Sony ericsson walkman telefoner
har 2 spørsmål!
1: jeg har en sony ericsson w580i
hvordan formaterer man helt? noen sier at det er å holde inn en knapp eller to men vet ikke x D
2:vet noen om en layout/theme/motiv som følger rytmen/bassen til musikken.. som denne
http://www.esato.com/logos/colour/w580themes.php?p=340
et eksempel..
Takk for svar
Vet ikke men mitt andre treff på google ga meg dette:
u're problem is the configuration of the operating system which is @!&%#. You'll have to format the internal memory. Don't worry, the operating system will re-install automatically. You'll loose all the contacts in you're agenda, all the messages, installed aplications, etc... The phone memory will be like in a new p900. Note that after this format, the only available language is english. There is NO way to undo the format. I recommand this as the last methode to save you're phone. You should go to a SE dealer first, maybe is another simpler way (that is if you have some document of ownership of the phone. If not, get ready for the ultimate restore-factory-default reset of the phone. This is NOT the master reset from the menu. First, eject the memory stick So access the service menu. Flip closed-mode: JogDial <Up> key <*> JogDial <down> JogDial <down> key <*> JogDial <down> key <*> Then service functions The phone will ask if you want to format Yes, Restart Yes Then it will probabily show an error, continue anyway. AFTER the process is complete and the phone is like new, restart the phone. Insert the memory stick Install Sman 1.3(free) (download http://renegade.w3xs.com/) Access the fn menu (upper right corner)-modules-file manager, access drive d: (memory card) and delete the system folder (this contains information about the installed programs and you don't need it anymore as the phone won't reconise previos installed programs, or will give errors. And you're done, the phone will work like new and you will have more space as a lot of temp and junk files (as support for chineese language) will be deleted.
Men på den andre siden så aner jeg ikke ;-P
har 2 spørsmål!
et eksempel..
Takk for svar
Takker ; D :thumbup: Men trenger mest det med det andre spm..x D hadde vært litt kult..
men motivet må lese av musikk..blir et problem det
