Trenger hjelp til et registrerings system!
Hallo! Jeg har et registrerings system.
Og det funket helt fint - intill jeg skiftet url'en til slik at man får f.eks: side=register. osv.. Da klikka scriptet. Og jeg kommer automatisk til melingen: "Register Fucked Up!".
Hvorfor det ?
Kilde:
https://www.diskusjon.no/index.php?showtopic=886877
Her er scriptet: Hva er feil ?
<?php
# Auteur: J. Klompen #
# Site : http://www.maffia.net.tc #
# Date : 15 apr 2005 #
# Email: [email protected] #
// bezoekers statistieken
$pagename = "Register";
include("./counter.inc.php");
setcookie("cookieusername", "");
setcookie("cookiepassword", "");
if (!$_POST['name'] OR !$_POST['password']) {
<html>
<head>
<title>Registrer @ Mafia</title>
<link rel="stylesheet" type="text/css" href="src/standard.css" />
<script language=JavaScript>
function screenshots(){
var popurl="screenshots.php"
winpops=window.open(popurl,"","width=800,height=640,")
function firstFocus()
if (document.forms.length > 0)
var TForm = document.forms[0];
for (i=0;i<TForm.length;i++)
if ((TForm.elements.type=="text")||
(TForm.elements.type=="textarea")||
(TForm.elements.type.toString().charAt(0)=="s"))
document.forms[0].elements.focus();
break;
</SCRIPT>
</head>
<body>
<table class="login"><tr><td align="center">
<table class="windowLogin">
<tr>
<td class="loginLeft">
<img src="images/logoLogin.jpg" />
</td>
<td class="loginRight">
<div class="mainTitle"><div class="logo"> </div></div>
<div class="mainText">
Register!<br />
<br />
<?php
include "_ip_block.php";
if ($ip_check == "pos") {
<form method="post">
<table>
<tr><td class="column1"><li></td><td class="column2">Brukernavn </td><td class="column3"><input type="text" name="name" /></td><td></td></tr>
<tr><td class="column1"><li></td><td class="column2">E - post</td><td class="column3"><input type="text" name="password" /></td><td></td></tr>
<tr><td></td><td></td><td class="column4"><input class="button" type="submit" value="Registrer" /></td></tr>
</table>
</form>
<?php
} elseif ($ip_check == "neg") {
echo "You are blocked from this site!!!";
echo "<br/>";
echo "Reason: $reason";
</div>
</td>
</table>
<div class="windowLoginStatus">
<a class="login" href="index.php">Logg inn</a> | <a class="login" href="recover.php">Glemt Passord!</a> | <a class="login" href="java script:screenshots()">Screenshots!</a></div>
</td></tr></table>
</body>
</html>
<?php
<?php
} else {
$name = $_POST['name'];
$password = $_POST['password'];
$while = 0;
include "_connect.php";
$lijstGebruikers = "SELECT * FROM users";
$resultLijstGebruikers = mysql_query($lijstGebruikers);
while ($row = mysql_fetch_array($resultLijstGebruikers)) {
$name2 = strtolower($name);
$username = strtolower($row[username]);
if ($name2 == $username) {
$while = 1;
if ($while == 1) {
echo "User allready exists";
echo "<br />Please wait till we tranfer u";
echo "<META http-equiv=refresh content=\"2;url=register.php\">";
} else {
$datem = date( "j.M.Y - G:i:s" );
$lijstGebruikers = "SELECT * FROM users WHERE specialised='$password'";
if (mysql_num_rows($resultLijstGebruikers) == 1) {
echo "There is allready an user that uses that email adress!";
} else {
$pass1 = rand(0,100);
$pass2 = rand(0,100);
$pass3 = rand(0,100);
$pass4 = rand(0,100);
$pass5 = rand(0,100);
$passgenerated = $pass1 . $pass2 . $pass3 . $pass4 . $pass5;
if ($passgenerated) {
$opdracht = "insert INTO users values('0','$name','$passgenerated','0','1500','0','100','0','0','No quote','0','0','0','0','Netherlands','0','0','0','0','0','0','$datem','0','0','0','0','0','$password')";
$resultaat = mysql_query($opdracht);
if ($resultaat) {
echo "<div class=\"mainText\">";
echo "Register succes! You can now login with this password: <b>\"$passgenerated\"</b>. Have fun!<br/>(You can change your password in profile, after your logged in)<br/>";
echo "<a href=index.php>Return to login</a>";
echo "</div>";
} else {
echo "Register Fucked up!";
echo "<META http-equiv=refresh content=\"2;url=index.php\">";
} else {
echo "Could not send the email!";
