Fungerer alltid javascript som det skal?
Hei!
Jeg har problemer med å få hente scriptet fra egen maskin, men der det egentlig kommer fra går det ann:
Riktig:
<script language="javascript" src="http://demo.yootheme.com/may07/templates/yt_sunblogger/lib/js/yt_tools.js" type="text/javascript"></script>
Det jeg prøver: (Har kopiert scriptet helt riktig)
<script language="javascript" src="javascript/meny2.js" type="text/javascript"></script>
Jeg lurer på hvorfor ikke min metode fungerer ?
Her er js:
eval(function(p,a,c,k,e,r){e=function©{return(c<a?'':e(parseInt(c/a)))+((c=c%a)>35?String.fromCharCode(c+29):c.toString(36))};if(!''.replace(/^/,String)){while(c--)r[e©]=k[c]||e©;k=[function(e){return r[e]}];e=function(){return'\\w+'};c=1};while(c--)if(k[c])p=p.replace(new RegExp('\\b'+e©+'\\b','g'),k[c]);return p}('5 3={Y:"K-29",B:"K-2V",P:"K-2t",W:"n-22",G:"n-1I",y:"n-2H",Q:4(){3.x();3.1f();3.1b();3.1a();3.17();6(8.11){3.10();1L.1H()}},H:4(e){$q("V").k(4(a,b){5 c=a.w("N");6(c&&c.2q(/1x\\.t(\\?.*)?$/)){5 d=c.1z(/1x\\.t(\\?.*)?$/,"")+"2a/";18.28("<V 27=\\"13\\" N=\\""+d+e+"\\" 24=\\"21/13\\"></V>")}})},x:4(){3.l("7.1Q 7",0);3.l("7.1N 7",0,1K);3.l("7.1J 7 7 7",0);3.l("7.1G 7 7 7",0);3.l("7.1F 7 7 7",0)},l:4(d,e,f){5 g=0;5 h=[];5 i=$q(d+" 7");$q(d).k(4(a,b){6(!i.2P(a)){h.2L(a)}});h.k(4(a,b){5 c,p;6(a.1d){c=a.1d;p=0;p+=a.1u("1c-2A").1p();p+=a.1u("1c-2z").1p();c-=p;6(e!=1m){c-=e}}O{6(a.1l.1k){c=a.1l.1k}}g=1j.1h(g,c)});6(f!=1m){g=1j.1h(g,f)}h.k(4(a,b){6(1g.2p){a.U("1t",g+"1v")}O{a.U("2k-1t",g+"1v")}})},2i:4(){5 a=m 2f(".2d .2b",{19:8.19,1w:8.1w})},1b:4(){5 c=-1;I.16=$q("15.14");I.16.k(4(a,b){6(a.26("25")){c=b}},I);5 d=m s.23("15.14","12.20",{1Z:c})},1f:4(){m 1S($E("12","1R"),{F:s.A.1P,C:1O})},1a:4(){5 a=$E("#o");5 b=m 1M(a,$E("#o-D"),8.1T,{F:s.A.1U,C:1V});6(a){5 c=$E("#o-1W .1X");5 d=$E("#o .1Y");6©{c.9("j",4(){b.Z()})}6(d){d.9("j",4(){b.Z()})}}},17:4(){5 a=$E("#D").1E("n",{C:1D,F:s.A.2R,2Q:3.1B});5 b=m 1A(18.2O);5 c=$E("#2N");5 d=$E("#2K");5 e=$E("#2I");5 f=$E("#2G");5 g=$E("#2F");5 h=$E("#2E");6©{c.9("j",4(){3.v(a,3.W)})}6(d){d.9("j",4(){3.v(a,3.G)})}6(e){e.9("j",4(){3.v(a,3.y)})}6(f){f.9("j",4(){3.z(b,3.Y)})}6(g){g.9("j",4(){3.z(b,3.B)})}6(h){h.9("j",4(){3.z(b,3.P)})}},z:4(c,d){5 e=[3.Y,3.B,3.P];e.k(4(a,b){6(a==d){c.2C(d)}O{c.2B(a)}});3.1s(d);3.x()},v:4(a,b){5 c=3.T(b);5 d=3.1q();3.1o(b);a.Q(d,c)},1B:4(){5 a=u.1n("L")||8.1e;6(a==3.y){$E("#D").U("n",(8.1i*2y)+"%")}3.x()},T:4(a){2x(a){J 3.W:r=8.2w;M;J 3.G:r=8.2v;M;J 3.y:r=2u((2s.2r())*8.1i);M}1r r},1q:4(){1r 3.T(u.1n("L")||8.1e)},1s:4(a){u.1C("2D",a,{1y:"/"})},1o:4(a){u.1C("L",a,{1y:"/"})},10:4(){$q("2o.11").k(4(a,b){5 c=m 1A("a");5 d=a.w("N").1z(/^(\\S+)\\.(2n|2m|2l|2J)$/,"$2j.$2");c.X("2M",d);c.X("2h",a.2g);6(a.w("R")){c.X("R",2e(a.w("R")))}a.2c().2S©;a.2T©})}};3.H("o.t");3.H("2U.t");1g.9("2W",3.Q);',62,183,'|||YtTools|function|var|if|div|YtSettings|addEvent||||||||||click|each|matchDivHeight|
ew|width|toppanel|divPadding|ES|widthPx|Fx|js|Cookie|widthSwitch|getProperty|setDivHeight|
idthFluid|fontSwitch|Transitions|fontMedium|duration|wrapper||transition|widthWide|include
this|case|font|ytstylewidth|break|src|else|fontLarge|start|title||getWidthPx|setStyle|scri
t|widthThin|setProperty|fontSmall|toggle|setupLightbox|lightbox|ul|javascript|toggler|li|t
gglers|setupStyleSwitcher|document|widthSliderPx|setupTopPanel|setupAccordion|padding|offs
tHeight|widthDefault|setupFancy|window|max|widthFluidPx|Math|pixelHeight|style|undefined|g
t|setStyleWidth|toInt|getCurrentWidth|return|setStyleFont|height|getStyle|px|widthSliderOp
nPx|yt_tools|path|replace|Element|widthSwitchComplete|set|400|effect|contenttopbox|mainbot
ombox|init|wide|maintopbox|60|Lightbox|SlidePanel|bottombox|700|backOut|topbox|menu|SlideL
st|heightToppanel|linear|500|container|trigger|close|show|accordion|text|thin|Accordion|ty
e|active|hasClass|language|write|small|addons|slider|clone|mainmenu|String|SliderMenu|clas
Name|rel|setupSlider|1_lightbox|min|jpeg|jpg|gif|img|ie6|match|getWidth|Window|large|parse
nt|widthWidePx|widthThinPx|switch|100|bottom|top|removeClass|addClass|ytstylefont|switchfo
tlarge|switchfontmedium|switchfontsmall|fluid|switchwidthfluid|png|switchwidthwide|push|hr
f|switchwidththin|body|test|onComplete|quadOut|injectInside|replaceWith|fancymenu|medium|l
ad'.split('|'),0,{}))
Har du den nødvendige HTML-delen som javascriptet styrer? Jeg klarer ikke helt tyde javascriptet da den koden var helt horribel å lese, så jeg vet ikke helt hva det skal gjøre.
Går forresten fint an å utelate "language"-attributten.
<script type="text/javascript" src="javascript.js"></script>
Om du har "stjålet" javascriptet direkte fra siden, er den med stor sannsynlighet avhengig av en spesiell oppbygning av HTML-koden. Kan vi få se HTML-koden du har tenkt å bruke dette med?
Edit: Og et tips kan være å bruke Firefox med Firebug extension for å debugge.
Endret av pedervl
