Partisjonsfeil
Locazor
En NTFS partisjon på en av diskene mine har en feil. Windows omtaler denne som en "RAW" partisjon og jeg får ikke tilgang til den hvis den ikke formateres. I Partition Magic omtales den bare som "BAD." Vet noen hva jeg kan gjøre for å gjenopprette partisjonen? Jeg har prøvd med mange forskjellige "data recovery" programmer, så jeg vet at filene ligger der. Men alle disse programmene er bare demoer som ikke vil gjenopprette filer større enn 64kb. Noen som kan hjelpe meg?
http://www.compuapps.com/Download/DriveWiz...al/drivewiz.htm
http://www.tek-tips.com/gviewthread.cfm/le.../528/qid/273634
Your first and most pressing question--what the hell is a RAW file system?--is easy enough to answer. It's simply a disk partition that has not been
formatted with an NT file system, neither FAT nor NTFS.
As to the remainder of your problem, Mole feels that too much of the recipe is missing to cook up an entirely satisfactory answer. For instance, was the motherboard changed when going from the Pentium to the K6 processor? If so, there could very well be a problem with what Windows NT thinks is the disk controller and what is actually in the machine. This would cause problems in accessing the disk.
What's the fastest way to solve the problem? You may want to consider a complete re-install of the operating system, followed by a restore of data from the backup you performed prior to making the major hardware change. During the process of installing Windows NT, you will have the opportunity to format the drives to either FAT or NTFS.
One smart option for partitioning your hard disk is to create a smaller primary partition--say 2GB--using FAT, and to designate the rest of the hard drive NTFS. As you probably know, system boot files always reside on the primary partition. This way your boot up is fast, while the bulk of your files can enjoy the additional stability and security of NTFS. Note that with Windows NT 4.0, your hard drive may have only one or as many as four partitions. Going back to square one will let you customize your NT 4.0 installation for maximum performance.
BTW, your spelling is just fine, GastIt's your punctuation that looks a little weird…. Now, how about those fabled Argentine steaks?
Gastronomically yours,
Mole
I Powerquest PartitionInfo:
Error #109: Partition ends after end of disk.
 ucEndCylinder (113034) must be less than 14593.
Noen som vet hvordan jeg fikser dette?
og her er all partisjonsinfo, disk 2 som har problemer.
PowerQuest PartitionInfo 8.0 -- Windows NT/2000 Version
Date Generated:  02/24/03  19:39:52
Copyright ©1994-2002, PowerQuest Corporation
Permission is granted for this utility to be freely copied so long
as it is not modified in any way.  All other rights are reserved.
PowerQuest, makers of PartitionMagic®, Drive Image, and DriveCopy, can be reached at:
   Voice:  801-437-8900
   Fax:  801-226-8941
   Web site:  http://www.powerquest.com/support/
   E-mail:  [email protected]
General System Information:
   Total Physical Memory (bytes):  536,334,336
   Used Physical Memory: (bytes):  293,376,000
   Maximum Page File Size: (bytes):  1,311,227,904
   Current Page File Size: (bytes):  283,054,080
Disk Geometry Information for Disk 1:    24792 Cylinders,  255 Heads,  63 Sectors/Track
System              PartSect  # Boot BCyl Head Sect  FS    ECyl Head Sect    StartSect     NumSects
                          0  0  00     1    0    1  0F    1023  254   63       16,065  398,267,415
Info: Begin C,H,S values were large drive placeholders.
Info: End C,H,S values were large drive placeholders.
 Actual values are:
       0  0  00      1    0    1  0F  24791  254   63     16065 398267415
                     16,065  0  00     1    1    1  07    1023  254   63       16,128  398,267,352
 Actual values are:
   16065  0  00      1    1    1  07  24791  254   63     16128 398267352
Disk Geometry Information for Disk 2:    14593 Cylinders,  255 Heads,  63 Sectors/Track
Warning: Logical drive chain points to sector without partition table.
                          0  0  00     9    8    1  0F    1023  137   15  134,233,7931,681,666,063
 Actual values are:
       0  0  00   8355  170    9  0F  113034  137   15 1342337931681666063
Info: Partition didn't begin on head boundary.
 ucBeginHead expected to be 0 or 1, not 170.
 ucBeginSector expected to be 1, not 9.
Info: Partition didn't end on cylinder boundary.
 ucEndHead expected to be 254, not 137.
 ucEndSector expected to be 63, not 15.
Disk Geometry Information for Disk 3:    7473 Cylinders,  255 Heads,  63 Sectors/Track
                          0  0  80     0    1    1  07     675  254   63           63   10,859,877
                          0  1  00   676    0    1  0F    1023  254   63   10,859,940  109,193,805
 Actual values are:
       0  1  00    676    0    1  0F   7472  254   63  10859940 109193805
                 10,859,940  0  00   676    1    1  07    1023  254   63   10,860,003  102,430,377
 Actual values are:
10859940  0  00    676    1    1  07   7051  254   63  10860003 102430377
Partition Information for Disk 1:    194,474.4 Megabytes
Volume         PartType    Status    Size MB    PartSect  #   StartSect  TotalSects
              Unallocated Pri           7.8        None --          63      16,002
              ExtendedX   Pri      194,466.5           0  0      16,065 398,267,415
              EPBR        Log      194,466.5        None --      16,065 398,267,415
E:             NTFS        Log      194,466.5      16,065  0      16,128 398,267,352
Partition Information for Disk 2:    114,471.0 Megabytes
              Unallocated Pri      65,543.8        None --          63 134,233,730
              ExtendedX   Pri      821,126.0           0  0 134,233,7931,681,666,063
              EPBR        Log           0.0        None -- 134,233,793          63
              Unallocated Log      48,924.5        None -- 134,239,140 100,197,405
              Unallocated Log      772,194.7        None -- 234,436,5451,581,454,665
Partition Information for Disk 3:    58,620.0 Megabytes
C:             NTFS        Pri,Boot  5,302.7           0  0          63  10,859,877
              ExtendedX   Pri      53,317.3           0  1  10,859,940 109,193,805
              EPBR        Log      50,014.9        None --  10,859,940 102,430,440
D:             NTFS        Log      50,014.8  10,859,940  0  10,860,003 102,430,377
              Unallocated Log       3,302.4        None -- 113,290,380   6,763,365
Boot Record for drive E:   (Drive: 1, Starting sector: 16,128, Type: NTFS)
1. Jump:                   EB 52 90
2. OEM Name:               NTFS
3. Bytes per Sector:       512
4. Sectors per Cluster:    8
5. Reserved Sectors:       0
6. Number of FATs:         0
7. Root Dir Entries:       0
8. Total Sectors:          0
9. Media Descriptor:       0xF8
10. Sectors per FAT:        0
11. Sectors per Track:      63  (0x3F)
12. Number of Heads:        255  (0xFF)
13. Hidden Sectors:         63  (0x3F)
14. Total Sectors (>32MB):  0  (0x0)
15. Unused:                 0x80008000
16. Total NTFS Sectors:     398267351
17. MFT Start Cluster:      786432
18. MFT Mirror Start Clust: 24891709
19. Clusters per FRS:       246
20. Clusters per Index Blk: 1
21. Serial Number:          0x54B0956BB0955478
22. Checksum:               0  (0x0)
23. Boot Signature:         0xAA55
Boot Record for drive C:   (Drive: 3, Starting sector: 63, Type: NTFS)
1. Jump:                   EB 52 90
2. OEM Name:               NTFS
8. Total Sectors:          0
16. Total NTFS Sectors:     10859876
17. MFT Start Cluster:      262144
18. MFT Mirror Start Clust: 678742
21. Serial Number:          0x9C3881BC38819644
Boot Record for drive D:   (Drive: 3, Starting sector: 10,860,003, Type: NTFS)
1. Jump:                   EB 52 90
2. OEM Name:               NTFS
4. Sectors per Cluster:    1
8. Total Sectors:          0
13. Hidden Sectors:         10860003  (0xA5B5E3)
16. Total NTFS Sectors:     102430376
17. MFT Start Cluster:      7074550
18. MFT Mirror Start Clust: 49464103
20. Clusters per Index Blk: 8
21. Serial Number:          0xCE609B8E609B7BC1
