Sokkalf™ Skrevet 13. mars 2008 Del Skrevet 13. mars 2008 (endret) Får hver dag flere tusen mislykkede innloggingsforsøk med ssh i auth.log.. slik som dette: Klikk for å se/fjerne innholdet nedenfor Mar 13 06:27:06 archaic sshd[18636]: Invalid user pc06 from 124.192.3.248 Mar 13 06:27:10 archaic sshd[18638]: Invalid user pc07 from 124.192.3.248 Mar 13 06:27:15 archaic sshd[18640]: Invalid user pc08 from 124.192.3.248 Mar 13 06:27:20 archaic sshd[18643]: Invalid user pc09 from 124.192.3.248 Mar 13 06:27:25 archaic sshd[18645]: Invalid user pc10 from 124.192.3.248 Mar 13 06:27:30 archaic sshd[18647]: Invalid user pc11 from 124.192.3.248 Mar 13 06:27:36 archaic sshd[18649]: Invalid user pc12 from 124.192.3.248 Mar 13 06:27:41 archaic sshd[18651]: Invalid user pc13 from 124.192.3.248 Mar 13 06:27:46 archaic sshd[18653]: Invalid user pc14 from 124.192.3.248 Mar 13 06:27:51 archaic sshd[18655]: Invalid user pc15 from 124.192.3.248 Mar 13 06:27:56 archaic sshd[18657]: Invalid user pc16 from 124.192.3.248 Mar 13 06:28:01 archaic sshd[18659]: Invalid user pc17 from 124.192.3.248 Mar 13 06:28:05 archaic sshd[18661]: Invalid user pc18 from 124.192.3.248 Mar 13 06:28:10 archaic sshd[18663]: Invalid user pc19 from 124.192.3.248 Mar 13 06:28:15 archaic sshd[18665]: Invalid user pc20 from 124.192.3.248 Mar 13 06:28:20 archaic sshd[18667]: Invalid user sms from 124.192.3.248 Mar 13 06:28:25 archaic sshd[18669]: Invalid user smf from 124.192.3.248 Mar 13 06:28:29 archaic sshd[18671]: Invalid user svf from 124.192.3.248 Mar 13 06:28:40 archaic sshd[18673]: Invalid user stf from 124.192.3.248 De kommer aldri inn uansett, jeg har bra nok sikkerhet, men er litt lei av loggfiler som blir enorme. Er det noen måte å konfigurere systemet på så den evt. blacklister hosts etter et gitt antall mislykkede innloggingsforsøk? Endret 13. mars 2008 av Sokkalf^ Lenke til kommentar
-Logos- Skrevet 13. mars 2008 Del Skrevet 13. mars 2008 (endret) Jeg bruker: denyhosts - an utility to help sys admins thwart ssh hackers Den tar automatisk 3 feilede påloggingsforsøk og legger i hosts.deny. Foreløpig har den kun hatt jobben med å stenge ute meg selv når jeg har skrevet brukernavn og passord feil for mange ganger... Det er ikke en direkte konfigurasjon da man legger inn noe nytt,,, men skal gjøre jobben:) Endret 13. mars 2008 av mariunae Lenke til kommentar
Sokkalf™ Skrevet 13. mars 2008 Forfatter Del Skrevet 13. mars 2008 Takker! Den skal sjekkes ut. Lenke til kommentar
Sokkalf™ Skrevet 13. mars 2008 Forfatter Del Skrevet 13. mars 2008 Det funket glimrende, allerede 3 hosts som er lagt inn i hosts.deny ser jeg. Takk igjen Lenke til kommentar
serrghi Skrevet 13. mars 2008 Del Skrevet 13. mars 2008 Takker og for denne, har slitt med samme problem. Jævla kidz som skal leke über hakk0r. Lenke til kommentar
Richard87 Skrevet 31. mars 2008 Del Skrevet 31. mars 2008 Hei, Prøv og skift porten til 222 eller noe, stopper 99% av script kiddies;) Lenke til kommentar
Torbjørn Skrevet 31. mars 2008 Del Skrevet 31. mars 2008 Å bytte port er en overlegent god løsning, husk at du kan konfigurere ssh klienten på brukernivå til å bruke forskjellig port til forskjellige servere, dvs du vil ikke merke noen forskjell hos deg selv selvom du bytter port Lenke til kommentar
Del Skrevet 31. mars 2008 Del Skrevet 31. mars 2008 Skifte av port funker finfint, ellers kan du disable passord (skrev litt om det i howto'en). Lenke til kommentar
Sokkalf™ Skrevet 31. mars 2008 Forfatter Del Skrevet 31. mars 2008 Har kjørt public key auth lenge, så at noen skulle komme inn har jeg ikke vært særlig bekymret for. mariunaes løsning har forøvrig fungert strålende, så noen ytterligere tiltak ser jeg ikke som nødvendig. Tviler ikke på at bytte av port tar de aller aller fleste, men det stopper bare de automatiske angrepene fra bots etc. Sitter det noen der som er bestemt på å komme seg inn, tar det ikke lange tiden før han/hun finner ut hvilken port du kjører ssh på. Da er det viktig å sørge for at man har sikkerheten ivaretatt, og ikke kun kjøper seg falsk trygghet ved å tro at portbytte stopper alle. Lenke til kommentar
arnizzz Skrevet 1. april 2008 Del Skrevet 1. april 2008 Port-knocking er jo også et alternativ. Bruker det selv på noen maskiner og funker fint det. Lenke til kommentar
Torbjørn Skrevet 1. april 2008 Del Skrevet 1. april 2008 Har kjørt public key auth lenge, så at noen skulle komme inn har jeg ikke vært særlig bekymret for. mariunaes løsning har forøvrig fungert strålende, så noen ytterligere tiltak ser jeg ikke som nødvendig. Tviler ikke på at bytte av port tar de aller aller fleste, men det stopper bare de automatiske angrepene fra bots etc. Sitter det noen der som er bestemt på å komme seg inn, tar det ikke lange tiden før han/hun finner ut hvilken port du kjører ssh på. Da er det viktig å sørge for at man har sikkerheten ivaretatt, og ikke kun kjøper seg falsk trygghet ved å tro at portbytte stopper alle. Vel i ditt spørsmål snakker du nettopp om disse streif login forsøkene. Det er sjelden disse ipene kommer tilbake igjen, (slik at denyhosts får noen virkning) Lenke til kommentar
Sokkalf™ Skrevet 1. april 2008 Forfatter Del Skrevet 1. april 2008 Klart, jeg hadde sikkerheten på plass og var jo i bunn og grunn ikke bekymret for dem. Alt jeg lette etter var noe som ble kvitt all spamen i loggene (var jo umulig å lete etter reelle situasjoner pga at man måtte vasse gjennom titusenvis av linjer med tull), og det tok denyhosts seg av. Bytte av port hadde funket fint det og, men jeg er såpass lat at jeg ikke gidder ekstraarbeidet med å konfigurere en haug med klienter til å bruke riktig port. Lenke til kommentar
Torbjørn Skrevet 2. april 2008 Del Skrevet 2. april 2008 (endret) Jeg mener ikke å flisespikke, men hvis 10-20 ip'er hver får 3 forsøk hver periode (el. lignende gjennom denyhosst), vil det fortsatt bli tilsvarende mange entries i loggen, i tillegg til de entries som er lovlige (fra dine klienter) Min erfaring fra når jeg brukte deny.hosts , var at samme IP sjelden kom tilbake for å prøve igjen. Du kan enkelt kjøre sshd på 2 porter, en på 22 og en på annet.tall.her , og tillate kun dine klienter på port 22 og den.andre.porten for resten av verden EDIT: småtterier Endret 2. april 2008 av Torbjørn Lenke til kommentar
Sokkalf™ Skrevet 2. april 2008 Forfatter Del Skrevet 2. april 2008 3 forsøk hver blir 3 entries i loggen. Det er en enorm forbedring fra de tusentalls entries jeg hadde fra enkelte IPer før. Nå har jeg ~450 entries i loggen per dag. Før hadde jeg mellom 15000 og 20000 entries i loggen per dag. Denyhosts har dermed hjulpet betraktelig for meg, uten noen ekstra config av ssh overhodet. Jeg anser det dermed som den beste løsningen (for meg!). Lenke til kommentar
Torbjørn Skrevet 2. april 2008 Del Skrevet 2. april 2008 Jeg snakker om portendring i tillegg Du vil få 3 oppføringer per uønsket ip, med f.eks 10-20 uønskede ip'er om dagen er det 60 oppføringer, jeg syns fortsatt det er spam i loggen, var bare det jeg ville si. Lenke til kommentar
Langbein Skrevet 2. april 2008 Del Skrevet 2. april 2008 (endret) Tviler ikke på at bytte av port tar de aller aller fleste, men det stopper bare de automatiske angrepene fra bots etc. Sitter det noen der som er bestemt på å komme seg inn, tar det ikke lange tiden før han/hun finner ut hvilken port du kjører ssh på. Da er det viktig å sørge for at man har sikkerheten ivaretatt, og ikke kun kjøper seg falsk trygghet ved å tro at portbytte stopper alle. Det er sant, men i løpet av alle årene jeg har kjørt SSH-server på non-standard port, har jeg aldri opplevd et eneste innbruddsforsøk. Dette i skarp kontrast til alle forsøkene på ymse brukernavn/passord-kombinasjoner som har vært testet mot port 22. Det skal litt til før noen gidder å portscanne alle 65536 portene på en tilfeldig maskin, så da må det nesten være noen som kjenner deg og har et spesielt ønske om å bryte seg inn på akkurat DIN server. Eller at du jobber i Pentagon, NSA osv. Men såklart, man skal ikke basere sikkerheten alene på dette. Er også viktig med oppdatert programvare og gode passord (evt. RSA/DSA keys) Endret 2. april 2008 av Langbein Lenke til kommentar
