CM Cosmos 1000 og Cosmos S
hmm etter å ha lest følgende om S versjonen tror jeg den utgår:
Once installing all of the hardware and powering up the system, the chassis was a bit loud. Most of the noise can be attributed to the two Dynatron LGA-771 heatsink fans, but with the extensive use of mesh in the system, the three 120mm fans, and one 200mm fan, this system had operated louder than when in a different aluminum EATX chassis. It wasn't much louder, but still noticeable.
