Autostart av avant window navigator
Jeg har prøvd nå å få AWN til å starte automatisk når Ubuntu starter, sammen med de prog. som jeg har lagt til (drag n drop ikoner inn i AWN). Men når jeg restarter maskinen er alle ikonene borte fra AWN! Og av og til starter ikke awn automatisk heller!
Noen som kan assistere? :whistle::)
Får fortsatt ikke til dette. Jeg kjører kommandoen sudo avant-window-navigator settings i terminal og får dette:
/apps/avant-window-navigator/force_monitor unset, setting now
/apps/avant-window-navigator/monitor_width unset, setting now
/apps/avant-window-navigator/monitor_height unset, setting now
/apps/avant-window-navigator/panel_mode unset, setting now
/apps/avant-window-navigator/auto_hide unset, setting now
/apps/avant-window-navigator/auto_hide_delay unset, setting now
/apps/avant-window-navigator/keep_below unset, setting now
/apps/avant-window-navigator/bar/bar_height unset, setting now
/apps/avant-window-navigator/bar/bar_pos unset, setting now
/apps/avant-window-navigator/bar/bar_angle unset, setting now
/apps/avant-window-navigator/bar/icon_offset unset, setting now
/apps/avant-window-navigator/bar/rounded_corners unset, setting now
/apps/avant-window-navigator/bar/corner_radius unset, setting now
/apps/avant-window-navigator/bar/render_pattern unset, setting now
/apps/avant-window-navigator/bar/pattern_uri unset, setting now
/apps/avant-window-navigator/bar/pattern_alpha unset, setting now
/apps/avant-window-navigator/bar/glass_step_1 unset, setting now
/apps/avant-window-navigator/bar/glass_step_2 unset, setting now
/apps/avant-window-navigator/bar/glass_histep_1 unset, setting now
/apps/avant-window-navigator/bar/glass_histep_2 unset, setting now
/apps/avant-window-navigator/bar/border_color unset, setting now
/apps/avant-window-navigator/bar/hilight_color unset, setting now
/apps/avant-window-navigator/bar/show_separator unset, setting now
/apps/avant-window-navigator/bar/sep_color unset, setting now
/apps/avant-window-navigator/window_manager/show_all_windows unset, setting now
/apps/avant-window-navigator/window_manager/launchers unset, setting now
/apps/avant-window-navigator/app/active_png unset, setting now
/apps/avant-window-navigator/app/use_png unset, setting now
/apps/avant-window-navigator/app/arrow_color unset, setting now
/apps/avant-window-navigator/app/arrow_offset unset, setting now
/apps/avant-window-navigator/app/tasks_have_arrows unset, setting now
/apps/avant-window-navigator/app/name_change_notify unset, setting now
/apps/avant-window-navigator/app/alpha_effect unset, setting now
/apps/avant-window-navigator/app/icon_effect unset, setting now
/apps/avant-window-navigator/title/text_color unset, setting now
/apps/avant-window-navigator/title/shadow_color unset, setting now
/apps/avant-window-navigator/title/background unset, setting now
/apps/avant-window-navigator/title/font_face unset, setting now
** (avant-window-navigator:25268): WARNING **: Failed to make connection to session bus: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
** (avant-window-navigator:25268): CRITICAL **: dbus_g_proxy_new_for_name: assertion `connection != NULL' failed
** (avant-window-navigator:25268): CRITICAL **: dbus_g_proxy_call: assertion `DBUS_IS_G_PROXY (proxy)' failed
** (avant-window-navigator:25268): WARNING **: There was an error requesting the name: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Segmentation fault (core dumped)
Noen som har en idé om hvorfor jeg ikke får åpnet settings?
AWN starter normalt.
  • 2 måneder senere...
ja. du skal ikke kjøre avant eller manager'en med sudo. når de kjøres som sudo, vil alt de lagrer av instillinger ha root-eierskap. avslutt dem begge to, endre alt de eventuelt har lagret (tror de lagrer i .config/awn), og start dem uten sudo.
