Problemer med X
Gjorde nettopp en Debian nettinstallering, men kommer ikke inn i X.
Ved startx får jeg meldinga:
blablabla
(--)Assining device section with no busID to primary device
(EE) No devices detected
Fatal server error:
no screens found
blabla
XIO: fatal IO error 104 (connection reset by peer) on server ":0.0"
after 0 requests (0 known processed) with 0 events remaining.
Siden ting funka med Libranet, så reinstallerte jeg Libranet, kopierte XF86Config-4, kjørte ny nettinstallering, og prøvde med Libranets XF86Config-4. men uten at dette hjalp.
Jeg fikk også en melding om bug i kernel 2.4.20, ved installering av X, uten at jeg, desverre, finleste denne meldingen.
Er det en ide å installere kernel 2.4.19, som Libranet bruker?
Hva kan jeg gjøre?
Her er xfree-loggen:
This is a pre-release version of XFree86, and is not supported in any
way. Bugs may be reported to [email protected] and patches submitted
to [email protected]. Before reporting bugs in pre-release versions,
please check the latest version in the XFree86 CVS repository
(http://www.XFree86.Org/cvs)
XFree86 Version 4.1.0.1 / X Window System
(protocol Version 11, revision 0, vendor release 6510)
Release Date: 21 December 2001
If the server is older than 6-12 months, or if your card is
newer than the above date, look for a newer version before
reporting problems. (See http://www.XFree86.Org/FAQ)
Build Operating System: Linux 2.4.17 i686 [ELF]
Module Loader present
(==) Log file: "/var/log/XFree86.0.log", Time: Thu Feb 27 17:49:18 2003
(==) Using config file: "/etc/X11/XF86Config-4"
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) ServerLayout "Default Layout"
(**) |-->Screen "Default Screen" (0)
(**) | |-->Monitor "GSM:4a61"
(**) | |-->Device "nVidia Corporation NV17 [GeForce4 MX440]"
(**) |-->Input Device "Default Keyboard"
(**) Option "XkbRules" "xfree86"
(**) XKB: rules: "xfree86"
(**) Option "XkbModel" "pc104"
(**) XKB: model: "pc104"
(**) Option "XkbLayout" "us"
(**) XKB: layout: "us"
(==) Keyboard: CustomKeycode disabled
(**) |-->Input Device "Default Mouse"
(WW) The directory "/usr/lib/X11/fonts/cyrillic" does not exist.
Entry deleted from font path.
(WW) The directory "/usr/lib/X11/fonts/TrueType" does not exist.
(WW) The directory "/usr/share/fonts/truetype" does not exist.
(WW) The directory "/usr/share/fonts/truetype/openoffice" does not exist.
(**) FontPath set to "unix/:7100,/usr/lib/X11/fonts/misc,/usr/lib/X11/fonts/75dpi/:unscaled,/usr/lib/X11/fonts/Type1,/usr/lib/X11/fonts/Speedo,/usr/lib/X11/fonts/75dpi"
(==) RgbPath set to "/usr/X11R6/lib/X11/rgb"
(==) ModulePath set to "/usr/X11R6/lib/modules"
(--) using VT number 7
(WW) Cannot open APM
(II) Module ABI versions:
XFree86 ANSI C Emulation: 0.1
XFree86 Video Driver: 0.4
XFree86 XInput driver : 0.2
XFree86 Server Extension : 0.1
XFree86 Font Renderer : 0.2
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) Module bitmap: vendor="The XFree86 Project"
compiled for 4.1.0.1, module version = 1.0.0
Module class: XFree86 Font Renderer
ABI class: XFree86 Font Renderer, version 0.2
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/X11R6/lib/modules/libpcidata.a
(II) Module pcidata: vendor="The XFree86 Project"
compiled for 4.1.0.1, module version = 0.1.0
ABI class: XFree86 Video Driver, version 0.4
(II) PCI: Probing config type using method 1
(II) PCI: Config type is 1
(II) PCI: stages = 0x03, oldVal1 = 0x00000000, mode1Res1 = 0x80000000
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 1039,0648 card 1043,8086 rev 02 class 06,00,00 hdr 80
(II) PCI: 00:01:0: chip 1039,0001 card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:02:0: chip 1039,0963 card 0000,0000 rev 04 class 06,01,00 hdr 80
(II) PCI: 00:02:5: chip 1039,5513 card 1043,8087 rev 00 class 01,01,8a hdr 00
(II) PCI: 00:02:7: chip 1039,7012 card 1043,8096 rev a0 class 04,01,00 hdr 00
(II) PCI: 00:03:0: chip 1039,7001 card 1043,8087 rev 0f class 0c,03,10 hdr 80
(II) PCI: 00:03:1: chip 1039,7001 card 1043,8087 rev 0f class 0c,03,10 hdr 00
(II) PCI: 00:03:2: chip 1039,7001 card 1043,8087 rev 0f class 0c,03,10 hdr 00
(II) PCI: 00:03:3: chip 1039,7002 card 1043,8087 rev 00 class 0c,03,20 hdr 00
(II) PCI: 00:04:0: chip 1039,0900 card 1043,80a7 rev 91 class 02,00,00 hdr 00
(II) PCI: 00:09:0: chip 1412,1712 card 153b,1115 rev 02 class 04,01,00 hdr 00
(II) PCI: 00:0c:0: chip 10ec,8139 card 10ec,8139 rev 10 class 02,00,00 hdr 00
(II) PCI: 01:00:0: chip 10de,0171 card 10b0,0002 rev a3 class 03,00,00 hdr 00
(II) PCI: End of PCI scan
(II) LoadModule: "scanpci"
(II) Loading /usr/X11R6/lib/modules/libscanpci.a
(II) Module scanpci: vendor="The XFree86 Project"
(II) UnloadModule: "scanpci"
(II) Unloading /usr/X11R6/lib/modules/libscanpci.a
(II) Host-to-PCI bridge:
(II) PCI-to-ISA bridge:
(II) PCI-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (-1,0,0), BCTRL: 0x08 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX
(II) Bus 0 prefetchable memory range:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x08 (VGA_EN is set)
(II) Bus 1 I/O range:
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xe7000000 - 0xe7ffffff (0x1000000) MX
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xef700000 - 0xfebfffff (0xf500000) MX
(II) Bus -1: bridge is at (0:2:0), (0,-1,0), BCTRL: 0x08 (VGA_EN is set)
(II) Bus -1 I/O range:
(II) Bus -1 non-prefetchable memory range:
(II) Bus -1 prefetchable memory range:
(--) PCI:*(1:0:0) NVidia unknown chipset (0x0171) rev 163, Mem @ 0xe7000000/24, 0xf0000000/27, 0xef800000/19, BIOS @ 0xef7e0000/17
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX
(II) OS-reported resource ranges:
[0] -1 0 0xffe00000 - 0xffffffff (0x200000) MX(B)
[1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MXE(B)
[2] -1 0 0x000f0000 - 0x000fffff (0x10000) MX
[3] -1 0 0x000c0000 - 0x000effff (0x30000) MX
[4] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX
[5] -1 0 0x0000ffff - 0x0000ffff (0x1) IX
[6] -1 0 0x00000000 - 0x000000ff (0x100) IX
(II) Active PCI resource ranges:
[0] -1 0 0xe3800000 - 0xe38000ff (0x100) MX
[1] -1 0 0xe4000000 - 0xe4000fff (0x1000) MX
[2] -1 0 0xe4800000 - 0xe4800fff (0x1000) MX
[3] -1 0 0xe5000000 - 0xe5000fff (0x1000) MX
[4] -1 0 0xe5800000 - 0xe5800fff (0x1000) MX
[5] -1 0 0xe6000000 - 0xe6000fff (0x1000) MX
[6] -1 0 0xe8000000 - 0xebffffff (0x4000000) MX
[7] -1 0 0xef7e0000 - 0xef7fffff (0x20000) MX(B)
[8] -1 0 0xef800000 - 0xef87ffff (0x80000) MX(B)
[9] -1 0 0xf0000000 - 0xf7ffffff (0x8000000) MX(B)
[10] -1 0 0xe7000000 - 0xe7ffffff (0x1000000) MX(B)
[11] -1 0 0x00008000 - 0x000080ff (0x100) IX
[12] -1 0 0x00008400 - 0x0000843f (0x40) IX
[13] -1 0 0x00008800 - 0x0000880f (0x10) IX
[14] -1 0 0x00009000 - 0x0000900f (0x10) IX
[15] -1 0 0x00009400 - 0x0000941f (0x20) IX
[16] -1 0 0x00009800 - 0x000098ff (0x100) IX
[17] -1 0 0x0000a000 - 0x0000a07f (0x80) IX
[18] -1 0 0x0000a400 - 0x0000a4ff (0x100) IX
[19] -1 0 0x0000b400 - 0x0000b40f (0x10) IX
[20] -1 0 0x0000b800 - 0x0000b800 (0x1) IX
[21] -1 0 0x0000d000 - 0x0000d000 (0x1) IX
[22] -1 0 0x0000d400 - 0x0000d400 (0x1) IX
[23] -1 0 0x0000d800 - 0x0000d800 (0x1) IX
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[5] -1 0 0xe3800000 - 0xe38000ff (0x100) MX
[6] -1 0 0xe4000000 - 0xe4000fff (0x1000) MX
[7] -1 0 0xe4800000 - 0xe4800fff (0x1000) MX
[8] -1 0 0xe5000000 - 0xe5000fff (0x1000) MX
[9] -1 0 0xe5800000 - 0xe5800fff (0x1000) MX
[10] -1 0 0xe6000000 - 0xe6000fff (0x1000) MX
[11] -1 0 0xe8000000 - 0xebffffff (0x4000000) MX
[12] -1 0 0xef7e0000 - 0xef7fffff (0x20000) MX(B)
[13] -1 0 0xef800000 - 0xef87ffff (0x80000) MX(B)
[14] -1 0 0xf0000000 - 0xf7ffffff (0x8000000) MX(B)
[15] -1 0 0xe7000000 - 0xe7ffffff (0x1000000) MX(B)
[16] -1 0 0x0000ffff - 0x0000ffff (0x1) IX
[17] -1 0 0x00000000 - 0x000000ff (0x100) IX
[18] -1 0 0x00008000 - 0x000080ff (0x100) IX
[19] -1 0 0x00008400 - 0x0000843f (0x40) IX
[20] -1 0 0x00008800 - 0x0000880f (0x10) IX
[21] -1 0 0x00009000 - 0x0000900f (0x10) IX
[22] -1 0 0x00009400 - 0x0000941f (0x20) IX
[23] -1 0 0x00009800 - 0x000098ff (0x100) IX
[24] -1 0 0x0000a000 - 0x0000a07f (0x80) IX
[25] -1 0 0x0000a400 - 0x0000a4ff (0x100) IX
[26] -1 0 0x0000b400 - 0x0000b40f (0x10) IX
[27] -1 0 0x0000b800 - 0x0000b800 (0x1) IX
[28] -1 0 0x0000d000 - 0x0000d000 (0x1) IX
[29] -1 0 0x0000d400 - 0x0000d400 (0x1) IX
[30] -1 0 0x0000d800 - 0x0000d800 (0x1) IX
(II) LoadModule: "ddc"
(II) Loading /usr/X11R6/lib/modules/libddc.a
(II) Module ddc: vendor="The XFree86 Project"
(II) LoadModule: "GLcore"
(II) Loading /usr/X11R6/lib/modules/extensions/libGLcore.a
(II) Module GLcore: vendor="The XFree86 Project"
ABI class: XFree86 Server Extension, version 0.1
(II) LoadModule: "dbe"
(II) Loading /usr/X11R6/lib/modules/extensions/libdbe.a
(II) Module dbe: vendor="The XFree86 Project"
Module class: XFree86 Server Extension
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "dri"
(II) Loading /usr/X11R6/lib/modules/extensions/libdri.a
(II) Module dri: vendor="The XFree86 Project"
(II) Loading sub module "drm"
(II) LoadModule: "drm"
(II) Loading /usr/X11R6/lib/modules/linux/libdrm.a
(II) Module drm: vendor="The XFree86 Project"
(II) Loading extension XFree86-DRI
(II) LoadModule: "extmod"
(II) Loading /usr/X11R6/lib/modules/extensions/libextmod.a
(II) Module extmod: vendor="The XFree86 Project"
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension FontCache
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) LoadModule: "glx"
(II) Loading /usr/X11R6/lib/modules/extensions/libglx.a
(II) Module glx: vendor="The XFree86 Project"
(II) Loading sub module "GLcore"
(II) Reloading /usr/X11R6/lib/modules/extensions/libGLcore.a
(II) Loading extension GLX
(II) LoadModule: "record"
(II) Loading /usr/X11R6/lib/modules/extensions/librecord.a
(II) Module record: vendor="The XFree86 Project"
compiled for 4.1.0.1, module version = 1.13.0
(II) Loading extension RECORD
(II) Reloading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) LoadModule: "freetype"
(II) Loading /usr/X11R6/lib/modules/fonts/libfreetype.a
(II) Module freetype: vendor="The XFree86 Project"
compiled for 4.1.0.1, module version = 1.1.9
(II) Loading font FreeType
(II) LoadModule: "speedo"
(II) Loading /usr/X11R6/lib/modules/fonts/libspeedo.a
(II) Module speedo: vendor="The XFree86 Project"
(II) Loading font Speedo
(II) LoadModule: "type1"
(II) Loading /usr/X11R6/lib/modules/fonts/libtype1.a
(II) Module type1: vendor="The XFree86 Project"
(II) Loading font Type1
(II) Loading font CID
(II) LoadModule: "vbe"
(II) Loading /usr/X11R6/lib/modules/libvbe.a
(II) Module vbe: vendor="The XFree86 Project"
(II) LoadModule: "int10"
(II) Loading /usr/X11R6/lib/modules/linux/libint10.a
(II) Module int10: vendor="The XFree86 Project"
(II) LoadModule: "nv"
(II) Loading /usr/X11R6/lib/modules/drivers/nv_drv.o
(II) Module nv: vendor="The XFree86 Project"
compiled for 4.1.0.1, module version = 1.0.1
Module class: XFree86 Video Driver
(II) LoadModule: "mouse"
(II) Loading /usr/X11R6/lib/modules/input/mouse_drv.o
(II) Module mouse: vendor="The XFree86 Project"
Module class: XFree86 XInput Driver
ABI class: XFree86 XInput driver, version 0.2
(II) NV: driver for NVIDIA chipsets: RIVA128, RIVATNT, RIVATNT2,
RIVATNT2 (A), RIVATNT2 (B), RIVATNT2 (Ultra), RIVATNT2 (Vanta),
RIVATNT2 M64, RIVATNT2 (Integrated), GeForce 256, GeForce DDR,
Quadro, GeForce2 GTS, GeForce2 GTS (rev 1), GeForce2 ultra,
Quadro 2 Pro, GeForce2 MX, GeForce2 MX DDR, Quadro 2 MXR,
GeForce 2 Go, GeForce3, GeForce3 (rev 1), GeForce3 (rev 2),
GeForce3 (rev 3)
(II) Primary Device is: PCI 01:00:0
(--) Assigning device section with no busID to primary device
(EE) No devices detected.
Fatal server error:
no screens found
When reporting a problem related to a server crash, please send
the full server output, not just the last messages.
This can be found in the log file "/var/log/XFree86.0.log".
Please report problems to [email protected].
  • 4 måneder senere...
Hvorfor kan man ikke apt'e nyere versjoner av XFree? e.g. Den versjonen av XFree som er på apt er den der 4.1.0 fra desember 2001. -Det er ganske teit spør du meg...
Du kan bare apte programmer som er 110% stabile om du kjører stable...
Det er nok ikke helt riktig. Du kan legge til uoffisielle apt-kilder i sources.list. Enkelte kilder er veldig greie; XFree86 4.3, KDE 3.1, osv.
