ATI RADEON 9800 to be Launched Tomorrow
Posted 3/04/03 at 10:05 am by Anton
ATI Technologies did not tried to keep its secrets about the code-named R350 graphics processor really hard at this time, as loads of information about the newcomer is now available all around the Internet. Even though ATI Technologies always asks all who receive press materials and samples of the products to sign Non Disclosure Agreements, just like NVIDIA, who even asks some to sign NDAs without providing anything except a bit of official information about the future of the company, it could not hold the information from being leaked by a nearly official source in Taiwan.
The upcoming RADEON 9800 and RADEON 9800 PRO that will be launched on the 5th or on the 6th, both feature dual 400MHz RAMDAC, 165MHz TMDS transmitter, 8 pipeline architecture, 256-bit memory bus, 512Kb of serial flash ROM, AGP 8x/4x/2x compatibility, integrated TV-out controller (up to 1024x768) and HYDRAVISION technology to support for simultaneous dual displays and DirectX 9.0/OpenGL support.
It was said that the RADEON 9800 will be clocked at 325/620MHz for core and 128MB of DDR SDRAM memory. The RADEON 9800 PRO will probably support 256MB of DDR memory and will be clocked at 400/920MHz. Some sources indicated that there will be 375/750MHz versions of the product, while the 400/920MHz clocked graphics cards will either be limited edition or will be available later. To tell you the truth, the latter is more likely, as the VPU itself supports DDR-2M memory, while no memory maker announced production of such chips. On the other hand, Hynix announced 1000MHz DDR SDRAM memory products in late 2002 (see this news-story), thus, such chips should be available by now and ATI may utilise them in order to create the most-powerful graphics card on the market. Remember that this information should still be considered as unofficial.
http://www.xbitlabs.com/news/story.html?id=1046790346
9800 kortene er basert på R350... som igjen er samme som R300 bare produsert 13micro, hvilket tillater høyere klokking.
Det jeg ville frem til, er at 9700/9500 støtter også 256MB RAM. Det er bare ikke produsert.
Husker jeg ikke feil, så støtter Gf4 Ti4xx kortene også 256MB, men disse er heller ikke produsert pga kostnadene...
Bare til info :)
Oi, oi, oi... Lovende specs. Men jeg holder meg til nVidia. 8)
Noe sier meg at NV35 vil ha en minne hastighet på godt over 1Ghz, kanskje nærmere 1.5Ghz. :D
Dem må først få orden på kjølingen... Den bråker som en støvsuger.
Og prisen... Noe sier meg at Nvidia må ta seg sammen. Blir spennende å se hva S3 kan få til nå.
What also seems to be important is that the RADEON 9800 and the RADEON 9800 PRO will be made using copper 0.15 micron technology and will have a number of advantages over the previous-generation RADEON 9700 family.
According to our sources, the most important innovation of the RADEON 9800 is the F-buffer technology that supports pixel shader programs with unlimited number of instructions. We will compare this feature of the RADEON 9800 as well as the GeForce FX 5800, which also boasts with infinite number of pixel shaders instructions, once we have both in our lab. Another pair of innovations among the SMARTSHADER 2.1 architecture is Multiple Render Target and shadow volume rendering acceleration support.
Another couple of improvements are said to be introduced under SMOOTHVISION 2.1 brand-name. ATI is going to again optimize its FSAA and anisotropic filtering patterns to offer you even more speed and quality.
There may be other minor differences between the RADEON 9700 and RADEON 9800 VPUs, but I think you will have a great opportunity to learn more about them in one of our upcoming articles.
Helt den samme chippen er det vel ikke...Det er en del forbedringer!
nvidiaFX pro har 1000mhz og Radeon 9700Pro 620mhz minne, men de 2 korta er omtrent like raske, enda FX har mye raskere minne...
Stemmer. Make that 1.5Ghz - 2Ghz. :D
ATI har 256bit minne, Geforce FX har bare 128bit. Det er det som utgjør den store forskjellen på minne siden.
Komme med vannkjøling som standard. :D
S3? De pinglene? Nei, da har jeg heller troa på 3DLabs. :wink:
S3 pingler? Har du hørt om Columbia? Den skal visst være et fett kort hvis de ikke feiler som SiS gjorde med Xabre.
Personlig håper jeg Matrox hopper inn på markedet for raskhet, De har jo kvalitet men mangler fart.
Matrox er kule. Bare synd de ikke er litt bedre på 3D. Husker jeg hadde Matrox Mystique 4MB. Det var bra 3D kort det. :D
Matrox er bra på 3D... Men de er ikke raske i spill men brae in GL software som 3D Studio Max.
