Asus P5N-E SLI og Quad Core/Q6600 overklokking (Intel P35 og X38/X48 Tweaking)
  • 2 uker senere...
Nei nå holder jeg på å synke lavt for tiden... Veldig lavt faktisk.
Går og sniffer på ett http://www.komplett.no/k/ki.aspx?sku=342621
Det verste er at jeg vet det blir bare problemer men er fortsatt tiltrukket det kortet der av en eller annen merkelig grunn.
Riktignok blir det bare en 500 kroners Celeron på den og ett ultra billig skjermkort men...
Noen gode råd hvordan jeg kan glemme det skrotet der? :p
Måtte bare poste dette her, tror jeg har snublet over en JihadNvidiot...
Til opplysning så er dette fra AIM og ja jeg bruker Sweeper navnet naturligvis.
[10:22] nomakewan: I've owned an nForce2, and my current is an nForce4.
[10:22] nomakewan: I'll probably use an nForce 680i next.
[10:22] Sweeperthemerc: 4 capacitors is bust.
[10:23] nomakewan: Hahaha, keep talkin'.
[10:23] Sweeperthemerc: 680 for AMD or Intel?
[10:23] nomakewan: Intel, dur.
[10:23] nomakewan: AMD can suck my nuts.
[10:23] nomakewan: All my computers have been AMD.
[10:23] nomakewan: I love AMD.
[10:23] Sweeperthemerc: My condolances, save yourself the trouble and get a P35 or X48 ;)
[10:23] nomakewan: But AMD sucks right now.
[10:23] nomakewan: So Intel will be my next computer.
[10:23] Sweeperthemerc: Else be prepared for headaches.
[10:23] Sweeperthemerc: And lots of them.
[10:23] nomakewan: Hahaha, people said that about the ECS board I'm using.
[10:23] nomakewan: :)
[10:24] Sweeperthemerc: I have heard of people in frustration pouring petrol onto the nForce boards and setting fire to them.
[10:24] nomakewan: Good for those idiots.
[10:24] Sweeperthemerc: A P35 or X38/48 is a sure fire bet for stability though.
[10:24] nomakewan: Thankfully, I'm not stupid.
[10:24] nomakewan: I read ahead.
[10:24] Sweeperthemerc: And no weird oddities.
[10:24] Sweeperthemerc: http://vip.asus.com/forum/view.aspx?id=200...SLanguage=en-us
[10:25] Sweeperthemerc: I recommend reading that first though... Proper 680i setup procedures ;)
[10:25] nomakewan: ...except it's from Asus, and I'd be buying an eVGA, and I already read all the information on eVGA 680i boards.
[10:25] nomakewan: So thanks, but...no thanks.
[10:25] Sweeperthemerc: It is a gamble, and if you MUST have an nForce, EVGA or XFX is the only way to go.
[10:26] Sweeperthemerc: Same memory issues exists on the EVGA, I thought you knew that much if you have been reading around?
[10:26] Sweeperthemerc: Another aspect is that it is a gamble, either you get a system that works, OR you end up in hell.
[10:26] nomakewan: "Memory issue?" Which would that be?
[10:26] Sweeperthemerc: And thats when you Americans are screwed, in Norway we can return the motherboard and get everything refunded.
[10:26] Sweeperthemerc: And are covered by a 3 year warranty by law.
[10:27] nomakewan: Um, hello?
[10:27] nomakewan: Question?
[10:27] Sweeperthemerc: Memory issues? It can fry your chips as it doesn't give the voltage that is indicated in the BIOS.
[10:27] Sweeperthemerc: When it says 1.9V in the BIOS for an instance.
[10:27] Sweeperthemerc: It will really be feeding 2.2V or 2.3V
[10:28] Sweeperthemerc: It has killed a lot of memory, and even EVGA have been having those issues.
[10:28] Sweeperthemerc: Then there is the random nForce related crashes and BSOD's...
[10:28] Sweeperthemerc: The memory controller is really picky.
[10:29] nomakewan: Um, I've read that they work just fine if you use the memory that eVGA tested...which I would be, since the Kingston 4GB kit I was looking at happens to be cheap and on that list.
[10:29] Sweeperthemerc: Heh, no guarantees I am afraid.
[10:29] Sweeperthemerc: It means you are SUPPOSED to have no problems, but you are far from the safe zone.
[10:29] Sweeperthemerc: Memory slots also have a tendency to go dud at random too.
[10:30] Sweeperthemerc: There was a guy having to swap around his memory as slots 2 and 4 went dud and only gave crashes upon boot after a while.
[10:30] Sweeperthemerc: then nr 3 went dud.
[10:30] Sweeperthemerc: And he returned his motherboard.
[10:30] nomakewan: Lemme give you a hint, Sweeper.
[10:30] Sweeperthemerc: Asked for a refund + shipping and got a X48.
[10:30] nomakewan: Listening?
[10:30] nomakewan: I....
[10:30] nomakewan: ...Don't...
[10:30] nomakewan: ...Care.
[10:31] nomakewan: o_o Really.
[10:31] nomakewan: I'll take my chances, mmkay?
[10:31] Sweeperthemerc: Well at least you know what you are going to.
[10:31] nomakewan: I'll build this.
[10:31] nomakewan: If it works great? Awesome!
[10:31] nomakewan: If it doesn't? Then you can have your eagerly-awaited "I-told-you-so."
[10:31] nomakewan: But until then?
[10:31] Sweeperthemerc: I have told you what to expect, so you won't be surprised.
[10:31] nomakewan: STFU PLZ.
[10:31] nomakewan: kthx
[10:31] Sweeperthemerc: And if the bugs pop up, you know where it comes from
Skal man ha Nvidia så skal man ha det... HEH.
Tror jeg mistet lysten på Striker'n nå ja.
