-Logos- Skrevet 28. februar 2008 Del Skrevet 28. februar 2008 Etter den eksterne disken min har stått "idle" en stund... og jeg prøver å få kontakt med den vil den ikke opp igjen og sier det er en I/O feil :/media/FreeAgent Drive$ lsls: .: Input/output error dmesg: 10436.876000] end_request: I/O error, dev sda, sector 6291527 [10436.876000] Buffer I/O error on device sda1, logical block 786433 [10440.904000] sd 0:0:0:0: [sda] Device not ready: <6>: Sense Key : Not Ready [current] [10440.904000] : Add. Sense: Logical unit not ready, initializing command required [10440.904000] end_request: I/O error, dev sda, sector 6291527 [10440.904000] Buffer I/O error on device sda1, logical block 786433 [10482.920000] sd 0:0:0:0: [sda] Device not ready: <6>: Sense Key : Not Ready [current] [10482.920000] : Add. Sense: Logical unit not ready, initializing command required [10482.920000] end_request: I/O error, dev sda, sector 6291527 [10482.920000] Buffer I/O error on device sda1, logical block 786433 [75686.548000] sd 0:0:0:0: [sda] Device not ready: <6>: Sense Key : Not Ready [current] [75686.548000] : Add. Sense: Logical unit not ready, initializing command required [75686.548000] end_request: I/O error, dev sda, sector 6291527 [75686.548000] Buffer I/O error on device sda1, logical block 786433 [75686.552000] sd 0:0:0:0: [sda] Device not ready: <6>: Sense Key : Not Ready [current] [75686.552000] : Add. Sense: Logical unit not ready, initializing command required [75686.552000] end_request: I/O error, dev sda, sector 6291527 [75686.552000] Buffer I/O error on device sda1, logical block 786433 [75693.088000] sd 0:0:0:0: [sda] Device not ready: <6>: Sense Key : Not Ready [current] [75693.088000] : Add. Sense: Logical unit not ready, initializing command required [75693.088000] end_request: I/O error, dev sda, sector 6291527 [75693.088000] Buffer I/O error on device sda1, logical block 786433 [76671.180000] sd 0:0:0:0: [sda] Device not ready: <6>: Sense Key : Not Ready [current] [76671.180000] : Add. Sense: Logical unit not ready, initializing command required [76671.180000] end_request: I/O error, dev sda, sector 0 [76671.180000] Buffer I/O error on device sda, logical block 0 [76671.184000] sd 0:0:0:0: [sda] Device not ready: <6>: Sense Key : Not Ready [current] [76671.184000] : Add. Sense: Logical unit not ready, initializing command required [76671.184000] end_request: I/O error, dev sda, sector 0 [76671.184000] Buffer I/O error on device sda, logical block 0 [76671.192000] sd 0:0:0:0: [sda] Device not ready: <6>: Sense Key : Not Ready [current] [76671.192000] : Add. Sense: Logical unit not ready, initializing command required [76671.192000] end_request: I/O error, dev sda, sector 8 [76671.192000] Buffer I/O error on device sda, logical block 1 Kjører Ubuntu 7.10 Lenke til kommentar https://www.diskusjon.no/topic/918194-io-feil-p%C3%A5-ekstern-harddisk-etter-at-den-har-st%C3%A5tt-en-stund/
