Packard Bell EasyNote ramtype?
iMono
Description
The EasyNote G series notebook has 256 MB SDRAM soldered on-board (not upgradeable). It has one SO-DIMM expansion slot. This slot will be already filled if the computer has more than 256 MB memory. If present, this module must be removed to upgrade your computer's memory.
Features
Requires a 200-pin, non-ECC, PC2700 DDR333 SO-DIMM.
Can accept 256, 512 or 1024 MB memory modules.
Maximum memory capacity: 1280 MB.
http://support.packardbell.com/no/item/index.php?i=spec_mem_nr1&ppn=PB11R00016
