Acer 5920 eller 6920
Hei hva ville dere valgt mellom disse to
Aspire 5920G Pris ca 9000
Spesifikasjoner:
Prosessor: Intel Core 2 Duo T7500 (Santa Rosa)
Skjerm : 15,4" Acer Crystal BrigthTFT WXGA (1280x800)
Minne : 2048 MB (2 x1024MB)
Harddisk : 250 GB Harddisk
Optisk Enhet : Blu-Ray Leser, DVD Brenner
Chip-set : Mobile Intel PM965 Express
Grafikk : Geforce 8600-GT
Optisk enhet : DVD Super Multi DVD Leser og DVD Brenner
Kommunikasjon : FireWire 1394, HDMI™ port med HDCP support, Bluetooth
Lydkort : Dolby®-certified surround sound system with two built-in Acer 3DSonic stereo speakers and one subwoofer supporting low-frequency effects, Intel® High-Definition audio support,S/PDIF (Sony/Philips Digital Interface) support for digital speakers
Batteri : 8 Celler
Eksterne porter : 4 x USB 2.0 ports, 1 x HDMI™ port with HDCP support,1 x External display (VGA) port,1 x ExpressCard™/54 slot, 5-in-1 card reader (SD/MMC/MS/MS PRO/xD), 1 x S-video/TV-out (NTSC/PAL) port,1 x Consumer infrared (CIR) port , 1 x IEEE 1394 port ,1 x Modem (RJ-11) port , 1 x Ethernet (RJ-45) port ,1 x Headphone/speaker/line-out jack with S/PDIF support, Blåtann
Nettverkskort : 10/100 Mbit nettverkskort,Trådløst 802.11g/n WLAN
Tastatur : 88-/89-key keyboard, inverted "T" cursor layout, 2.5 mm (minimum) key travel, Seamless touchpad pointing device with 4-way scroll button, 12 function keys, four cursor keys, two Windows® keys, hotkey controls, embedded numeric keypad, international language support, independent Euro and US dollar sign keys, Empowering Key , asy-launch buttons: WLAN, Internet, email, Bluetooth®, 3G (optional), Acer Arcade™ ,Acer MediaTouch keys: play/pause,stop,previous,nextandrecord keys
Vekt . 2.75 Kg
Programvare :Windows Vista Home Premium Edition (Norsk, Dansk, Engelsk) , Norton® Antivirus (3 md. fri bruk), Cyberlink PowerDVD, NTI CD Maker,Acer Notebook Manager, Adobe Acrobat Reader, On-line User Guide, Acer GridVista,Microsoft® Works 8.5 with Office Home and Student 2007 Trial
Garanti : 1 års garanti (ikke på batteri) Support : 800 84 880 (09:00 – 17:00)
Multimedia : 5 i 1 kortleser for (SD/MMC/MS/MS PRO/xD), 0.3MP Orbicam - Web kamera integrert
Eller denne
Acer Aspire 6920G Core 2 Duo T8100 Pris 11000
Spesifikasjoner:
Prosessor: Intel Core 2 Duo T8100 (2.1GHz)
Skjerm : 16" WXGA Acer CrystalBrite™ TFT LCD (1920x1080)
Minne : 4096 MB (2 x2048MB) NB: Kun ca. 3070MB RAM vil være synlig i Windows da skjermkortet allokerer internminne for optimal ytelse.
Harddisk : 320 GB Harddisk
Chip-set :
Grafikk : Geforce 9500 GS med opptil 1280 MB of HyperMemory™ (512 MB dedikert GDDR2 VRAM, opptil 768 MB delst systemminne*), støtter Microsoft® DirectX® 10 og PCI Express®
Optisk enhet : DVD - Blu-ray
Lydkort : Dolby®-certified surround lydsystem med to innebygde Acer 3DSonic stereo høyttalere og en subwoofer som støtter lave frekvenser, Intel® High-Definition audio støtte, S/PDIF (Sony/Philips Digital Interface) støtte.
Batteri : 6 Celler
Eksterne porter : 4 x USB 2.0 ports,,1 x External display (VGA) port,1 x DVI, 1 x ExpressCard™/54 slot, 5-in-1 card reader (SD/MMC/MS/MS PRO/xD), 1 x S-video/TV-out (NTSC/PAL) port,1 x Consumer infrared (CIR) port , 1 x IEEE 1394 port ,1 x Modem (RJ-11) port , 1 x Ethernet (RJ-45) port ,1 x Headphone/speaker/line-out jack with S/PDIF support
Nettverkskort : 10/100 Mbit nettverkskort,Trådløst 802.11g/n WLAN , Blåtann og biometrisk fingeravtrykkleser
Tastatur : 88-/89-tasters tastatur, sømløs touchpad pekeenhet med 4-veis scroll-tast, 12 funksjonstaster, 4 markørtaster, 2 Windows® taster, hurtigsatstkontroll, internasjonal språkstøtte, Acer Empowering tast. Knapper for: WLAN, Internett, e-post, Bluetooth®, 3G (optional), Acer Arcade™, Acer MediaTouch keys: play/pause,stop,previous,nextandrecord keys
Vekt : 3.6 Kg
Programvare :Windows Home Premium Edition (Norsk, Dansk, Engelsk) , Norton® Antivirus (3 md. fri bruk), Cyberlink PowerDVD, NTI CD Maker,Acer Notebook Manager, Adobe Acrobat Reader, On-line User Guide, Acer GridVista,Microsoft® Works 8.5 with Office Home and Student 2007 Trial
Jeg blir og bruke pcen til og spille, film og surfe med.
Hvilken har best spesifikasjoner til prisen og som sagt hvilken ville dere valgt.
Skal konfirmeres snart så får litt spenn:)
Endret av Kingleverpostei
Skjermoppløsningen på 6920 blir tung å drive i spill med bare 9500M GS, og du vil mest sannsynlig måtte skru oppløsningen for å få spill til å kjøre glatt - da kjører du i ikke-native oppløsning med de konsekvenser det får (uskarpt/grumsete bilde). Til annen bruk er det sikkert kjekt med god plass på skrivebordet. vekta er drøy i forhold til at elprice reklamerer med at den ikke er større enn en 15,4" maskin.
På den annen side er 1280x800 ubehagelig lav oppløsning på en 15,4" skjerm, etter min mening, og det (eneste?) store ankepunktet mot 5920G.
Står valget kun mellom disse to? Får en del mer ytelse for pengene med en Dell XPS m1530, evt. Thinkpad T61P (så lenge lageret rekker) som er på billigsalg for tiden. 14" skjerm blir kanskje noe knapt til film, ellers ser jeg ingen store ankepunkter med denne (best ytelse i prisklassen).
Takk for svar, men har ThinkPad T61p blu ray? og hvem har best grafikk kort av disse?
Er ikke så god på sånt:P
Jeg blir nåkk å spille COD4, flight simulator x og orange box.
Ønsker 15" og oppover, blu ray, hdmi og blue tooth.
Det står ikke nødvendig vis mellom de, men tenker og bruke under 11 lappa.
Takker på forhånd.
Dell XPS m1530 har nok det beste grafikkortet i denne prisklassen (T61P omtrent like bra, men antar den ikke er aktuell for deg). m1530 kan du få med skjermoppløsningene 1440x900 eller 1680x1050 som jeg synes er langt mer hensiktsmessige til ditt bruk. HDMI har den, blu-ray og bluetooth kan du få den satt opp med når du konfigurerer den på dells sider.
Fikk smaken av dell m1530.
Men hvordan er batteri tiden med 6 cellers. Og hvordan er støynivået på disse.
Vil denne kjøre fsx, cod4, orange box?
Komponenter
Intel® Core™ 2 Duo-prosessor T8300 (2,40 GHz, 800 MHz FSB, 3 MB L2-buffer)
Ekte Windows Vista™ Home Premium - norsk
Standardgaranti - 1 års XPS Premium Hardware Support (inkl. spill- og på stedet-støtte)
2,0 megapikslers kamera og Tuxedo-svart for CCFL-skjerm
15,4-tommers UltraSharp™ widescreen WSXGA+ (1680 x 1050) TFT-skjerm med TrueLife™
Biometrisk fingeravtrykksleser med SVART preg
3072 MB 667 MHz Dual Channel DDR2 SDRAM [1x2048+1x1024]
250 GB (5400 rpm) SATA-harddisk
NVIDIA® GeForce™ Go 8600M GT med 256 MB dedikert grafikkminne
Fast 8x DVD+/-RW slank stasjon med innstikksplass, inkludert programvare
6-cellers primært litiumionbatteri (56 W/t)
Er det stor forskjell på T8300 og T9300?
Og er det forskjell fra acer sitt 8600gt og dell sitt?
grafikkortet i XPS m1530 bruker GDDR3 minnebrikker mot GDDR2 som er i acer-maskinene. med GDDR3-brikker yter 8600M GT ca 20% bedre eller ca 1000 poeng mer i 3DMark06.
Batteritid og støy kan du søke etter i den store tråden som går om denne maskinen, men jeg mener å huske antydninger om ca 2,5 timer batteri ved "normal" bruk med 6-cellers og 4,5 timer med 9-cellers batteri.
Endret av ventle
Jeg tror faktisk at 5920G har DDR3 minne på grafikk-kortet, mener å huske at det stod det på multicom da jeg kjøpte den der, jeg mener at jeg så i Acer Aspire 5920 tråden at den hadde det og at Inspiron PC'ene hadde DDR2 minne. (Da det fortsatt var mulig å kjøpe Inspiron PC-er med 8600-kortet.)
Men anyway, vurdert Dell XPS M1710? Den er jo latterlig billig, og har et av de beste skjermkortene for bærbare. Vet ikke om 17" blir for stort for deg men, fortsatt verd å ta en titt på. ;)
(Vil også si at Dells support er veldig bra, i forhold til visse andre bedrifter...)
Endret av magneman
Må du gi mye ekstra for T9300 i forhold til T8300? Forskjellen er såvidt jeg vet bare at T9300 har dobbelt så mye L2-cache, noe som i gjennomsnitt skal gi ett sted mellom 5 og 10% ytelsesøkning i ren prosessorytelse (den samlede ytelsen vil ikke øke mye mer da det er mange fler ting som spiller inn, men i svært prosessorkrevende oppgaver, sånn som tunge beregningsprogrammer og rendering av videofiler vil du nok kunne kappe noen sekunder). Stor forskjell er det ikke, men om prisforskjellen er liten, hvorfor ikke gå for det beste?
angående oppløsning er dette subjektivt og mye en vanesak. Hvor stor skjerm med hvor stor oppløsning bruker du til daglig? Er dette en bærbar eller stasjonær skjerm?
Da er du vant til forholdsvis lav oppløsning fra tidligere. 1680x1050 ville vært mitt klare valg, men jeg spiller ikke lengre. De nyeste spillene må du nok måtte regne med å kjøre i litt lavere oppløsninger for å få god flyt og ha de andre instillingene over middels. Jeg regner med du vil bli fornøyd med 1440x900 hvis du prioriterer spillytelse.
Jeg synes ikke det er verdt 900 kroner for å gå opp til T9300. Til spill, film og surfing, som du sier du skal bruke den til, vil du ikke merke forskjellen hverken i dag eller fremtiden ettersom film og surfing er lett match for alle dagens prosessorer, mens skjermkortet uansett er flaskehalsen i spill. Har du likevel god råd kan du alltids koste det på deg, men verd pengene er det ikke.
Ja, 1440x900 på en 1440x900-skjerm vil bli så skarpt som det er mulig å få det på dette panelet. 1440x900 på en 1680x1050-skjerm vil bli uskarpt ettersom pikslene i skjermbildet må deles på flere av de fysiske pikslene på skjermen. Langt fra optimalt og svært slitsomt til daglig bruk. I 3D-spill har det ikke så mye å si ettersom det er såpass mye bevegelse i bildet uansett, men satt side om side ville du nok ikke hatt problem med å se at skjermen som kjører i native oppløsning er mye skarpere.
Det ser du enkelt på 3DMark-resultatene. 5920G ligger i området 3500-4000 poeng i 3DMark06, mens med GDDR3-minne på skjermkortet ville det klart poengsummer mellom 4500 og 5000 poeng, så det er ikke tvil om at 5920Gs skjermkort benytter seg av tregere GDDR2 minnebrikker.
Dessuten kan du prøve å google det litt, og dukker da over ett par tråder i forumet på notebookreview der folk snakker om å oppgradere skjermkortet i 5920G til 8600M GT GDDR3. Mye vits i å gjøre dette hvis dette kortet allerede sitter i maskinen?
