Alltid samme error i winapi program
Jeg prøver å lære winapi, og har begynnt å forstå litt...
Jeg bruker denne koden:
#include <windows.h>
/*  Declare Windows procedure  */
LRESULT CALLBACK WindowProcedure (HWND, UINT, WPARAM, LPARAM);
/*  Make the class name into a global variable  */
char szClassName[ ] = "WindowsApp";
int WINAPI WinMain (HINSTANCE hThisInstance,
				HINSTANCE hPrevInstance,
				LPSTR lpszArgument,
				int nFunsterStil)
HWND hwnd;			   /* This is the handle for our window */
MSG messages;			/* Here messages to the application are saved */
WNDCLASSEX wincl;		/* Data structure for the windowclass */
/* The Window structure */
wincl.hInstance = hThisInstance;
wincl.lpszClassName = szClassName;
wincl.lpfnWndProc = WindowProcedure;	  /* This function is called by windows */
wincl.style = CS_DBLCLKS;				 /* Catch double-clicks */
wincl.cbSize = sizeof (WNDCLASSEX);
/* Use default icon and mouse-pointer */
wincl.hIcon = LoadIcon (NULL, IDI_APPLICATION);
wincl.hIconSm = LoadIcon (NULL, IDI_APPLICATION);
wincl.hCursor = LoadCursor (NULL, IDC_ARROW);
wincl.lpszMenuName = NULL;				 /* No menu */
wincl.cbClsExtra = 0;					  /* No extra bytes after the window class */
wincl.cbWndExtra = 0;					  /* structure or the window instance */
/* Use Windows's default color as the background of the window */
wincl.hbrBackground = (HBRUSH) COLOR_BACKGROUND;
/* Register the window class, and if it fails quit the program */
if (!RegisterClassEx (&wincl))
	return 0;
/* The class is registered, let's create the program*/
[color="#FF0000"]void CreateToolTipForRect(HWND hwndParent)
// Create a ToolTip.
HWND hwndTT = CreateWindowEx(WS_EX_TOPMOST,
	TOOLTIPS_CLASS, NULL,
	WS_POPUP | TTS_NOPREFIX | TTS_ALWAYSTIP,
	CW_USEDEFAULT, CW_USEDEFAULT,
	hwndParent, NULL, g_hInst,NULL);
SetWindowPos(hwndTT, HWND_TOPMOST,
	0, 0, 0, 0,
	SWP_NOMOVE | SWP_NOSIZE | SWP_NOACTIVATE);
// Set up "tool" information.
// In this case, the "tool" is the entire parent window.
TOOLINFO ti = { 0 };
ti.cbSize = sizeof(TOOLINFO);
ti.uFlags = TTF_SUBCLASS;
ti.hwnd = hwndParent;
ti.hinst = g_hInst;
ti.lpszText = TEXT("This is your ToolTip string.");;
GetClientRect (hwndParent, &ti.rect);
// Associate the ToolTip with the "tool" window.
SendMessage(hwndTT, TTM_ADDTOOL, 0, (LPARAM) (LPTOOLINFO) &ti);
// Associate the ToolTip with the tool.
TOOLINFO toolInfo = { 0 };
toolInfo.cbSize = sizeof(toolInfo);
toolInfo.hwnd = hDlg;
toolInfo.uFlags = TTF_IDISHWND | TTF_SUBCLASS;
toolInfo.uId = (UINT_PTR)hwndTool;
toolInfo.lpszText = pText;
SendMessage(hwndTip, TTM_ADDTOOL, 0, (LPARAM)&toolInfo);
return TRUE;
}[/color]
/* Make the window visible on the screen */
ShowWindow (hwnd, nFunsterStil);
/* Run the message loop. It will run until GetMessage() returns 0 */
while (GetMessage (&messages, NULL, 0, 0))
	/* Translate virtual-key messages into character messages */
	TranslateMessage(&messages);
	/* Send message to WindowProcedure */
	DispatchMessage(&messages);
/* The program return-value is 0 - The value that PostQuitMessage() gave */
return messages.wParam;
/*  This function is called by the Windows function DispatchMessage()  */
LRESULT CALLBACK WindowProcedure (HWND hwnd, UINT message, WPARAM wParam, LPARAM lParam)
switch (message)				  /* handle the messages */
	case WM_DESTROY:
		PostQuitMessage (0);	   /* send a WM_QUIT to the message queue */
		break;
	default:					  /* for messages that we don't deal with */
		return DefWindowProc (hwnd, message, wParam, lParam);
return 0;
HWND hwndMain;
HWND hwndEdit;
char achTemp[256];	   // temporary buffer
LPSTR lpstrDict;		 // buffer for dictionary file
LPSTR *paLpDict;		 // array of pointers to words
UINT  cWords;			// number of words
Error:
Kompilator: Default compiler
Kjører  g++.exe...
g++.exe "C:\Documents and Settings\Ørjan\Mine dokumenter\c++\win\main.cpp" -o "C:\Documents and Settings\Ørjan\Mine dokumenter\c++\win\main.exe"	-I"C:\Dev-Cpp\lib\gcc\mingw32\3.4.2\include"  -I"C:\Dev-Cpp\include\c++\3.4.2\backward"  -I"C:\Dev-Cpp\include\c++\3.4.2\mingw32"  -I"C:\Dev-Cpp\include\c++\3.4.2"  -I"C:\Dev-Cpp\include"   -L"C:\Dev-Cpp\lib"
C:\Documents and Settings\Ørjan\Mine dokumenter\c++\win\main.cpp: In function `int WinMain(HINSTANCE__*, HINSTANCE__*, CHAR*, int)':
C:\Documents and Settings\Ørjan\Mine dokumenter\c++\win\main.cpp:42: error: a function-definition is not allowed here before '{' token
C:\Documents and Settings\Ørjan\Mine dokumenter\c++\win\main.cpp:42: error: expected `,' or `;' before '{' token
C:\Documents and Settings\Ørjan\Mine dokumenter\c++\win\main.cpp:70: error: `TOOLINFO' undeclared (first use this function)
C:\Documents and Settings\Ørjan\Mine dokumenter\c++\win\main.cpp:70: error: (Each undeclared identifier is reported only once for each function it appears in.)
C:\Documents and Settings\Ørjan\Mine dokumenter\c++\win\main.cpp:70: error: expected `;' before "toolInfo"
C:\Documents and Settings\Ørjan\Mine dokumenter\c++\win\main.cpp:71: error: `toolInfo' undeclared (first use this function)
C:\Documents and Settings\Ørjan\Mine dokumenter\c++\win\main.cpp:72: error: `hDlg' undeclared (first use this function)
C:\Documents and Settings\Ørjan\Mine dokumenter\c++\win\main.cpp:73: error: `TTF_IDISHWND' undeclared (first use this function)
C:\Documents and Settings\Ørjan\Mine dokumenter\c++\win\main.cpp:73: error: `TTF_SUBCLASS' undeclared (first use this function)
C:\Documents and Settings\Ørjan\Mine dokumenter\c++\win\main.cpp:74: error: `hwndTool' undeclared (first use this function)
C:\Documents and Settings\Ørjan\Mine dokumenter\c++\win\main.cpp:75: error: `pText' undeclared (first use this function)
C:\Documents and Settings\Ørjan\Mine dokumenter\c++\win\main.cpp:76: error: `hwndTip' undeclared (first use this function)
C:\Documents and Settings\Ørjan\Mine dokumenter\c++\win\main.cpp:76: error: `TTM_ADDTOOL' undeclared (first use this function)
C:\Documents and Settings\Ørjan\Mine dokumenter\c++\win\main.cpp: At global scope:
C:\Documents and Settings\Ørjan\Mine dokumenter\c++\win\main.cpp:83: error: expected constructor, destructor, or type conversion before '(' token
C:\Documents and Settings\Ørjan\Mine dokumenter\c++\win\main.cpp:83: error: expected `,' or `;' before '(' token
C:\Documents and Settings\Ørjan\Mine dokumenter\c++\win\main.cpp:86: error: expected unqualified-id before "while"
C:\Documents and Settings\Ørjan\Mine dokumenter\c++\win\main.cpp:86: error: expected `,' or `;' before "while"
C:\Documents and Settings\Ørjan\Mine dokumenter\c++\win\main.cpp:95: error: expected unqualified-id before "return"
C:\Documents and Settings\Ørjan\Mine dokumenter\c++\win\main.cpp:95: error: expected `,' or `;' before "return"
C:\Documents and Settings\Ørjan\Mine dokumenter\c++\win\main.cpp:96: error: expected declaration before '}' token
Kjøring avbrutt
Noen som vet hva som er galt?
Et tips er at når det dundrer inn med mange feil så prøv å fjern de du helt klart ser. Ofter får du flere syntax feil som henger sammen med andre feil.
f. eks variablene under er ikke erklært, dvs. at kompilatoren ikke har snøring på hva de er.
toolInfo
hDlg
pText
hwndTip
TTF_IDISHWND
TTF_SUBCLASS
TTM_ADDTOOL
Variabler som bare er store bokstaver er ofte constanter så de pleier å dukke opp hvis du googler de.
De andre har jeg ingen ide om hvor du har fra, men noen ser ut til å være handler til windows ting.
Du får tenke på det selv, men for meg kan det virke som om du går litt for fort fram med kodingen din.
Er dette berre noko du har copy/pasta?
Du sleit jo med å definere variablar/funksjonar for to dagar sidan... Ikkje det at eg har noko eg skulle sagt når det gjeld det (hehe..), men kanskje du skal lære deg meir standard-ting som OOP, funksjoner, pointers, og arrays før du går på dette? Og loops?
