Slå av datamaskinen med Visual Basic
Denne koden vil skru av Pcen
Declare Function ExitWindows Lib "user32" (ByVal dwReserved As Long, ByVal uReturnCode As Long) As Long
Public Const EWX_FORCE = 4
Public Const EWX_LOGOFF = 0
Public Const EWX_REBOOT = 2
Public Const EWX_SHUTDOWN = 1
Private Sub Form1_Load()
ExitWindowsEx EWX_FORCE, 0
End Sub
Denne coden vil restarte PCen
ExitWindowsEx EWX_REBOOT, 0
End Sub
Denne vil logge av pålogget bruker
ExitWindowsEx EWX_LOGOFF, 0
End Sub
  • 1 måned senere...
For å kunne slå av pcen i Xp eller NT må du skrive inn dette i programmet ditt:
' API-calls
Private Declare Function GetCurrentProcess Lib "kernel32" () As Long
Private Declare Function OpenProcessToken Lib "advapi32" (ByVal ProcessHandle As Long, ByVal DesiredAccess As Long, TokenHandle As Long) As Long
Private Declare Function LookupPrivilegeValue Lib "advapi32" Alias "LookupPrivilegeValueA" (ByVal lpSystemName As String, ByVal lpName As String, lpLuid As LUID) As Long
Private Declare Function AdjustTokenPrivileges Lib "advapi32" (ByVal TokenHandle As Long, ByVal DisableAllPrivileges As Long, NewState As TOKEN_PRIVILEGES, ByVal BufferLength As Long, PreviousState As TOKEN_PRIVILEGES, ReturnLength As Long) As Long
Private Declare Function ExitWindowsEx Lib "user32" (ByVal uFlags As Long, ByVal dwReserved As Long) As Long
Private Declare Function GetVersionEx Lib "kernel32" Alias "GetVersionExA" (ByRef lpVersionInformation As OSVERSIONINFO) As Long
Private Const EWX_LOGOFF = 0
Private Const EWX_SHUTDOWN = 1
Private Const EWX_REBOOT = 2
Private Const EWX_FORCE = 4
Private Const TOKEN_ADJUST_PRIVILEGES = &H20
Private Const TOKEN_QUERY = &H8
Private Const SE_PRIVILEGE_ENABLED = &H2
Private Const ANYSIZE_ARRAY = 1
Private Const VER_PLATFORM_WIN32_NT = 2
Type OSVERSIONINFO
dwOSVersionInfoSize As Long
dwMajorVersion As Long
dwMinorVersion As Long
dwBuildNumber As Long
dwPlatformId As Long
szCSDVersion As String * 128
End Type
Type LUID
LowPart As Long
HighPart As Long
End Type
Type LUID_AND_ATTRIBUTES
pLuid As LUID
Attributes As Long
End Type
Type TOKEN_PRIVILEGES
PrivilegeCount As Long
Privileges(ANYSIZE_ARRAY) As LUID_AND_ATTRIBUTES
End Type
' Sjekker om oprativsystemet er XP eller NT
Public Function IsWinNT() As Boolean
Dim myOS As OSVERSIONINFO
myOS.dwOSVersionInfoSize = Len(myOS)
GetVersionEx myOS
IsWinNT = (myOS.dwPlatformId = VER_PLATFORM_WIN32_NT)
End Function
' Gir programmet ditt rettigheter til å slå av pcen
Private Sub EnableShutDown()
Dim hProc As Long
Dim hToken As Long
Dim mLUID As LUID
Dim mPriv As TOKEN_PRIVILEGES
Dim mNewPriv As TOKEN_PRIVILEGES
hProc = GetCurrentProcess()
OpenProcessToken hProc, TOKEN_ADJUST_PRIVILEGES + TOKEN_QUERY, hToken
LookupPrivilegeValue "", "SeShutdownPrivilege", mLUID
mPriv.PrivilegeCount = 1
mPriv.Privileges(0).Attributes = SE_PRIVILEGE_ENABLED
mPriv.Privileges(0).pLuid = mLUID
AdjustTokenPrivileges hToken, False, mPriv, 4 + (12 * mPriv.PrivilegeCount), mNewPriv, 4 + (12 * mNewPriv.PrivilegeCount)
End Sub
Private Sub Form_Load()
If IsWinNT Then EnableShutDown
End Sub
Så kan du bruke kodene i siste innlegg
  • 2 uker senere...
