chny Skrevet 5. mai 2008 Del Skrevet 5. mai 2008 Hei. Har fått tak i et galleri script jeg liker veldig godt, problemet er at jeg skulle ønske den sorterte thumbnails'ene etter navn. Hadde blitt veldig glad om noen kunne se på koden og si meg en løsning. Jeg har merka det rødt der jeg tror det må kodes inn en slags sorterting. Takk for all hjelp! <?php $images_folder = "images/"; $thumbnail_folder = "thumbs/"; $root_folder = dirname(__FILE__)."/"; function get_images() { global $root_folder, $images_folder; $dest = $root_folder.$images_folder; $dir = opendir($dest); if($dir != NULL) { $files = array(); while( ($file = readdir($dir)) != NULL) { if(!is_dir($dest.$file)) { $files[] = basename($file); } } return $files; } return NULL; } function print_img_tag($image_name_array) { [color="#FF0000"] global $thumbnail_folder; foreach($image_name_array as $image) { $thumbnail = $thumbnail_folder.$image; echo('<a href="'.$_SERVER["PHP_SELF"].'?img='.$image.'" onclick="showImage(\''.$image.'\'); return false;">'); echo('<img class="image" src="'.$thumbnail.'" />'); echo('</a>'); } [/color] } ?> <html> <head> <title>Gallery title</title> <style> html { background-color: #000; } #images { margin:0; padding:0; } #images a { margin: 0.4em; } #images img { border: 0; } #images a:hover { border-bottom: 5px solid #ff8000; } h1 { color: #aaa; font-family: "Lucida Console" verdana sans-serif; letter-spacing: -0.07em; font-size: 120%; } #image { margin-top: 1em; margin-left: 0.4em; } </style> <script languange="Javascript"> function showImage(img) { node = document.getElementById("image"); if(node != null) { node.innerHTML = '<img src="<?php echo($images_folder);?>'+img+'" />'; } } </script> </head> <body> <h1>Gallery title</h1> <div id="images"> <?php echo(print_img_tag(get_images())); ?> </div> <div id="image"> <?php if(isset($_GET["img"]) || strlen($_GET["img"]) > 0) { $img = basename($_GET["img"]); echo('<img src="'.$images_folder.$img.'" />'); } ?> </div> </body> </html> Lenke til kommentar
Lokaltog Skrevet 5. mai 2008 Del Skrevet 5. mai 2008 (endret) Jeg orker ikke å grave meg gjennom koden din (den ser også mangelfull ut), men du kan jo prøve noe slikt som dette: global $thumbnail_folder; sort($image_name_array); foreach($image_name_array as $image) { $thumbnail = $thumbnail_folder.$image; echo('<a href="'.$_SERVER["PHP_SELF"].'?img='.$image.'" onclick="showImage(\''.$image.'\'); return false;">'); echo('<img class="image" src="'.$thumbnail.'" />'); echo('</a>'); } Endret 5. mai 2008 av Lokaltog Lenke til kommentar
chny Skrevet 5. mai 2008 Forfatter Del Skrevet 5. mai 2008 Tusen takk, skal prøve! Lenke til kommentar
