simen_gunnar Skrevet 11. april 2008 Del Skrevet 11. april 2008 Hei. De som har rendret i videocodecen x264 før vet hva jeg snakker om :] Jeg har tidligere brukt det til å rendre i kvaliteten 1280x720, men nå skal jeg rendre en film i 1280x1024! Hva slags endringer må jeg gjøre i "makemp4.bat" da? Det jeg har nå ser sånn ut: @echo off :------------------- : See http://wiki.meaz.org/index.php?title=Codecs:x264 for latest info :------------------- :START :------------------- : Start Configuration :------------------- : You need to export your movie as an avi with a filename. : You need to export your movie sound as a wav with the same filename. : Set the filename you will use on here. set mymovie=ja :------------------- :set the path to your files here (no \ at the end) :------------------- set mypath=C:\x264 :------------------- :set the audio bitrate to use here :------------------- set myabitrate=192 :------------------- :set the video bitrate to use here :------------------- set myvbitrate=5000 :------------------- :set the video frame rate you used here :------------------- set myfps=30 :------------------- :End Configuration :------------------- mkdir %mypath%\temp cls echo AVISource("%mypath%\%mymovie%.avi") > "%mypath%\%mymovie%.avs" echo Crop(0,0,-0,-0) >> "%mypath%\%mymovie%.avs" echo ConvertToYV12() >> "%mypath%\%mymovie%.avs" echo ======Encoding AAC audio====== "bin\faac.exe" -b %myabitrate% -o "%mypath%\temp\%mymovie%.m4a" "%mypath%\%mymovie%.wav" echo ============================== echo. echo ======= x264 pass 1/3 ======== "bin\x264.exe" -p 1 --bitrate %myvbitrate% --ref 3 --bframes 3 --subme 6 --weightb --analyse all --8x8dct --qpmin 4 --qpstep 6 --merange 24 --me umh --progress --no-psnr --stats "temp\x264.stats" --output NUL "%mymovie%.avs" echo ============================== echo. echo ======= x264 pass 2/3 ======== "bin\x264.exe" -p 3 --bitrate %myvbitrate% --ref 3 --bframes 3 --subme 6 --weightb --analyse all --8x8dct --qpmin 4 --qpstep 6 --merange 24 --me umh --progress --no-psnr --stats "temp\x264.stats" --output NUL "%mymovie%.avs" echo ============================== echo. echo ======= x264 pass 3/3 ======== "bin\x264.exe" -p 2 --bitrate %myvbitrate% --ref 3 --bframes 3 --subme 6 --weightb --analyse all --8x8dct --qpmin 4 --qpstep 6 --merange 24 --me umh --progress --no-psnr --stats "temp\x264.stats" --output "temp\%mymovie%.264" "%mymovie%.avs" echo ============================== echo. echo === Muxing Audio and Video === "bin\mp4box" -new -add "%mypath%\temp\%mymovie%.264#video" -add "%mypath%\temp\%mymovie%.m4a#audio" -fps %myfps% "%mypath%\%mymovie%.mp4" echo ============================== echo. if EXIST "%mypath%\%mymovie%.mp4" rmdir /S /Q temp del "%mypath%\%mymovie%.avs" :END echo If you have any errors, you haven't edited makemp4.bat correctly!!! echo Otherwise the video is now done and can be found with the filename: echo %mymovie%.mp4 echo. pause Hva må jeg endre på? Takker for evt. svar Lenke til kommentar
