alsamixer i arch: lite å justere
Jeg skaffet et nytt hovedkort nettopp, kalt P5E-V HDMI
Kortet rocker, og jeg har HD-lydutganger på det som jeg koplet til et 5:1 surroundanlegg.
Problemet er at jeg ikke kan justere bass og diskant! På det eksterne lydkortet mitt var det en ekstra avkryssingsboks i alsamixer kalt "tone", som man krysset av, og dermed kunne man justere bass med LFE. Denne knappen har jeg ikke med HDA_intel lyddriveren her, og LFE er en død heis.
Hva kan jeg gjøre?
Endret av Mads-b
Har samme hovedkort (m-ATX modellen), jeg har ikke testet kortet i ALSA, men det fungerer helt fint i OSS, men ikke med andre lydjusteringsprogrammer en ossmix (kmix, rexima, aumix finner ingenting).
Info ang. mikseren:
HDAUDIO MIXER
The Intel HDA mixer is a new type of mixer that doesn't have the normal volume controls
found on AC97 or legacy SB devices. The HDA mixer presents a concept of Jacks and you can
configure any jack to be either an output or an input jack.
Some motherboards may not correctly initialize the jacks according to their color and func-
tionality but in general here's the configuration that should generally be followed:
o Orange = Center/LFE
o Blue = Line-in
o Black = Rear
o Green = Front
o Grey = Side
o Pink = Mic
Some Azalia codecs support front panel connectors and so if you see fp-green and fp-pink
connectors, then these are for front panel speaker and mic/line-in Jacks.
There is a function selector for most of the analog audio jacks (for example connec-
tor.pink.mode). This selector is used to control if the jack is used as an input
(microphone or line in) or output (front, rear, side, speaker, etc).
ossinfo:
Version info: OSS 4.1 (b 080323/200804061624) (0x00040090) GPL
Platform: Linux/i686 2.6.23 #1 SMP Mon Feb 25 04:27:09 CET 2008 (bufu)
Number of audio devices: 9
Number of audio engines: 17
Number of MIDI devices: 0
Number of mixer devices: 1
Device objects
0: osscore0 OSS core services
1: hdaudio0 Intel HD Audio interrupts=1471398 (1475119)
HD Audio controller Intel HD Audio
Vendor ID 0x8086293e
Subvendor ID 0x10438277
Codec 0: ALC883 (0x10ec0883/0x1043829f)
Codec 1: Unknown (0x10951392/0xffffffff)
2: ossusb0 USB audio core services
3: vmix0 OSS transparent virtual mixer
MIDI devices (/dev/midi*)
Mixer devices
0: High Definition Audio ALC883 (Mixer 0 of device object 1)
Audio devices
HD Audio front /dev/oss/hdaudio0/pcm0 (device index 0)
HD Audio rear /dev/oss/hdaudio0/pcm1 (device index 1)
HD Audio center/LFE /dev/oss/hdaudio0/pcm2 (device index 2)
HD Audio side /dev/oss/hdaudio0/pcm3 (device index 3)
HD Audio pcm4 /dev/oss/hdaudio0/pcm4 (device index 4)
HD Audio spdif-out /dev/oss/hdaudio0/spdout0 (device index 5)
HD Audio spdifout /dev/oss/hdaudio0/spdout1 (device index 6)
High Definition Audio mix /dev/oss/hdaudio0/pcmin0 (device index 7)
High Definition Audio mix /dev/oss/hdaudio0/pcmin1 (device index 8)
ossmix (hva jeg har mulighet til å stille på):
Selected mixer 0/High Definition Audio ALC883
Known controls are:
codec1.connector.green.mode <front|rear|center/LFE|side|pcm4|input> (currently front)
codec1.connector.green <both/leftvol>[:<rightvol>] (currently 29.9:29.9 dB)
3 ON|OFF (currently OFF)
codec1.connector.black.mode <front|rear|center/LFE|side|pcm4|input> (currently center/LFE)
codec1.connector.black <both/leftvol>[:<rightvol>] (currently 29.9:29.9 dB)
221111 ON|OFF (currently OFF)
codec1.connector.orange.mode <front|rear|center/LFE|side|pcm4|input> (currently rear)
codec1.connector.orange <both/leftvol>[:<rightvol>] (currently 29.9:29.9 dB)
212111 ON|OFF (currently OFF)
codec1.connector.gray.mode <front|rear|center/LFE|side|pcm4|input> (currently pcm4)
codec1.connector.gray <both/leftvol>[:<rightvol>] (currently 29.9:29.9 dB)
222111 ON|OFF (currently OFF)
codec1.connector.pink.mode <front|rear|center/LFE|side|pcm4|input> (currently front)
codec1.connector.pink <both/leftvol>[:<rightvol>] (currently 29.9:29.9 dB)
211211 ON|OFF (currently OFF)
codec1.connector.fp-pink.mode <front|rear|center/LFE|side|pcm4|input> (currently front)
codec1.connector.fp-pink <both/leftvol>[:<rightvol>] (currently 29.9:29.9 dB)
221211 ON|OFF (currently OFF)
codec1.connector.blue.mode <front|rear|center/LFE|side|pcm4|input> (currently input)
codec1.connector.blue <both/leftvol>[:<rightvol>] (currently 29.9:29.9 dB)
212211 ON|OFF (currently OFF)
codec1.connector.fp-green.mode <front|rear|center/LFE|side|pcm4|input> (currently front)
codec1.connector.fp-green <both/leftvol>[:<rightvol>] (currently 29.9:29.9 dB)
222211 ON|OFF (currently OFF)
211121 ON|OFF (currently OFF)
221121 ON|OFF (currently OFF)
212121 ON|OFF (currently OFF)
222121 ON|OFF (currently OFF)
211221 ON|OFF (currently OFF)
221221 ON|OFF (currently OFF)
212221 ON|OFF (currently OFF)
222221 ON|OFF (currently OFF)
211112 ON|OFF (currently OFF)
codec1.record.mix1 <both/leftvol>[:<rightvol>] (currently 43.4:43.4 dB)
221112 ON|OFF (currently OFF)
212112 ON|OFF (currently OFF)
222112 ON|OFF (currently OFF)
211212 ON|OFF (currently OFF)
221212 ON|OFF (currently OFF)
212212 ON|OFF (currently OFF)
222212 ON|OFF (currently OFF)
211122 ON|OFF (currently OFF)
221122 ON|OFF (currently OFF)
codec1.record.mix2 <both/leftvol>[:<rightvol>] (currently 43.4:43.4 dB)
codec1.misc.mic <both/leftvol>[:<rightvol>] (currently 43.4:43.4 dB)
codec1.misc.fp-mic <both/leftvol>[:<rightvol>] (currently 43.4:43.4 dB)
codec1.misc.linein <both/leftvol>[:<rightvol>] (currently 43.4:43.4 dB)
codec1.misc.fp-headphone <both/leftvol>[:<rightvol>] (currently 43.4:43.4 dB)
codec1.misc.green <both/leftvol>[:<rightvol>] (currently 43.4:43.4 dB)
codec1.misc.black <both/leftvol>[:<rightvol>] (currently 43.4:43.4 dB)
codec1.misc.orange <both/leftvol>[:<rightvol>] (currently 43.4:43.4 dB)
codec1.misc.gray <both/leftvol>[:<rightvol>] (currently 43.4:43.4 dB)
codec1.misc.input-mix <mic|fp-mic|linein> (currently mic)
212122 ON|OFF (currently OFF)
222122 ON|OFF (currently OFF)
codec1.misc.front1 <both/leftvol>[:<rightvol>] (currently 43.4:43.4 dB)
codec1.misc.front2 <front|input-mix> (currently front)
211222 ON|OFF (currently OFF)
221222 ON|OFF (currently OFF)
codec1.misc.rear1 <both/leftvol>[:<rightvol>] (currently 43.4:43.4 dB)
codec1.misc.rear2 <rear|input-mix> (currently rear)
212222 ON|OFF (currently OFF)
222222 ON|OFF (currently OFF)
codec1.misc.center/lfe1 <both/leftvol>[:<rightvol>] (currently 43.4:43.4 dB)
codec1.misc.center/lfe2 <center/LFE|input-mix> (currently center/LFE)
codec1.misc.side1 <both/leftvol>[:<rightvol>] (currently 43.4:43.4 dB)
codec1.misc.side2 <side|input-mix> (currently side)
codec1.misc.pcm41 <both/leftvol>[:<rightvol>] (currently 43.4:43.4 dB)
codec1.misc.pcm42 <pcm4|input-mix> (currently pcm4)
vmix0-src <Fast|Low|Medium|High|High+|Production|OFF> (currently Fast)
vmix0-vol <monovol> (currently 25.0 dB)
vmix0-out1 <leftVU>:<rightVU>] (currently 121:121)
vmix0-out.pcm9 <both/leftvol>[:<rightvol>] (currently 25.0:25.0 dB)
vmix0-out2 <leftVU>:<rightVU>] (currently 121:121)
vmix0-out.pcm10 <both/leftvol>[:<rightvol>] (currently 25.0:25.0 dB)
vmix0-out3 <leftVU>:<rightVU>] (currently 0:0)
vmix0-out.pcm11 <both/leftvol>[:<rightvol>] (currently 25.0:25.0 dB)
vmix0-out4 <leftVU>:<rightVU>] (currently 0:0)
vmix0-out.pcm12 <both/leftvol>[:<rightvol>] (currently 25.0:25.0 dB)
vmix0-out5 <leftVU>:<rightVU>] (currently 0:0)
vmix0-out.pcm13 <both/leftvol>[:<rightvol>] (currently 25.0:25.0 dB)
vmix0-out6 <leftVU>:<rightVU>] (currently 0:0)
vmix0-out.pcm14 <both/leftvol>[:<rightvol>] (currently 25.0:25.0 dB)
vmix0-out7 <leftVU>:<rightVU>] (currently 0:0)
vmix0-out.pcm15 <both/leftvol>[:<rightvol>] (currently 25.0:25.0 dB)
vmix0-out8 <leftVU>:<rightVU>] (currently 0:0)
vmix0-out.pcm16 <both/leftvol>[:<rightvol>] (currently 25.0:25.0 dB)
vmix0-out9 <leftVU>:<rightVU>] (currently 0:0)
vmix0-in <leftVU>:<rightVU>] (currently 0:0)
jadda.. Prøvde OSS også, men systemet er fantastisk innfløkt. Ikke fant jeg ut hvordan jeg justerte bass og diskant i ossxmix heller :(
Klarte dog å få lyd på alle jackene, men så langt er jeg mad ALSA også, med et mye penere mixergrensesnitt.
