Harddisker forsvunnet etter oppgradering av Ubuntu
Jeg oppgraderte Ubuntuserveren min i går fra 6.06 > 6.10 > 7.04 > 7.10
Etter dette forsvant diskene mine.
Om jeg prøver og gå inn på /dev og skrive ls kommer ingen av harddiskene opp.
Under /media ligger alle harddiskene min, men alle er tomme
cat /etc/fstab gir:
# /etc/fstab: static file system information.
# <file system> <mount point> <type> <options> <dump> <pass>
proc /proc proc defaults 0 0
# /dev/sda1 -- converted during upgrade to edgy
UUID=2bc99400-0167-4224-b9c6-1881dde7410f / ext3 defaults,errors=remount-ro 0 1
# /dev/sda6 -- converted during upgrade to edgy
UUID=9039df3a-f41e-4581-a129-06894696639d /boot ext3 defaults 0 2
# /dev/hda1 -- converted during upgrade to edgy
UUID=2ea82230-80ab-425a-a7d1-f8212c5e5434 /media/hda1 ext3 defaults 0 2
# /dev/sdb1 -- converted during upgrade to edgy
UUID=f1f976d3-a536-4c3d-ad56-f67fff1f4876 /media/sdb1 ext3 defaults 0 2
# /dev/sdc1 -- converted during upgrade to edgy
UUID=b1ebd68c-da00-4849-b1fe-0dd89665f9fb /media/sdc1 ext3 defaults 0 2
# /dev/sdd1 -- converted during upgrade to edgy
UUID=8d42fafd-5776-427a-a701-68299341de14 /media/sdd1 ext3 defaults 0 2
# /dev/sda5 -- converted during upgrade to edgy
UUID=7f289114-226b-41b3-a92c-cca1576b0ac6 none swap sw 0 0
/dev/hdb /media/cdrom0 udf,iso9660 user,noauto 0 0
sudo fdisk -l gir
Disk /dev/hda: 300.0 GB, 300090728448 bytes
255 heads, 63 sectors/track, 36483 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk identifier: 0xb20d1442
Device Boot Start End Blocks Id System
/dev/hda1 1 36483 293049666 83 Linux
Disk /dev/sda: 37.0 GB, 37019566080 bytes
255 heads, 63 sectors/track, 4500 cylinders
Disk identifier: 0x007a007a
/dev/sda1 * 1 4012 32226358+ 83 Linux
/dev/sda2 4013 4500 3919860 5 Extended
/dev/sda5 4013 4377 2931831 82 Linux swap / Solaris
/dev/sda6 4378 4500 987966 83 Linux
Disk /dev/sdb: 500.1 GB, 500107862016 bytes
255 heads, 63 sectors/track, 60801 cylinders
Disk identifier: 0x0009104b
/dev/sdb1 * 1 60801 488384001 83 Linux
Disk /dev/sdc: 320.0 GB, 320072933376 bytes
255 heads, 63 sectors/track, 38913 cylinders
Disk identifier: 0x62ab445f
/dev/sdc1 1 38913 312568641 83 Linux
Disk /dev/sdd: 250.0 GB, 250059350016 bytes
255 heads, 63 sectors/track, 30401 cylinders
Disk identifier: 0xf3224c96
/dev/sdd1 1 30401 244196001 83 Linux
