Fritz0r Skrevet 4. mars 2008 Del Skrevet 4. mars 2008 Saab, GM's svenske bil produsent skal nå starte med kanskje det som er den mest millijøvennelige svensk produserte bilen til dags dato. Motor: 200 hesters 1.4L BioHybrid turbo 0-100 E85 = 7.9 sekunder standard bensin = 8.3 sekunder Forbruk: 6.4 l/100km (E85) 4.9 l/100km (bensin) Detaljerte specs: BioPower Engine: Transversely-mounted, front wheel drive 1398 cc. Four cylinders Bore/stroke: 73.4/ 82.6 mm. Aluminum cylinder head, cast iron block DOHC, chain-driven. Four valves per cylinder. Forged steel crankshaft, steel connecting rods. Aluminum pistons, oil spray cooled. Direct Injection with centrally-mounted injectors. VVT, inlet and exhaust Sodium-filled exhaust valves Compression Ratio: 10.2: 1 Intercooled turbocharger. Max. Boost Pressure: 1.6 bar Dual-mass flywheel. Saab engine management Max power (E85): 200 hp (147 kW) @ 5000 rpm. Max.torque (E85): 280 Nm (207 lb.ft) @ 1750-5000 rpm Max power (gasoline): 170 hp (125 kW) @ 5200 rpm. Max.torque (gasoline): 230 Nm (170 lb.ft) @ 1500-5200 rpm Hybrid System: Electric motor/generator with lithium ion battery pack. Electric power boost, regenerative braking, fuel cut-off, automatic engine re-start Transmission: 6-spd manual gearbox, automated clutch, sequential gear selection, steering wheel controls Suspension: Front: Damper/coil struts, aluminum lower A-arm. Anti-roll bar. Rear: Torsion beam, two trailing links, coil springs and dampers. Anti-roll bar Steering: Rack and pinion, Electrical power assistance. Wheels, Tires: 21inch, 245/35R21 Brakes: Hydraulic, dual circuit, vacuum booster. Discs: 345 mm / 345 mm (all ventilated) Performance Data: (projected figures) 0 - 100 km/h (0-62 mph): 7.9 secs (E85) 8.3 secs (gasoline) 80 -120 km/h (50-75 mph), 5th gear: 8.8 secs (E85) 11.2 secs (gasoline) Top Speed, 6th gear: 216 km/h /134 mph (E85) 192 km/h / 119 mph (gasoline) Fuel consumption (combined cycle): 6.4 l/100km (E85) 4.9 l/100km (gasoline) CO2 emissions 105 g/km (E85) 117 g/km (gasoline) Kilde, press release og flere bilder: http://www.thetorquereport.com/2008/03/gen...saab_9x_bi.html Lenke til kommentar
Fritz0r Skrevet 4. mars 2008 Forfatter Del Skrevet 4. mars 2008 VG har bilde fra Geneve: http://www1.vg.no/bil-og-motor/artikkel.php?artid=504315 Lenke til kommentar
Skavold Skrevet 4. mars 2008 Del Skrevet 4. mars 2008 Denne blir nok bra. En skikkelig konkurrent til VAGs 1,4TFSI. Gleder meg til å se de tre neste Saab-modellene de neste få årene; 9-1, 9-4 og den nye 9-5. Lenke til kommentar
phax Skrevet 4. mars 2008 Del Skrevet 4. mars 2008 hehe, de bildene var jo litt vel konseptaktige, alltid like gøy og se hvor dørge kjedelige bilene faktisk ser ut når de blir lansert på markedet.. Lenke til kommentar
