[LØST] Hvor finner jeg HKEY_CURRENT_USER\Software\Wine\
Dette ligger i registeret akkurat som på windows.
http://wiki.jswindle.com/index.php/Regedit
"Wine follows the example of windows regedit by allowing you to edit the registry and use a gui. The Wine implementation of regedit can be run via the command line using either
wine regedit
regedit
Note: As wine registory information is stored in human readable files, the Wine version of regedit apparently cannot be used on native Windows."
EDIT: et lite tips ;)
bruk Ctrl+F til å søke, og F3 for å bla til neste resultat
Endret av NorthWave
