AVCHD for Dummies
Hei. Har fått meg kamera til jul, ett Panasonic HDC-5. Sikkert bra, men jeg føler meg ikke komfertabel med AVCHD formatet for å si det mildt. Finnes det ett konverteringsprogram slik at jeg enkelt kan konvertere filene til et format som enkelt lar seg redigere, spille av på en vanlig DVD maskin osv.
Hadde satt umåtelig stor pris på om noen kunne hjelpe meg, og forklart det må en måte slik at en idiot som meg selv skjønner det:)
Er dere evig takknemlig.
http://en.wikipedia.org/wiki/AVCHD
The following video-editing software features support for the AVCHD format:
Apple's Final Cut Express 4, Final Cut 6.01, CyberLink's PowerDirector 6, Sony Vegas 7.0e, Vegas Pro 8, and Vegas Movie Studio Platinum 8, Corel's Ulead VideoStudio 11 Plus, Corel's Ulead DVD MovieFactory 5, Pinnacle's Studio Plus 11, Avid Xpress Pro and Avid Media Composer, Canopus' EDIUS Pro 4.5.
Nero 7 Ultra Edition Enhanced and Nero 8 Ultra Edition are a software suites which contains the AVCHD editor, found in Nero Vision. Also included in this suite is Nero Showtime, which plays AVCHD files natively. Edited video can also be burned to DVD discs in AVCHD format for playback on hardware players or in Blu-ray format.
iMovie '08 allows you to convert AVCHD to the Apple Intermediate Codec format, but does not support AVCHD directly.
Other developers have pledged their support but it may still take some time for the implementation.
The following software can convert the AVCHD format to other formats:
Canopus's AVCHD Converter can convert AVCHD clips into a format which can be edited using Canopus' EDIUS 3/4.
A related tool, Canopus' ProCoder, can perform conversions that produce files which are usable by other video editing applications that do not support AVCHD natively.
Cineform also offers the Neo HDV product that allows AVCHD clips to be converted into I-frame wavelet .avi files designed for editing and post-production. These .avi files can be accepted by many popular consumer non-linear video editors, including those from Sony, Adobe and Corel, which has acquired Ulead.
Another useful product is CoreAVC, a reasonably cheap and quick h.264 decoder for Windows, which can decode AVCHD as well as a variety of other h.264 formats.
Nero Vision can convert AVCHD files to other formats such as MPEG-2 or AVI and can import them for use in video editing projects. Nero Vision can also export Sony's M2TS format to MPEG-4 files that can be viewed by Quicktime 7.
PowerDVD Ultra comes with an AVCHD codec that can be used with AVISynth[5] and VirtualDubMod[6] as described here[7].
There is a transcoder to convert AVCHD into P2, which is a format you can import into Avid Xpress or AVID Media Composer. The transcoder was created by Main Concept and is distributed free of charge by Panasonic. You can download the file from here [8].
Latest version VAIO Editing Components that pre-loaded with Sony VAIO PCs can serve as a plug-in for Adobe Premiere Pro 2 to support AVC-HD import/export and editing.
VoltaicHD is a simple yet useful tool to allow you to convert AVCHD files into other useful formats. The PC version allows output to WMV and AVI. A Mac version is also available.
  • 1 år senere...
Tanbee AVCHD Converter for Mac converts AVCHD(MTS/MT2S/MOD/TOD/MKV) videos to all popular HD/Common videos suitable for different mobile devices.
AVCHD Converter for Mac can be used like MTS Converter, M2TS Converter, TS Converter, MOD Converter, TOD Converter, MKV Converter etc.
Input File Format Support
Video : M2TS, MTS, TS, TP, TRP, MOD, TOD, WMV, 3GP, 3G2, MOV, VOB, MPG, ASF, FLV, AVI, RM, RMVB, DV, MPEG-1, MPEG-2, MP4, MKV, etc
Audio : MKA, MP3, WAV, M4A, AAC, AC3, AIFF, AMR, FLAC, WMA, MP2, etc
This step-by-step guide will show you how to convert video files with this software.
Before you start, please download, install and launch
Intel Version (9.00M).
PowerPC Version (8.64M).
Step 1: Load video files
Click "Add Files" button to add video files you want. After video files are imported successfully, you will see all of them listed in the program:
Step 2: Select output format
Select one or more files in the file list, click "Profile" drop-down button, and select an output format for the selected files in the drop-down list that opens.
Step 3: Edit Video (Trim,Crop,Effect)
Select a video file in the file list, click "Trim","Crop","Effect" button to open window for edit.
Step 4: Convert
After the above settings, check the needed files to convert in the file list, and click "Convert" button on the window to start converting.
http://www.avchd.converter-for-mac.com
Note: This version is for Mac OS. If you are using Windows, please click here.
