"certified drivers" til SB live!
jeg prøver desperat å få kjørt Comanche4 fra novalogic, ettersom det krasjer på alle mulige steder før jeg kommer inn til selve helikopteret og får flydd litt sendte jeg inn mail til novalogic support, uten å få annet svar om at driverne må være "certified". Hvor finner jeg dette? og hva har det egentlig å si( når hardware kommer fra "industristandarden" creative)?
lang versjon:
Dear NovaLogic Customer,
Make sure you have certified drivers from the manufacturer of your hardware
or computer for both your Sound and Video Cards. To check your drivers,
click on Start, Find, Files or Folders, type in dxdiag.exe, click on Find
Now, double-click on dxdiag. You should now see your DirectX Diagnostic Tool
window. Select the tabs for DirectX Drivers, Display & Sound. Make sure
that all components have drivers that are certified. If not, you need to
contact the manufacturer of the device(s) and obtain drivers that are
certified with DirectX 7.0 or later. These should be available for download
on the internet.
-----Original Message-----
Sent: Thursday, January 03, 2002 4:32 AM
To: [email protected]
Subject: Comanche 4 Support
UserName = *********
UserPhone = *******
guide = no
update = yes
userts = Starting the game
version = latest using auto-update
Issue = The game freezez at several different stages. After the first
splash-screen when playing the intro, it definately crashes when trying to
skip the intro by pressing ESC, but if I let the intro play finished I get
to the main menu, but the main menu freezez, the sound chugs and goes into
loop about 1-2 seconds after I start moving my mouse. This is the most
common crash. Keyboard freezez aswell, and there is only a reboot left for
me to do.. As far as I remember it crashes even without me moving the mouse,
and a few times I've even been able to fiddle around the menus a while
before it crashed. What is the most interesting, to me at least, is that
I've actually played 2 missions before it crashed whilst loading the third..
a few times I get past the main menu, and get to 20%(variable, but this is
the most common) of loading the mission. To say the least, this is
frustrating. I've updated to the latest supported driver for my gfx-card,
reset the bios, adjusted to get more virtual memory, but I'm unsure of what
is actually the problem, seeing as the game actually started once and let me
play a few missions. Updating the game didn't see to fix my problems. Hope
you can give me a few hints :smile:
ComputerOS = Windows 2000
ComputerRAM = 128 MB RAM or more
ComputerManufacturer = Other
ComputerMfgOther = Self build
ComputerProcessorType = AMD Athlon
ComputerProcessorSpeed = 400 MHz or more
ISP = start.no
connectiontype = ISDN
ComputerVideoCard = ATI RADEON 64DDR VIVO
ComputerSoundCard = sound blaster live! value
submit = Submit
Dette svaret tok en uke å få som svar. Hadde jeg forventet noe annet? vel egentlig ikke. Jeg tenkte dog å være vrang, og skaffe certified drivers til mitt soundblanster live! 1024. jeg har søkt rundt på google f.eks og finner sider hvor det står hvor jeg finner disse driverne, men alle linkene til creative derfra er døde. Finnes noe sted jeg kan få tak i gamle drivere?
tror jeg er litt for dum til å skjønne noe av driverguide.com, men jeg fant bare døde linker til creative der hehe
hehe , har CREATIVE noen gang laget WHQL `certifiserte drivere ? :smile:
prøv å fjerne crap' driver fra Creative ,for mye tull i deres software...
sats på å bruke M$ drivere for det kortet , det går ihvertfall hvis du har w2k eller xp
