Hvilke GPS programmer til N95 8GB
pierce007
Jeg har prøvd Nokia Maps 1.2 og 2.0 beta, Route 66 v7.xx, Sygic Mobile og Garmin Mobile XT.
Jeg er uten tvil mest fornøyd med Garmin Mobile XT.
Det er dog viktig at en bruker den nyeste versjonen (4.10.60) for at den skal fungere med den innebygde GPS'en i N95/N95 8GB.
Versjon 4.10.20 fungerer helt fint med den interne GPSen på min N82. At det skal være noe annerledes på N95 tviler jeg sterkt på.
Det er sant nok. 4.10.20 var den første versjonen med bl.a. N95 støtte.
Men det har blitt foretatt en god del bugfikser fra versjon 4.10.20 til 4.10.60:
Changes made from version 4.10.40 to 4.10.60:
* Provide the latest Garmin splash screen and associated copyright text.
* Provide a Vehicle setting within Settings->Map to support the downloadable Garmin vehicles.
* Provide Afrikaans voice support.
* Improve the Bluetooth connection process for the GPS receiver.
* Correct the voice selection in the startup page.
* Correct the search capability to find Contacts and My Locations using lowercase letters.
* Correct a GPX import failure when the route or track name is long.
* Correct the Save to Contacts from My Locations to save the location also.
* Correct the display of a POI position for countries that use comma as a decimal separator.
* Correct the POI count in the POI list page.
Changes made from version 4.10.20 to 4.10.40:
* Provide Garmin Mobile SDK support.
* Improve the map drawing speed at 50m zoom scale when there are Custom POI points without location information.
* Improve the backlight setting option text for clarity.
* Improve display of detailed weather information (E90).
* Improve visibility of roads on map display (E90).
* Improve the categorization of Custom POIs.
* Improve communication to the Garmin GPS 10 device.
* Improve the stability of off-route recalculations.
* Improve text display (Chinese).
* Prompt for GPX import after download of waypoints/routes/tracks from MapSource.
* Decrease the size of the message boxes (E90).
* Correct map drawing in landscape mode when creating a new saved route.
* Correct route calculation in landscape mode when creating a new saved route (E70).
* Correct the timeout for safety camera downloads when connecting through low-speed networks.
* Correct the highlighting of downloaded safety camera files.
* Correct the search capability for Custom POIs when multiple Custom POI categories exist (N95).
* Correct the truncated name of a route when importing a route with a long name.
* Correct the duplicate listing in search results for specific Custom POIs without location information.
* Correct empty guidance text when navigating to a highway exit.
* Correct an application lockup when adding a via point into an existing route.
* Correct the turn preview page display.
* Correct input of 'Where to' data according to Settings->System->Location Format.
* Correct the processing of route recalculations during active user calls.
Så jeg anbefaler uansett at man bruker versjon 4.10.60.
Ja det stemmer, dessverre. Selv bruker jeg Route66 og er meget fornøyd med det.
Har akkurat bestilt en N95 8GB, og skal bruke GPS funksjonen på den til en viss grad. Hvor kan man kjøpe det programmet? Route66.. Betaler man for det èn gang, eller er det en månedlig oppdateringsavgift eller noe sånt? Fotoboksvarsling?
www.66.com
Route 66 Mobile 8 ble sluppet nå nylig og er merkbart mye bedre enn versjon 7.3.
Route 66 Mobile 8 med Skandinaviske kart er også veldig billig, 60 euro fra webshoppen..
Endret av bidz
Jeg installerte Garmin Mobile XT, men den finner ikke GPS enheten på min N95 8GB. Er det noen instillinger jeg må gjøre for å få den til å fungere?
Får bare opp "Søker etter GPS-enhet" og får valg om å prøve igjen etter en liten stund.
Endret av ICS-FD
Det spørres vel om GPS programmer med fotoboksvarsling, og meg bekjent er det ingen av de som ramses opp her som har det(?) På Tomtom får man det, men man må bruke en ekstern GPS for at det skal fungere. Nå er jo fotoboksvarsling kun aktuelt ved kjøring, så da gjør det kanskje ikke så mye om man har en ekstern GPS mottaker liggendes i bilen ;) Jeg bruker forøvrig den løsningen selv...
Garmin Mobile XT har fotoboksvarsling, og det følger med et gratis "abbonnemang" på oppdaterte fotoboksvarslings POI'er i programmet, som man kan oppdatere via WiFi/GPRS.
Er vel det at man må betale for gang det brukes. Eller noe i den duren.
Det koster ingenting å bruke det utenom hvis man bruker stemmestyring som koster ca 500 (veldig usikker på prisen) for 3 år. Man kan bruke stemmestyring gratis i 3 mnd.
Litt mer enn 500 tror jeg det koseter for tre år. Nå har også Nokia endre systemet, slik at om man vil ha 3 års navigering (som følger personen, ikke telefonen), må man kjøpe det i en butikk. Man kan kun kjøpe ett år via telefonen, og det koster rundt 500 tror jeg.
Nokia sin løsning:
Navigering koster penger. Både med og uten stemmestyring. Vil du ha veibeskrivelse til et sted du skal må du punge ut. Dersom du vil se hvor du er på kartet = gratis. Du kan betale for 1 dag, 1 mnd eller for 1 år. Det er gratis å prøve navigering i 3 uker.
Selv bruker jeg Garmin Mobile XT og er fornøyd.
Nokia sin løsning:
Det koster altså penger for å bruke stemmestyring og veibeskrivelse med Nokias GPS program som kommer med telefone. Hva med de andre programmene man kan kjøpe kart for, slike som Wayfinder, Route66 og Garmin? Gjelder det det samme for disse?
Det beste hadde vært et GPS program med komplett kart som ikke koster noe å bruke, slikt som vanlig GPS enhet man har i bil.
Hei,, jeg bare lurer på et par ting,, Garmin Mobile XT er den og få i norsk utgave og i så tilfelle hva koster den ,, er det noen som har prøvd topografiske kart 1.5000. jeg har selv nokia n82,, på forhånd takk for svar
