COD4 PS3 hack demonstration
trydis
Det står jo rett under videoen hvordan du kan gjøre det, så er jo lett å bekrefte/avkrefte det om du vil ;)
How To:
Copy your gamesave to a thumbdrive/external hdd. Connect it to your computer. Go to: YOURDRIVE/PS3/SAVEDATA/BLUS30072-AUTO-
Open GPAD0CM with any text editor, add the following to the bottom:
set pHaezHack0 "set compassSize 1.5;set compassMaxRange 6500;set compassRadarLineThickness 0;set compassRadarPingFadeTime 0;set compassSoundPingFadeTime 0;set player_burstFireCooldown 0;set g_speed 1250;set player_view_pitch_up 90;set player_sprintTime 99;set player_sustainAmmo 1;set player_breath_hold_time 60;set g_gravity 150;set phys_gravity -200;set jump_height 225"
vstr pHaezHack0
Then open GPAD0MP with any text editor, and the following to the bottom:
set pHaezHack1 "set aim_lockon_debug 1;set aim_lockon_region_height 0;set aim_lockon_region_width 1386;set aim_lockon_strength 0.99;set aim_lockon_deflection 0.0005;set cg_tracerchance 1;set cg_tracerlength 5000;set cg_tracerSpeed 750;set cg_tracerwidth 4;set cg_drawShellshock 0;set compassRadarUpdateTime 0.001;set cg_enemyNameFadeIn 0;set cg_enemyNameFadeOut 900000;set cg_drawThroughWalls 1;set compassEnemyFootstepEnabled 1;set compassEnemyFootstepMaxRange 99999;set compassEnemyFootstepMaxZ 99999;set compassEnemyFootstepMinSpeed 0"
vstr pHaezHack1
Save both, plug the drive into your PS3, and copy the save from your drive, overwriting your current gamesave. Start the game, and enjoy.
I didn't want to let this out, but somebody else figured out how I did it, and told people on nextgenboard how to do it, so no harm in giving it away anymore. Hopefully it will just speed up IW's patching the issue. I told them weeks ago how it was done, and how to fix the issue. It is in their hands now.
Endret av trydis
Hmm, javel..
Men hvis det plutselig skulle komme en patch som fikset dette, hva ville skje med gamesave filen da:S?
Kunne jo kanskje sendt en mail med videoen+forklaring på hvordan de hacker til for eksempel IW?
Eller fourzerotwo som gir ut diverse nyheter fra IW.
Leste litt på det offisielle forumet og det virker som det funker. Håper patchen som kom i dag gjør det umulig å spille med redigerte saves ... hvis ikke er det ikke noe vits å spille COD4 lenger.
Endret av shaker
Ja hvis det som står på COD4 forumet er sant er det mulig å få seg automatgranatkaster med uendelig ammo (og bøtter med andre cheats) :wallbash:
Ifølge forum rundt så er dette alerede fikset i den nye patchen, har selv ikke lagt merke til noen som cheater (har den nye patchen)
