Hva er AA?
- AA (Anti-Aliasing)
The screen consists of a lot of pixels (a square entity) and because of its shape aliasing happens, which also produces crawling (when aliasing moves). This isn’t a problem for lines which are vertical or horizontal since they then will follow the pixel’s sides. Anti-aliasing will reduce the problem by making the transition between pixels smother by replacing the light intensity of the pixel. This is done by creating sub-pixels which samples how the actual luminance (colour) is within the pixel which then creates a final pixel colour. More samples will ensure an even smother transition between the pixels.
There exist two main solutions:
MS (Multi-Sampling)
This method only works on polygon edges. Think about polygons as something which has a skeleton (called mesh). Not everything on screen is made up by polygons - it will therefore not catch everything (e.g. vegetation). It requires a lot of memory bandwidth and memory.
4xRGMS (D3D FSAAViewer)
Pink = sub-pixels
Green = texture sample
SS (Super-Sampling)
It’s a “catch all” method. The normal implementation is by making a higher resolution version (4x = 4xresolution!) of the frame which is then down-sampled to the correct screen resolution. This ensures that everything on-screen get anti-aliased. It requires a lot of fill-rate, memory bandwidth and memory.
Ordered Grid vs. Rotated Grid
Ordered grid = samples follows the shape of the pixel
Rotated grid = same as the above but now on a angle (see picture above)
RGSS is seen to have one basic advantage over OGSS: More effective anti-aliasing near the horizontal and vertical axes, where the human eye can most easily detect screen aliasing (jaggies). This advantage also permits the use of fewer sub-samples to achieve approximately the same visual effect as OGSS.
Quote
