Når jeg er i CMD og skriver adprep /forestprep får jeg denne feilmelingen opp:
Adprep encountered a Win32 error.
Error code: 0x3a Error message: The Specified server cannot preform the requested operation.
Har googlet på dette i et parr timer. men er ikke mye svar og finne :/
Serveren er en windows 2003..
Legger til denne loggen ;)
Klikk for å se/fjerne innholdet nedenfor
Adprep created the log file ADPrep.log under C:\WINDOWS\system32\debug\adprep\logs\20080331102729 directory.
Adprep copied file D:\CMPNENTS\R2\ADPREP\schema.ini from installation point to local machine under directory C:\WINDOWS.
Adprep copied file D:\CMPNENTS\R2\ADPREP\sch31.ldf from installation point to local machine under directory C:\WINDOWS\system32.
Adprep copied file D:\CMPNENTS\R2\ADPREP\dcpromo.csv from installation point to local machine under directory C:\WINDOWS\system32\debug\adprep\data.
Adprep copied file D:\CMPNENTS\R2\ADPREP\409.csv from installation point to local machine under directory C:\WINDOWS\system32\debug\adprep\data.
Adprep successfully made the LDAP connection to the local domain controller ELEV2.
Adprep was about to call the following LDAP API. ldap_search_s(). The base entry to start the search is (null).
LDAP API ldap_search_s() finished, return code is 0x0
Adprep successfully retrieved information from the local directory service.
Adprep successfully initialized global variables.
[Status/Consequence]
Adprep is continuing.
ADPREP WARNING:
Before running adprep, all Windows 2000 domain controllers in the forest should be upgraded to Windows 2000 Service Pack 1 (SP1) with QFE 265089, or to Windows 2000 SP2 (or later).
QFE 265089 (included in Windows 2000 SP2 and later) is required to prevent potential domain controller corruption.
For more information about preparing your forest and domain see KB article Q331161 at [url="http://support.microsoft.com"]http://support.microsoft.com[/url].
[User Action]
If ALL your existing Windows 2000 domain controllers meet this requirement, type C and then press ENTER to continue. Otherwise, type any other key and press ENTER to quit.
Adprep was unable to check the forest update status.
Adprep queries the directory to see if the forest has already been prepared. If the information is unavailable or unknown, Adprep proceeds without attempting this operation.
[User Action]
Restart Adprep and check the Adprep.log file. Verify in the log file that this forest has already been successfully prepared.
Error code: 0x3a Error message: The specified server cannot perform the requested operation..
##la til kodeblokk og spoiler så det blir litt mer lesbart :) - enden##
Endret av enden
