"løyst" Hvem selger USB kontroller til 1.8 " hd?
Driver å modder ein TomTom go 910 GPS. Den har en 1.8" 20 gig hd. Skal sette inn ein 60 gig, det ej slit meder å finne nokon som sel ein usb kontoller som kan hjelpe meg med å kopiere innholdet på orginaldisken til den nye disken.
Nokon som kan gi meg ein link til ein billig usb kontroller som virka?
Kjøpte eit kabinett frå Deal Extreme.
Tusen takk for hjelpa JohnDoeMAKT og Dragonlove
Endret av ohy
Korleis finn eg ut kva slag grensesnitt som er på dei då?
Dette er infoen jeg har på 60 gig hardisken:
Toshiba introduces a 60GB 1.8-inch embedded HDD for consumer electronic (CE) devices, the MK6008GAH. Enabling some of today's most exciting, small form factor mobile devices, the new mini-drives offer manufacturers significant storage for consumer, commercial and PC applications - such as music players, handheld PCs, PDAs, wearable computers and laptops. Toshiba is committed to grow with developers and users to provide smart computing solutions, backed by Toshiba-renowned quality and technology leadership.
Data Storage Physical:
Per drive, formatted* 60.0GB
Number of Disks 2
Number of Data Heads 4
User Data Cylinders 55,728
Logical Configuration:
Heads 16
Cylinders 16,383
User Sectors/Track at zone 0 63
Logical Blocks (LBA) 117,210,240
Data Transfer Rate:
Buffer to Host- PIO 16.6MB/sec
Buffer to Host- Ultra DMA 100MB/sec
Maximum Internal 131.1 - 283.3 Mbits/sec
Seek Time:
Track-to-track 3ms
Average 15ms
Maximum 26ms
Nominal Power Requirements:
Voltage 3.3V (5%)
Energy Consumption Efficiency: 0.005W/GB
Power Consumption:
Start
Seeking
Reading
Writing
Idle
Standby
Sleep 1.8watts
1.1watts
1.0watts
1.0watts
0.4watts
0.12watts
0.07watts
Other:
Rotational Speed 4,200rpm
Average Latency 7.14ms
Interface ATA 6
Buffer 2Mbytes
Physical & Environmental Specs
Dimensions/Weight:
Height 0.31" (8mm)
Width 2.12" (54mm)
Depth 2.79" (71mm)
Weight 2.01 oz (59g)
Ambient Temperature:
Operating 41 - 140F (5 to 60C)
Non-Operating -4 - 149F (-20 to 65C)
Shipping -40 - 158F (-40 to 70C)
Vibration and Shock:
Operating Vibration 2.0G (15-500 Hz)
Operating Shock 500G/2.0ms
Non-Operating Shock 1,500G/1.0ms
Reliability Characteristics
Error Rates:
Non-recoverable 1 in 1013 bits
Seek 1 in 106 seeks
Other:
Preventive Maintenance None
Product Life 5 years or 20,000 power ON hours
Reknar med at det er ATA 6 som er avgjørande i eine eller andre retninga.
Korleis kan eg finne ut kva som er på den som sitter i GPSen? er det vits om eg legg ut eit bilde her? kan dokke fortelle meg kva det er då?
takk for hjelpa so langt:)
Men skulla helst hatt den kontrolleren iløpet av neste uke. så
