802.11g
Det finnes produkter basert på den foreløpige 802.11g standarden på det norske markedet. Jeg tror Buffalo Airstation G54 foreløpig er den eneste du får kjøpt i Norge.
Selv om standarden ikke er 100% ferdig utviklet, garanterer Buffalo for gratis oppgradering/erstatning av produktene når standarden er endelig.
Endelig standard forventes å være ferdig Juni, med publisering rundt slutten av Juli.
Det ble gjort noen endringer på standarden i Januar og de har to milepæler igjen før de endelig er ferdig.
Sakset fra en IEEE 802 info relase:
"Now that we have a complete draft of the IEEE P802.11g standard, some manufacturers are beginning to release products in accordance with it. While the IEEE is pleased to see early development of product based on our work, it is quite speculative to release products at this time."
"The IEEE P802.11g draft had technical changes made to it at the January 2003 session, and further changes are expected starting in March 2003 based on comments received from the sponsor organization of IEEE 802.11." said Brian Mathews, IEEE 802.11 publicity chair. He added, "The only sure way to guarantee compliance and avoid potential interoperability problems is to wait for final ratification of 802.11g, which is highly likely in June 2003."
Så jeg ville bedt de som selger Buffalo produktene om en skriftelig verifikasjon på at de vil bytte inn produktet du kjøper om det ikke er kompatibelt med endelig 802.11g standarden.
Standard 802.11g er 54mbps samme som 802.11a, men de bruker forskjellige frekvens spektrum.
JPT
Sakset litt fra buffalotech-sidene:
NOTE TO OUR CUSTOMERS:
As you may know, IEEE802.11g is slated to be certified by the Wi-Fi Alliance in mid 2003. We understand this could affect current 802.11g technology. We are dedicated to ensuring that our customers have the most current and reliable products available on the market today. If the certification materially changes the principal operating features of our pre-standard 802.11g products, we will replace or upgrade any of those products at no charge and provide toll-free technical support. We thank you for your loyalty and confidence in our products.
