Feil i template-funksjon.
Hei!
Her er template-classen
class Template
VARIABLES
Setting our variables
var $template; 			//The template name
var $template_string;		//The template string will be stored here
var $prefix	= "{"; 		//The variable prefix character.
var $suffix	= "}"; 		//The variable suffix character.
var $var_array = array(); 	//The values of your variables will be stored here
	var $root;
function selectTemplate($filename)
	$this->template = "template/" . $filename . ".htm";
function addVar($name, $value)
	//storing our variable and its value into an array
	$this->var_array[$name] = $value;
function loadFile()
	//saving its contents into a string	/
	$this->template_string = file_get_contents("../" . ($this -> template));
function replaceVars()
	//The foreach loop is very useful when we want to loop through
	//associative arrays.
	foreach($this->var_array as $assoc => $value)
		//appending the variable prefixes to match. ex: {VAR_NAME}
		$var_name = $this->prefix.$assoc.$this->suffix;
		//replacing every instance of the variable with it's corresponding value.
		//so {VAR_NAME} becomes "this is my variable"
		$this->template_string = str_replace($var_name, $value, $this->template_string);
 function Parse()
	//loading the file
	$this->loadFile();
	//setting the variables
	$this->replaceVars();
	//outputting the newly parsed template :)
	// ** return $this->template_string;
	print $this->template_string;
}//end of class
(Husker ikke hvor jeg lastet den ned, uansett cred til h*n som har skrevet den)
Og her er en del av nyhets-scriptet mitt som kaller template-funksjonen
$max = 5;
$current = 0;
while($Rad=mysql_fetch_array($result) and $current < $max+1)
$Template[$current] = new Template;
	$Template[$current] -> selectTemplate("news");
	$Template[$current] -> addVar("Id",$Rad['id']);
	$Template[$current] -> addVar("Overskrift",$Rad['overskrift']);
	$Template[$current] -> addVar("Nyhet",$Rad['nyhet']);
	// Henter brukerinfo om brukeren som har skrevet nyheten.
	$brukerID = $Rad['bruker'];
	$SQL = "SELECT * FROM brukere WHERE id='$brukerID'";
	$result = mysql_query($SQL);
	$BrukerRad = mysql_fetch_row($result);
	$Template[$current] -> addVar("BrukerId",$BrukerRad[0]);
	$Template[$current] -> addVar("BrukerNick",$BrukerRad[6]); // nr 6 pga den peker til kolonnen "nick"
	$Template[$current] -> Parse();
$current++;
Problemet er at databasen / tbl'n som innholder 10nyheter, skal 5 skrives ut.. men denne skriver bare ut 1..
Noen som vet hvorfor? Ser ut til at template-funksjonen Parse() ikke liker å bli kalt i while loop for meg.
SQL-spørringen til tbl'n er
SELECT * FROM nyheter ORDER BY timestamp DESC
edit :
$Template[current] ble bare lagt til for debugging, glemte å fjerne den.
Før brukte jeg bare $Template .
Endret av Hayer
Gjest Slettet+1298342134
Jeg ser ikke hvorfor denne koden ikke skal fungere, har du satt på error_reporting og sjekket at SQLen din gjør det den skal?
Og jeg ser du bruker litt php og en ekstra spørring for å hente brukernavnet på den som skrev nyheten, du kan få alt i en spørring:
SELECT nyheter.id, nyheter.overskrift, nyheter.nyhet, brukere.nick FROM nyheter INNER JOIN brukere ON brukere.id = nyheter.bruker ORDER BY timestamp DESC
Her ligger feilen din:
Du setter $result variabelen til å peke til et nytt datasett istedenfor det som holder alle nyhetene dine, derfor får du bare første nyheten.
Her har jeg skrevet litt om koden din:
$sql = "SELECT nyheter.id, nyheter.overskrift, nyheter.nyhet, brukere.nick, brukere.id AS brukerid FROM nyheter INNER JOIN brukere ON brukere.id = nyheter.bruker ORDER BY timestamp DESC LIMIT 0,10";
$result = mysql_query($sql);
while($Rad = mysql_fetch_array($result)) {
$Template = new Template;
$Template -> selectTemplate("news");
$Template -> addVar("Id", $Rad['id']);
$Template -> addVar("Overskrift", $Rad['overskrift']);
$Template -> addVar("Nyhet", $Rad['nyhet']);
$Template -> addVar("BrukerNick",$Rad['nick']);
$Template -> addVar("BrukerId", $Rad['brukerid']);
$Template -> Parse();
Dette henter bare ut de 10 første nyhetene.
Endret av Slettet+1298342134
