Bremser Hyundai Coupe
Hei,
En bremsekalipper til Hyundai Coupe ,inkl klosser, koster over 4000,- hos forhandler her i Norge.
I USA koster det samme til Hyundai Tiborun , ca 800,- inkl. frakt og moms inn til Norge.
Er det noen som vet om deler til Tiborun passer til Coupe. Tror det er samme bilen , men er ikke sikker.
Takknemlig hvis noen vet.
Harald
Fant dette på nettet, gi kanskje svar på mitt foregående spørsmål (Wikipedia)
Also called Hyundai RD Tiburon
Production 1996–1999
Assembly Asan, South Korea
Engine(s) 1.6 L (114 hp), 1.8 L (130 hp), or 2.0 L I4 Beta I DOHC (140 hp)
Transmission(s) 4-speed automatic
5-speed manual
Wheelbase 97.4 in (2474 mm).
Length 170.9 in (4341 mm).
Width 68.1 in (1730 mm).
Height 51.7 in (1313 mm).
Related Hyundai Elantra
5-speed manual
RD (1996- 1999)
Tiburon first began production in late 1996. It was available in a few foreign markets with engine choices of either 1.6L or 1.8L. In the United States, the Tiburon was first offered in 1997 with base models using the Elantra's 1.8L 130 hp (97 kW) engine while the upscale FX received a 2.0L four-cylinder engine. The 2.0L was rated at 140 hp (104 kW) at the crankshaft (the car's manual specifies 102 kW (137 hp) at the flywheel). Base weight was around 2,550 lb (1,150 kg), giving the RD Tiburon a higher power to weight ratio than the newer GK 2.0L. The 2.0L produces a 0-60 mph time of ~7.9 seconds[2], with a 1/4 mile time of ~16 seconds. In 1998 the Tiburon lost its weaker 1.8L engine, giving both models the 2.0L. All versions of the Tiburon manufactured from 1996-2001 are known as "RD" Tiburons. There were various options, with or without ABS, 2 airbags, leather, and sunroof.
