Snerk Skrevet 23. februar 2008 Rapporter Del Skrevet 23. februar 2008 Operation: Broken Mirror heter den, og kommer med et APC kjøretøy med noen snasne funksjoner. In Broken Mirror, Eucadian and Chernovan players will gain access to an APC that can seat six soldiers. These six soldiers can pop out of port holes akin to that on the tank and protect the vehicle when necessary. However, like the dropship, the APC is useful for more than simple transport missions. It can ram through just about any vehicle or emplacement (with the exception of tanks), instantly killing or destroying its target. It can deploy a electromagnetic bubble shield, which your troops can fire out of, but will neutralize incoming fire. It will also short out enemy vehicles and make aircraft critically fail if they come into contact with this shield, protecting ground troops from dive bombing attacks. What's more, the APC can be used as a mobile checkpoint, allowing players to spawn inside of an APC that's driving around the map. This means that you can potentially rejoin the fight on the battlefield without having to trek across some distance if a checkpoint is being fiercely fought over. But there's an additional plus to spawning inside the APC, which is that players will randomly receive one weapon that can be immediately used. So you could emerge from the vehicle you spawned into with binoculars, flame throwers or other items. http://ps3.ign.com/articles/854/854404p1.html Dropship'et fra omega dawn ble aldri helt det store, men den APC'en kan bli genial. Uansett, håper ikke de drøyer for lenge med å utgi denne og 1.3 patchen. Lenke til kommentar
Nimrad Skrevet 23. februar 2008 Rapporter Del Skrevet 23. februar 2008 1.3 patch? Dvs. at det er en gratis oppdatering? Lenke til kommentar
Snerk Skrevet 23. februar 2008 Forfatter Rapporter Del Skrevet 23. februar 2008 1.3 patchen blir gratis, men booster pakken må du nok ut med noen kroner for. Lenke til kommentar
HerrGhost Skrevet 23. februar 2008 Rapporter Del Skrevet 23. februar 2008 Det nye kjøretøyet høres rått ut. Lenke til kommentar
Snerk Skrevet 1. mars 2008 Forfatter Rapporter Del Skrevet 1. mars 2008 Den nye APCen og boble-skjoldet: Ser unektelig morro ut. Mer her: http://kotaku.com/360631/warhawk-gets-monster-bubble-shields Lenke til kommentar
HerrGhost Skrevet 1. mars 2008 Rapporter Del Skrevet 1. mars 2008 Dæven, det ser rått ut. Lenke til kommentar
Lineplx Skrevet 1. mars 2008 Rapporter Del Skrevet 1. mars 2008 Det spille ser kult ut hvor får du taki det? Lenke til kommentar
Kuff1 Skrevet 1. mars 2008 Rapporter Del Skrevet 1. mars 2008 (endret) Djises det der ser fett ut! Gleder meg til å teste det ut Lineplx du kan kjøpe det på Playstation Store for litt mer enn 200kr, eller du kan kjøpe det i vanlig butikk der det koster litt mer, men da får du med et headset/mic i pakken. Jeg syns det er lettest å kjøpe det på Playstation Store for da er det jo bare å laste ned og spille med en gang. Endret 1. mars 2008 av Diskusjon-Unit Lenke til kommentar
Lineplx Skrevet 2. mars 2008 Rapporter Del Skrevet 2. mars 2008 Djises det der ser fett ut! Gleder meg til å teste det ut Lineplx du kan kjøpe det på Playstation Store for litt mer enn 200kr, eller du kan kjøpe det i vanlig butikk der det koster litt mer, men da får du med et headset/mic i pakken. Jeg syns det er lettest å kjøpe det på Playstation Store for da er det jo bare å laste ned og spille med en gang. takker Lenke til kommentar
