Forandre hvilket OS som skal boote...?
http://apcmag.com/how_to_dual_boot_windows...alled_first.htm
I terminal:
sudo gedit /boot/grub/menu.lst
There are loads of options you can change, but only a couple that you’re likely to be interested in. The default boot entry is defined by the “default” value.
The default value is 0, which means that the first entry in the list (which is Ubuntu) always gets loaded.
If you want to make it so that Windows XP loads by default, change the value to 4, as XP is the fifth item in the list (the numbering system starts at 0).
The other way to load Windows XP by default is to change the value for “default” from a numerical value to “saved”. Then, GRUB will load whichever boot entry has been marked with “savedefault”.
If you scroll down the list and have a look at the entries, you’ll notice that both the main Ubuntu entry and Windows XP have been marked with “savedefault”. Remove the value for Ubuntu and Windows XP will launch by default.
