FCW Skrevet 3. mars 2008 Del Skrevet 3. mars 2008 (endret) SMART forteller meg at min systemdisk har 80 "errors" Loggen forteller meg ingenting, noen som kan hjelpe meg her? Er det på tide å bytte? Disken funker bra selv om den er noen år gammel. === START OF READ SMART DATA SECTION ===SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 14004 - # 2 Short offline Completed without error 00% 14003 - > sudo smartctl --log selective /dev/sda smartctl version 5.37 [i686-pc-linux-gnu] Copyright © 2002-6 Bruce Allen Home page is http://smartmontools.sourceforge.net/ SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. > sudo smartctl --log directory /dev/sda smartctl version 5.37 [i686-pc-linux-gnu] Copyright © 2002-6 Bruce Allen Home page is http://smartmontools.sourceforge.net/ Warning: device does not support General Purpose Logging > sudo smartctl --all /dev/sda smartctl version 5.37 [i686-pc-linux-gnu] Copyright © 2002-6 Bruce Allen Home page is http://smartmontools.sourceforge.net/ === START OF INFORMATION SECTION === Model Family: Seagate Barracuda 7200.7 and 7200.7 Plus family Device Model: ST3160021A Serial Number: 5JS09K97 Firmware Version: 3.06 User Capacity: 160.041.885.696 bytes Device is: In smartctl database [for details use: -P show] ATA Version is: 6 ATA Standard is: ATA/ATAPI-6 T13 1410D revision 2 Local Time is: Tue Mar 4 00:27:10 2008 CET SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 430) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. No General Purpose Logging support. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 111) minutes. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 071 061 006 Pre-fail Always - 124340511 3 Spin_Up_Time 0x0003 097 096 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 366 5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 0 7 Seek_Error_Rate 0x000f 089 060 030 Pre-fail Always - 918166219 9 Power_On_Hours 0x0032 085 085 000 Old_age Always - 14005 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 096 096 020 Old_age Always - 4147 194 Temperature_Celsius 0x0022 030 053 000 Old_age Always - 30 195 Hardware_ECC_Recovered 0x001a 071 061 000 Old_age Always - 124340511 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x003e 200 181 000 Old_age Always - 23 200 Multi_Zone_Error_Rate 0x0000 100 253 000 Old_age Offline - 0 202 TA_Increase_Count 0x0032 100 253 000 Old_age Always - 0 SMART Error Log Version: 1 ATA Error Count: 80 (device log contains only the most recent five errors) CR = Command Register [HEX] FR = Features Register [HEX] SC = Sector Count Register [HEX] SN = Sector Number Register [HEX] CL = Cylinder Low Register [HEX] CH = Cylinder High Register [HEX] DH = Device/Head Register [HEX] DC = Device Command Register [HEX] ER = Error register [HEX] ST = Status register [HEX] Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 80 occurred at disk power-on lifetime: 13921 hours (580 days + 1 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 84 51 01 3f 00 00 e0 Error: ICRC, ABRT 1 sectors at LBA = 0x0000003f = 63 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- c8 00 01 3f 00 00 e0 00 00:03:53.678 READ DMA c8 00 01 3f 00 00 e0 00 00:03:53.080 READ DMA c8 00 01 bf 00 00 e0 00 00:03:52.478 READ DMA c8 00 01 4f 00 00 e0 00 00:03:51.876 READ DMA c8 00 01 41 00 00 e0 00 00:03:51.321 READ DMA Error 79 occurred at disk power-on lifetime: 13921 hours (580 days + 1 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 84 51 01 3f 00 00 e0 Error: ICRC, ABRT 1 sectors at LBA = 0x0000003f = 63 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- c8 00 01 3f 00 00 e0 00 00:03:53.678 READ DMA c8 00 01 bf 00 00 e0 00 00:03:53.080 READ DMA c8 00 01 4f 00 00 e0 00 00:03:52.478 READ DMA c8 00 01 41 00 00 e0 00 00:03:51.876 READ DMA c8 00 01 41 00 00 e0 00 00:03:51.321 READ DMA Error 78 occurred at disk power-on lifetime: 13921 hours (580 days + 1 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 84 51 01 41 00 00 e0 Error: ICRC, ABRT 1 sectors at LBA = 0x00000041 = 65 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- c8 00 01 41 00 00 e0 00 00:03:53.678 READ DMA c8 00 01 41 00 00 e0 00 00:03:53.080 READ DMA c8 00 01 41 00 00 e0 00 00:03:52.478 READ DMA c8 00 01 3f 00 00 e0 00 00:03:51.876 READ DMA c8 00 01 3f 00 00 e0 00 00:03:51.321 READ DMA Error 77 occurred at disk power-on lifetime: 13921 hours (580 days + 1 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 84 51 01 41 00 00 e0 Error: ICRC, ABRT 1 sectors at LBA = 0x00000041 = 65 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- c8 00 01 41 00 00 e0 00 00:03:53.678 READ DMA c8 00 01 41 00 00 e0 00 00:03:53.080 READ DMA c8 00 01 3f 00 00 e0 00 00:03:52.478 READ DMA c8 00 01 3f 00 00 e0 00 00:03:51.876 READ DMA c8 00 01 3f 00 00 e0 00 00:03:51.321 READ DMA Error 76 occurred at disk power-on lifetime: 13921 hours (580 days + 1 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 84 51 01 41 00 00 e0 Error: ICRC, ABRT 1 sectors at LBA = 0x00000041 = 65 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- c8 00 01 41 00 00 e0 00 00:03:47.699 READ DMA c8 00 01 3f 00 00 e0 00 00:03:53.080 READ DMA c8 00 01 3f 00 00 e0 00 00:03:52.478 READ DMA c8 00 01 3f 00 00 e0 00 00:03:51.876 READ DMA c8 00 01 7f 00 00 e0 00 00:03:51.321 READ DMA SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 14004 - # 2 Short offline Completed without error 00% 14003 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. På forhånd takk! Endret 3. mars 2008 av FCW Lenke til kommentar
Mr. Floppy Skrevet 5. mars 2008 Del Skrevet 5. mars 2008 Siden feilmeldingene nevner ICRC (=Interface CRC), så vil jeg i første omgang foreslå at du sjekker kablene. Dobbelsjekk at de sitter fast i begge ender, prøv gjerne med en annen kabel, og pass på at den ikke ligger i nærheten av noe som kan forstyrre signalene. Loggen inneholder ingen graverende feil av typen ødelagte sektorer e.l. Det mest alvorlige er SMART-attributt #1, Raw Read Error Rate, som indikerer at disken må jobbe litt ekstra for å lese platen. Men det er vel ikke annet å vente når disken har kjørt i over 14000 timer - verdien ligger foreløpig godt innenfor den verdien som produsenten oppgir som kritisk. Står det noe i /var/log/messages som tyder på noen problemer? Lenke til kommentar
FCW Skrevet 9. mars 2008 Forfatter Del Skrevet 9. mars 2008 (endret) Takk for svar Her er utdreg av loggen: Mar 9 06:47:02 FILSERVER syslogd 1.4.1#21ubuntu3: restart. Mar 9 07:03:57 FILSERVER -- MARK -- Mar 9 07:23:57 FILSERVER -- MARK -- Mar 9 07:43:57 FILSERVER -- MARK -- Mar 9 08:03:57 FILSERVER -- MARK -- Mar 9 08:23:57 FILSERVER -- MARK -- Mar 9 08:43:57 FILSERVER -- MARK -- Mar 9 08:45:43 FILSERVER kernel: [472753.544228] sd 4:0:0:0: [sdc] Device not ready: <6>: Sense Key : Not Ready [current] Mar 9 08:45:43 FILSERVER kernel: [472753.544236] : Add. Sense: Logical unit not ready, initializing command required Mar 9 08:45:43 FILSERVER kernel: [472753.544243] end_request: I/O error, dev sdc, sector 311 Mar 9 08:45:43 FILSERVER kernel: [472753.544248] printk: 20 messages suppressed. Mar 9 09:03:57 FILSERVER -- MARK -- Mar 9 09:23:57 FILSERVER -- MARK -- Mar 9 09:26:47 FILSERVER kernel: [475215.385708] sd 4:0:0:0: [sdc] Device not ready: <6>: Sense Key : Not Ready [current] Mar 9 09:26:47 FILSERVER kernel: [475215.385716] : Add. Sense: Logical unit not ready, initializing command required Mar 9 09:26:47 FILSERVER kernel: [475215.385723] end_request: I/O error, dev sdc, sector 540278863 Mar 9 09:43:57 FILSERVER -- MARK -- Mar 9 10:03:57 FILSERVER -- MARK -- Mar 9 10:23:57 FILSERVER -- MARK -- Mar 9 10:43:57 FILSERVER -- MARK -- Mar 9 11:03:57 FILSERVER -- MARK -- Mar 9 11:23:57 FILSERVER -- MARK -- Mar 9 11:43:57 FILSERVER -- MARK -- Mar 9 12:03:57 FILSERVER -- MARK -- Mar 9 12:23:57 FILSERVER -- MARK -- Mar 9 12:43:57 FILSERVER -- MARK -- Mar 9 13:03:57 FILSERVER -- MARK -- Mar 9 13:23:57 FILSERVER -- MARK -- Mar 9 13:43:57 FILSERVER -- MARK -- Mar 9 14:03:57 FILSERVER -- MARK -- Mar 9 14:23:57 FILSERVER -- MARK -- Mar 9 14:43:57 FILSERVER -- MARK -- Mar 9 15:03:57 FILSERVER -- MARK -- Mar 9 15:23:57 FILSERVER -- MARK -- Mar 9 15:43:57 FILSERVER -- MARK -- Mar 9 16:03:57 FILSERVER -- MARK -- Mar 9 16:23:57 FILSERVER -- MARK -- Mar 9 16:31:04 FILSERVER kernel: [500650.911775] sd 4:0:0:0: [sdc] Device not ready: <6>: Sense Key : Not Ready [current] Mar 9 16:31:04 FILSERVER kernel: [500650.911785] : Add. Sense: Logical unit not ready, initializing command required Mar 9 16:31:04 FILSERVER kernel: [500650.911793] end_request: I/O error, dev sdc, sector 311 Mar 9 16:31:04 FILSERVER kernel: [500650.911797] printk: 20 messages suppressed. Mar 9 16:31:14 FILSERVER kernel: [500660.767643] ip_tables: (C) 2000-2006 Netfilter Core Team Mar 9 16:43:57 FILSERVER -- MARK -- Mar 9 16:51:29 FILSERVER kernel: [501874.777200] sd 4:0:0:0: [sdc] Device not ready: <6>: Sense Key : Not Ready [current] Mar 9 16:51:29 FILSERVER kernel: [501874.777210] : Add. Sense: Logical unit not ready, initializing command required Mar 9 16:51:29 FILSERVER kernel: [501874.777219] end_request: I/O error, dev sdc, sector 0 Mar 9 16:51:29 FILSERVER kernel: [501874.777223] printk: 20 messages suppressed. Mar 9 17:03:57 FILSERVER -- MARK -- Forslag??? Edit: Fant ut at loggen viser Backup disken (Maxtor USB), sannsynligvis p.g.a den går i "standby" FC Endret 9. mars 2008 av FCW Lenke til kommentar
Mr. Floppy Skrevet 9. mars 2008 Del Skrevet 9. mars 2008 Edit: Fant ut at loggen viser Backup disken (Maxtor USB), sannsynligvis p.g.a den går i "standby"FC Selv bruker jeg ikke standby-funksjon, så jeg er ikke sikker på hva slags utslag det gir i loggen, men det er ikke usannsynlig at meldingene i loggen dreier seg om det. Du kan jo sjekke SMART-verdiene til den disken også for å være sikker. Hvis det ikke nevnes noe om den første disken i loggfilen, så vil jeg tippe at du ikke har noen akutte problemer, men sjekk kablene om du ikke har gjort det. Les forøvrig av SMART-verdiene en gang i blant (eller sett på automatisk e-postvarsling), ta jevnlig backup av viktige filer og sov godt i natt også. Lenke til kommentar
