UrgeLoL Skrevet 12. mars 2008 Rapporter Del Skrevet 12. mars 2008 Ser gjerne at de lager ett nytt max payne spill da jeg likte det forrige. Washington (dbTechno) - Sources are stating that Rockstar is currently working on a new Max Payne for release in 2009 on the Xbox 360 and PS3. This would likely launch alongside with the launch of the movie, which stars Mark Walhberg. Take-Two had a conference call to investors yesterday, stating that once Rockstar finishes up on GTA IV, they are moving on to release a sequel to another big franchise for release in 2009. Many have been speculating what exactly this sequel could be, with ideas pointing towards a new Bully, Manhunt, or something else. It appears that the new franchise entry they are talking about will be a new Max Payne game. Max Payne gained a lot of attention as a franchise, releasing originally on the PC and then on the PS2 and Xbox. The game is already being made into a huge Hollywood movie, starring Mark Wahlberg, which will also release in 2009. It appears that Rockstar is getting a new entry into the Max Payne series ready to coincide with the release of the movie, even though it will likely have a different story. Kilde Lenke til kommentar
Bear^ Skrevet 12. mars 2008 Rapporter Del Skrevet 12. mars 2008 Dette håper jeg stemmer, Max Payne er et av de spillene jeg likte aller mest grunnet en kjempefin balanse av action og historie. Stemmer dette skal jeg investere i det med en gang. Lenke til kommentar
Erlendz Skrevet 12. mars 2008 Rapporter Del Skrevet 12. mars 2008 Det hadde vært topp! Lenke til kommentar
Erasus Skrevet 12. mars 2008 Rapporter Del Skrevet 12. mars 2008 Sinnsykt gode nyheter! Dette her blir forhåpentligvis storartet! Lenke til kommentar
Gjest Slettet+981234789 Skrevet 12. mars 2008 Rapporter Del Skrevet 12. mars 2008 Rockstar lager Max Payne?! høres litt merklig ut... Lenke til kommentar
Licht Skrevet 12. mars 2008 Rapporter Del Skrevet 12. mars 2008 Konsoll-eksklusiv? Ugh. Lenke til kommentar
Erasus Skrevet 12. mars 2008 Rapporter Del Skrevet 12. mars 2008 Vel tjaaa, jeg har troen på at de kommer til å gjøre en utmerket jobb. Rockstar er ikke kjent for å skuffe akkurat, men jeg håper inderlig at Max Payne 3 vil komme ut til PC i tillegg. Lenke til kommentar
Bear^ Skrevet 12. mars 2008 Rapporter Del Skrevet 12. mars 2008 Ja når du sier det så høres det litt rart ut, er jo Remedy som innehaver rettighetene til Max Payne, men Rockstar Torronto og andre Rockstar kontorer har vært innom med å utvikle andre versjoner, samt at Rockstar ga ut Max Payne spillene i sin tid. Lenke til kommentar
Zeph Skrevet 12. mars 2008 Rapporter Del Skrevet 12. mars 2008 Max Payne på Xbox 360 hadde vore elsk. MP-spela er noko av det beste eg har vore borti av den type spel på PC. Gameplayet, historien, teikneseriesidene med kommentarer til og ikkje minst den råtøffe stemma til Max. Lenke til kommentar
Bozzeye Skrevet 12. mars 2008 Rapporter Del Skrevet 12. mars 2008 Har kun spilt litt Max Payne til PS2, og sett en del på når en annen fyr spilte. Etter det jeg husker var det gøy, derfor blir det nok noe jeg kommer til å følge med på. Lenke til kommentar
Gjest Slettet-NIoHlfL Skrevet 12. mars 2008 Rapporter Del Skrevet 12. mars 2008 (endret) Ja når du sier det så høres det litt rart ut, er jo Remedy som innehaver rettighetene til Max Payne, men Rockstar Torronto og andre Rockstar kontorer har vært innom med å utvikle andre versjoner, samt at Rockstar ga ut Max Payne spillene i sin tid. Remedy solgte rettighetene allerede i 2002 til Take-2. Remedy fikk likevel utvikle oppfølgeren, men det er nok trolig helt opp til Take-2 selv å avgjøre hvem som skal utvikle 3'ern. Tror neppe det blir Remedy, de har ikke kapasitet til å utvikle mer enn et spill om gangen, og er nå opptatt med Alan Wake. Max Payne 3 ble for øvrig annonsert i 2004... Endret 12. mars 2008 av Slettet-NIoHlfL Lenke til kommentar
Vale Tudo Skrevet 13. mars 2008 Rapporter Del Skrevet 13. mars 2008 De driver jo å spiller inn Max Payne filmen nå om dagen, så dette skal man ikke se bort ifra nei.. Lenke til kommentar
Bear^ Skrevet 13. mars 2008 Rapporter Del Skrevet 13. mars 2008 Remedy solgte rettighetene allerede i 2002 til Take-2. Remedy fikk likevel utvikle oppfølgeren, men det er nok trolig helt opp til Take-2 selv å avgjøre hvem som skal utvikle 3'ern. Tror neppe det blir Remedy, de har ikke kapasitet til å utvikle mer enn et spill om gangen, og er nå opptatt med Alan Wake. Max Payne 3 ble for øvrig annonsert i 2004... Der var informasjonen jeg manglet ja. Da er det bare å se frem til, håper jeg, et like godt spill som Max Payne 1 og 2 var. Lenke til kommentar
BlastyTrasty Skrevet 13. mars 2008 Rapporter Del Skrevet 13. mars 2008 Godt nytt, Max Payne spela var utruleg bra. Lenke til kommentar
TCi Skrevet 13. mars 2008 Rapporter Del Skrevet 13. mars 2008 Håper sannelig det kommer til PC også. Helst at den utvikles for PC som hovedplattform. Ofte konsollspill får noe kronglete porting når det gjelder menyer og grensesnitt. Lenke til kommentar
Mala Skrevet 13. mars 2008 Rapporter Del Skrevet 13. mars 2008 Ja dette her hadde jo vert intet mindre en fantastisk, da de to foregående spillene var knallbra. Lenke til kommentar
Lakus Skrevet 13. mars 2008 Rapporter Del Skrevet 13. mars 2008 Eneren og Toeren er blant de spillene jeg ser på som klassikere. Lenke til kommentar
Erasus Skrevet 13. mars 2008 Rapporter Del Skrevet 13. mars 2008 Eneren og Toeren er blant de spillene jeg ser på som klassikere. Eneren synes jeg var utrolig bra, toeren var enda bedre og den ser jeg på som klassiker, så om den tredje i serien blir enda bedre, da får jeg vel kjøpe 2 kopier og sette den ene bak glass. Lenke til kommentar
Arangaras Skrevet 13. mars 2008 Rapporter Del Skrevet 13. mars 2008 Mark Wahlberg?! Skal Mark Wahlberg spele Max Payne?! Ikkje f.. Veit at dette sikkert er feil plass å diskutere dette, men det der går berre ikkje an. Mark Wahlberg ser jo so.. Pusete ut! Du trenge ein skikkeleg røff kar til å spele Max Payne, sånn som.. Tja, han fyren i Shoot 'em Up? Ikkje at eg har noko imot Mark Wahlberg, men han kan IKKJE vere Max Payne. Viss Max Payne blir modellert rundt herr Wahlberg i det nye spelet, og i tillegg gitt stemme til av han, so er eg redd for at dette kan øydeleggje litt for meg. Max Payne er berre definisjonen av mann, og spela kunne jo vere so dystre til tider at det nesten vart morosamt til slutt. For ikkje å snakke om all julinga Mr. Payne fekk, utan å døy. Lenke til kommentar
Erasus Skrevet 13. mars 2008 Rapporter Del Skrevet 13. mars 2008 Om bare Max Payne gikk i hendene til Christopher Nolan og Christian Bale... damn det ville ha vært noe helt for seg selv. Lenke til kommentar
