Garmin XT Nokia n95
regine
Noen som vet om den interne gps,en i nokia n95 funker med garmin XT.
Har prøvd meg på denne men får det ikke til å funke
1. unzip the download and install the file called garmin onto your memory card.
2. Disconnect phone from pc then navigate to the garmin folder and run the garminxt.sis this will install the aplication.
3. when installed goto aplications folder and start garminxt.
4. open settings open about about
3. Make note of your "Card ID"
4. Launch the keygen, and enter the "Card ID" you see on GMXT About page.
5. hit generate code
5. Copy (CTRL+C) the Device unlock key to clipboard.
6. Now open Notepad and paste (CTRL+V) the key and save the file as SW.UNL
9. Put your newly created file to your SD Card\Garmin directory and restart GMXT.
8. Program should now recognize your built-in GPS (if not go to settings\system and choose "connected gps") and you should be
able to use detailed maps.
