Ploppelopp Skrevet 19. februar 2008 Del Skrevet 19. februar 2008 Hei, Vet ikke om denne tråden bør ligge på dette forumet, for PC`n min virker strålende. Men det er en ting jeg ikke skjønner noe av. Når jeg Kjører CPUID HWmonitor så får jeg opp noe som heter Winbond W83627DHG. Se HWmonitor print: Hardware Monitor 1.0.6.0 ----------------------------------------------------- Mainboard Vendor http://www.abit.com.tw/ Mainboard Model IN9 32X MAX(680i-MCP55PXE) (0x66F - 0xF45576DC) LPCIO ----------------------------------------------------- Vendor Winbond Model W83627DHG Vendor ID 0x5CA3 Chip ID 0xA0 Revision ID 0x23 Config Mode I/O address 0x2E Dump config mode register space, LDN = 0xB 0 1 2 3 4 5 6 7 8 9 A B C D E F 00 FF FF FF FF FF FF FF 0B FF FF FF FF FF FF FF FF 10 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 20 A0 23 FF 00 84 00 00 FF 50 00 7E 00 EA 01 00 FF 30 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 60 02 90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Hardware monitor ----------------------------------------------------- Winbond W83627DHG hardware monitor Voltage sensor 0 1.34 Volts [0xA8] (CPU VCORE) Voltage sensor 1 8.53 Volts [0x99] (+12V) Voltage sensor 2 3.23 Volts [0xCA] (AVCC) Voltage sensor 3 3.23 Volts [0xCA] (+3.3V) Voltage sensor 4 1.37 Volts [0xAB] (VIN1) Voltage sensor 5 3.70 Volts [0x9A] (+5V) Voltage sensor 6 1.21 Volts [0x97] (VIN3) Temperature sensor 0 45°C (112°F) [0x2D] (SYSTIN) Temperature sensor 1 75°C (166°F) [0x16A] (CPUTIN) Dump hardware monitor LPC Register space, base address = 0x0290 bank 0 0 1 2 3 4 5 6 7 8 9 A B C D E F 00 04 FF 04 FF 01 00 00 00 01 01 01 01 3C 3C 0A 0A 10 04 FF 00 00 00 01 01 3C 43 17 00 00 FF FF FF C4 20 A8 99 CA CA AC 9A 97 2D FF FF FF DA 00 44 E4 80 30 01 20 12 00 08 90 84 00 44 00 5A A0 08 11 0A FF 40 03 DE 1F FF FF FF 07 55 2D 00 00 44 10 95 80 5C 50 FF FF 00 FF FF FF 00 80 C1 70 FF FF 19 04 04 05 60 04 FF 40 00 01 01 3C FF 01 FF 01 FF FF FF FF FF 70 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 80 04 FF 04 FF 01 00 00 00 01 01 01 01 3C 3C 0A 0A 90 04 FF 00 00 00 01 01 3C 43 17 00 00 FF FF FF C4 A0 A8 99 CA CA AC 9A 97 2D FF FF FF DA 00 44 E4 80 B0 01 20 12 00 08 90 84 00 44 00 5A A0 08 11 0A FF C0 03 00 10 FF FF FF 07 55 2D 00 00 44 10 95 80 5C D0 FF FF 00 FF FF FF 00 80 C1 70 FF FF 19 04 04 05 E0 04 FF 40 00 01 01 3C FF 01 FF 01 FF FF FF FF FF F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF bank 1 50 B5 80 00 4B 00 50 06 FE FF FF FF FF FF FF FF FF bank 2 50 EF 00 00 4B 00 50 1E 02 FF FF FF FF FF FF FF FF bank 3 50 04 02 03 03 00 04 01 00 00 07 00 B0 84 03 00 00 bank 4 50 39 13 FF 00 00 00 00 0A 4C CE 1D B9 09 5D 20 7F bank 5 50 C8 08 08 FF 22 00 A1 01 00 18 00 00 00 00 00 00 Hardware monitor ----------------------------------------------------- Winbond W83627DHG hardware monitor Voltage sensor 0 1.34 Volts [0xA8] (CPU VCORE) Voltage sensor 1 8.53 Volts [0x99] (+12V) Voltage sensor 2 3.23 Volts [0xCA] (AVCC) Voltage sensor 3 3.23 Volts [0xCA] (+3.3V) Voltage sensor 4 1.38 Volts [0xAC] (VIN1) Voltage sensor 5 3.70 Volts [0x9A] (+5V) Voltage sensor 6 1.21 Volts [0x97] (VIN3) Temperature sensor 0 45°C (112°F) [0x2D] (SYSTIN) Temperature sensor 1 75°C (166°F) [0x16A] (CPUTIN) Dump hardware monitor SMBus Register space, base address = 0x01C80 SMBus request at channel 0x0, address 0x2D bank 0 0 1 2 3 4 5 6 7 8 9 A B C D E F 00 04 FF 04 FF 01 00 00 00 01 01 01 01 3C 3C 0A 0A 10 04 FF 00 00 00 01 01 3C 43 17 00 00 FF FF FF D8 20 A8 99 CA CA AB 9A 97 2D FF FF FF DA 00 44 E4 80 30 01 20 12 00 08 90 84 00 44 00 5A A0 08 11 0A FF 40 03 10 10 FF FF FF 07 55 2D 00 00 44 10 95 80 5C 50 FF FF 00 FF FF FF 00 80 C1 70 FF FF 19 04 04 05 60 04 FF 40 00 01 01 3C FF 01 FF 01 FF FF FF FF FF 70 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 80 04 FF 04 FF 01 00 00 00 01 01 01 01 3C 3C 0A 0A 90 04 FF 00 00 00 01 01 3C 43 17 00 00 FF FF FF C2 A0 A8 99 CA CA AB 9A 97 2D FF FF FF DA 00 44 E4 80 B0 01 20 12 00 08 90 84 00 44 00 5A A0 08 11 0A FF C0 03 10 10 FF FF FF 07 55 2D 00 00 44 10 95 80 5C D0 FF FF 00 FF FF FF 00 80 C1 70 FF FF 19 04 04 05 E0 04 FF 40 00 01 01 3C FF 01 FF 01 FF FF FF FF FF F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF bank 1 50 B5 00 00 4B 00 50 06 FE FF FF FF FF FF FF FF FF bank 2 50 EF 00 00 4B 00 50 1E 02 FF FF FF FF FF FF FF FF bank 3 50 03 02 03 02 07 03 02 00 00 07 00 B0 84 03 00 00 bank 4 50 00 13 FF 00 00 00 00 03 84 CE 1D B9 09 5D 20 7F bank 5 50 C8 08 08 FF 22 00 A1 01 00 18 00 00 00 00 00 00 Hardware monitor ----------------------------------------------------- abit UGuru 2005 hardware monitor Board ID 0x0019 Voltage sensor 0 1.15 Volts [0x73] (CPU Core) Voltage sensor 1 2.10 Volts [0x69] (DDR2) Voltage sensor 2 1.05 Volts [0x69] (DDR2 VTT) Voltage sensor 3 1.20 Volts [0x78] (CPU VTT) Voltage sensor 4 1.40 Volts [0x8C] (NB) Voltage sensor 5 1.53 Volts [0x99] (SB) Voltage sensor 6 1.43 Volts [0x8F] (HyperTransport) Voltage sensor 7 11.94 Volts [0xC7] (ATX +12V (24-Pin)) Voltage sensor 8 12.00 Volts [0xC8] (ATX +12V (4-Pin)) Voltage sensor 9 4.92 Volts [0xA4] (ATX +5V) Voltage sensor 10 3.34 Volts [0xA7] (ATX +3.3V) Voltage sensor 11 5.01 Volts [0xA7] (ATX 5VSB) Temperature sensor 0 32°C (89°F) [0x20] (CPU) Temperature sensor 1 28°C (82°F) [0x1C] (System) Temperature sensor 2 60°C (139°F) [0x3C] (PWM Phase 1) Temperature sensor 3 61°C (141°F) [0x3D] (PWM Phase 2) Temperature sensor 4 61°C (141°F) [0x3D] (PWM Phase 3) Temperature sensor 5 60°C (139°F) [0x3C] (PWM Phase 4) Temperature sensor 6 59°C (138°F) [0x3B] (PWM Phase 5) Fan sensor 0 2160 RPM [0x24] (CPU) Fan sensor 1 n.a. [0x0] (SYS) Fan sensor 2 n.a. [0x0] (AUX1) Fan sensor 3 1980 RPM [0x21] (AUX2) Fan sensor 4 n.a. [0x0] (AUX3) Fan sensor 5 n.a. [0x0] (AUX4) Dump hardware monitor UGuru2005 Register space, base address = 0x0E0 UGuru request at bank 0x8 0 1 2 3 4 5 6 7 8 9 A B C D E F 00 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 10 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 20 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 30 03 00 60 03 51 00 36 00 86 03 48 00 06 2C 1B 12 40 33 09 00 00 00 00 00 00 00 00 00 00 09 20 24 20 50 20 1A 03 FF 00 03 00 04 00 00 00 00 00 00 00 00 60 00 00 00 00 00 00 00 00 00 0D 0A 06 0C E1 5E 82 70 00 00 00 00 00 01 01 02 00 02 00 00 00 00 00 00 80 00 00 00 78 8C 8F 99 82 C8 A4 A8 A7 C6 69 69 00 90 19 00 64 00 7C 00 00 2E 21 1C 3E 3E 3F 3E 3D 00 A0 23 00 00 21 00 00 00 00 00 00 06 00 00 00 00 00 B0 00 00 0F 00 00 00 00 00 00 00 00 00 3E 3F 02 01 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 E0 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 F0 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 A6 Hardware monitor ----------------------------------------------------- Intel Core 2 Quad Q6600 hardware monitor Temperature sensor 0 42°C (107°F) [0x3A] (core #0) Temperature sensor 3 37°C (98°F) [0x3F] (core #3) Temperature sensor 1 40°C (103°F) [0x3C] (core #1) Temperature sensor 2 37°C (98°F) [0x3F] (core #2) Dump hardware monitor Hardware monitor ----------------------------------------------------- GeForce 8800 GTX hardware monitor Temperature sensor 0 44°C (111°F) [0x2C] (GPU Core) Dump hardware monitor Hardware monitor ----------------------------------------------------- WDC WD2500JD-55HBB0 hardware monitor Temperature sensor 0 28°C (82°F) [0x1C] (HDD) Dump hardware monitor Hardware monitor ----------------------------------------------------- WDC WD2500JD-55HBB0 hardware monitor Temperature sensor 0 27°C (80°F) [0x1B] (HDD) Dump hardware monitor Hardware monitor ----------------------------------------------------- WDC WD2500JD-55HBB0 hardware monitor Temperature sensor 0 23°C (73°F) [0x17] (HDD) Dump hardware monitor Hardware monitor ----------------------------------------------------- WDC WD2500JD-55HBB0 hardware monitor Temperature sensor 0 27°C (80°F) [0x1B] (HDD) Dump hardware monitor Processors Map ------------------------------------------------------------------------------------ Number of processors 1 Number of threads 4 Processor 0 -- Core 0 -- Thread 0 -- Core 3 -- Thread 0 -- Core 1 -- Thread 0 -- Core 2 -- Thread 0 Processors Information ------------------------------------------------------------------------------------ Processor 1 (ID = 0) Number of cores 4 (max 4) Number of threads 4 (max 4) Name Intel Core 2 Quad Q6600 Codename Kentsfield Specification Intel® Core2 Quad CPU Q6600 @ 2.40GHz Package Socket 775 LGA (platform ID = 4h) CPUID 6.F.B Extended CPUID 6.F Core Stepping G0 Technology 65 nm Core Speed 2372.2 MHz Stock frequency 2400 MHz Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size FID/VID Control yes FID range 6.0x - 9.0x max VID 1.325 V Features XD, VT Thread dumps ------------------------------------------------------------------------------------ CPU Thread 0 APIC ID 0 Topology Processor ID 0, Core ID 0, Thread ID 0 Type 01008005h Max CPUID level 0000000Ah Max CPUID ext. level 80000008h Function eax ebx ecx edx 0x00000000 0x0000000A 0x756E6547 0x6C65746E 0x49656E69 0x00000001 0x000006FB 0x00040800 0x0000E3BD 0xBFEBFBFF 0x00000002 0x05B0B101 0x005657F0 0x00000000 0x2CB43049 0x00000003 0x00000000 0x00000000 0x00000000 0x00000000 0x00000004 0x0C000121 0x01C0003F 0x0000003F 0x00000001 0x00000004 0x0C000122 0x01C0003F 0x0000003F 0x00000001 0x00000004 0x0C004143 0x03C0003F 0x00000FFF 0x00000001 0x00000005 0x00000040 0x00000040 0x00000003 0x00000020 0x00000006 0x00000001 0x00000002 0x00000001 0x00000000 0x00000007 0x00000000 0x00000000 0x00000000 0x00000000 0x00000008 0x00000400 0x00000000 0x00000000 0x00000000 0x00000009 0x00000000 0x00000000 0x00000000 0x00000000 0x0000000A 0x07280202 0x00000000 0x00000000 0x00000503 0x80000000 0x80000008 0x00000000 0x00000000 0x00000000 0x80000001 0x00000000 0x00000000 0x00000001 0x20100000 0x80000002 0x65746E49 0x2952286C 0x726F4320 0x4D542865 0x80000003 0x51203229 0x20646175 0x20555043 0x51202020 0x80000004 0x30303636 0x20402020 0x30342E32 0x007A4847 0x80000005 0x00000000 0x00000000 0x00000000 0x00000000 0x80000006 0x00000000 0x00000000 0x10008040 0x00000000 0x80000007 0x00000000 0x00000000 0x00000000 0x00000000 0x80000008 0x00003024 0x00000000 0x00000000 0x00000000 Cache descriptor Level 1 D 32 KB 1 threads Cache descriptor Level 1 I 32 KB 1 threads Cache descriptor Level 2 U 4 MB 2 threads MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00900 MSR 0x000000E8 edx = 0x00000028 eax = 0x61C5F7B2 MSR 0x00000017 edx = 0x00100000 eax = 0x88408928 MSR 0x000000CD edx = 0x00000000 eax = 0x00000800 MSR 0x0000003F edx = 0x00000000 eax = 0x00000000 MSR 0x000000CE edx = 0x001B0928 eax = 0x7F7F071A MSR 0x000001A0 edx = 0x00000040 eax = 0x62972489 MSR 0x000000EE edx = 0x00000000 eax = 0x837D4B00 MSR 0x0000011E edx = 0x00000000 eax = 0xBE702109 MSR 0x0000019C edx = 0x00000000 eax = 0x883A0000 MSR 0x00000198 edx = 0x09280928 eax = 0x06000928 MSR 0x00000199 edx = 0x00000000 eax = 0x00000928 CPU Thread 1 APIC ID 3 Topology Processor ID 0, Core ID 3, Thread ID 0 Type 01008005h Max CPUID level 0000000Ah Max CPUID ext. level 80000008h Function eax ebx ecx edx 0x00000000 0x0000000A 0x756E6547 0x6C65746E 0x49656E69 0x00000001 0x000006FB 0x03040800 0x0000E3BD 0xBFEBFBFF 0x00000002 0x05B0B101 0x005657F0 0x00000000 0x2CB43049 0x00000003 0x00000000 0x00000000 0x00000000 0x00000000 0x00000004 0x0C000121 0x01C0003F 0x0000003F 0x00000001 0x00000004 0x0C000122 0x01C0003F 0x0000003F 0x00000001 0x00000004 0x0C004143 0x03C0003F 0x00000FFF 0x00000001 0x00000005 0x00000040 0x00000040 0x00000003 0x00000020 0x00000006 0x00000001 0x00000002 0x00000001 0x00000000 0x00000007 0x00000000 0x00000000 0x00000000 0x00000000 0x00000008 0x00000400 0x00000000 0x00000000 0x00000000 0x00000009 0x00000000 0x00000000 0x00000000 0x00000000 0x0000000A 0x07280202 0x00000000 0x00000000 0x00000503 0x80000000 0x80000008 0x00000000 0x00000000 0x00000000 0x80000001 0x00000000 0x00000000 0x00000001 0x20100000 0x80000002 0x65746E49 0x2952286C 0x726F4320 0x4D542865 0x80000003 0x51203229 0x20646175 0x20555043 0x51202020 0x80000004 0x30303636 0x20402020 0x30342E32 0x007A4847 0x80000005 0x00000000 0x00000000 0x00000000 0x00000000 0x80000006 0x00000000 0x00000000 0x10008040 0x00000000 0x80000007 0x00000000 0x00000000 0x00000000 0x00000000 0x80000008 0x00003024 0x00000000 0x00000000 0x00000000 Cache descriptor Level 1 D 32 KB 1 threads Cache descriptor Level 1 I 32 KB 1 threads Cache descriptor Level 2 U 4 MB 2 threads MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00800 MSR 0x000000E8 edx = 0x0000001B eax = 0x74748EC4 MSR 0x00000017 edx = 0x00100000 eax = 0x88408928 MSR 0x000000CD edx = 0x00000000 eax = 0x00000800 MSR 0x0000003F edx = 0x00000000 eax = 0x00000000 MSR 0x000000CE edx = 0x001B0928 eax = 0x7F7F071A MSR 0x000001A0 edx = 0x00000040 eax = 0x62972489 MSR 0x000000EE edx = 0x00000000 eax = 0x837D4B00 MSR 0x0000011E edx = 0x00000000 eax = 0xBE702109 MSR 0x0000019C edx = 0x00000000 eax = 0x883F0000 MSR 0x00000198 edx = 0x09280928 eax = 0x06000928 MSR 0x00000199 edx = 0x00000000 eax = 0x00000928 CPU Thread 2 APIC ID 1 Topology Processor ID 0, Core ID 1, Thread ID 0 Type 01008005h Max CPUID level 0000000Ah Max CPUID ext. level 80000008h Function eax ebx ecx edx 0x00000000 0x0000000A 0x756E6547 0x6C65746E 0x49656E69 0x00000001 0x000006FB 0x01040800 0x0000E3BD 0xBFEBFBFF 0x00000002 0x05B0B101 0x005657F0 0x00000000 0x2CB43049 0x00000003 0x00000000 0x00000000 0x00000000 0x00000000 0x00000004 0x0C000121 0x01C0003F 0x0000003F 0x00000001 0x00000004 0x0C000122 0x01C0003F 0x0000003F 0x00000001 0x00000004 0x0C004143 0x03C0003F 0x00000FFF 0x00000001 0x00000005 0x00000040 0x00000040 0x00000003 0x00000020 0x00000006 0x00000001 0x00000002 0x00000001 0x00000000 0x00000007 0x00000000 0x00000000 0x00000000 0x00000000 0x00000008 0x00000400 0x00000000 0x00000000 0x00000000 0x00000009 0x00000000 0x00000000 0x00000000 0x00000000 0x0000000A 0x07280202 0x00000000 0x00000000 0x00000503 0x80000000 0x80000008 0x00000000 0x00000000 0x00000000 0x80000001 0x00000000 0x00000000 0x00000001 0x20100000 0x80000002 0x65746E49 0x2952286C 0x726F4320 0x4D542865 0x80000003 0x51203229 0x20646175 0x20555043 0x51202020 0x80000004 0x30303636 0x20402020 0x30342E32 0x007A4847 0x80000005 0x00000000 0x00000000 0x00000000 0x00000000 0x80000006 0x00000000 0x00000000 0x10008040 0x00000000 0x80000007 0x00000000 0x00000000 0x00000000 0x00000000 0x80000008 0x00003024 0x00000000 0x00000000 0x00000000 Cache descriptor Level 1 D 32 KB 1 threads Cache descriptor Level 1 I 32 KB 1 threads Cache descriptor Level 2 U 4 MB 2 threads MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00800 MSR 0x000000E8 edx = 0x0000001A eax = 0xF4DDD09F MSR 0x00000017 edx = 0x00100000 eax = 0x88408928 MSR 0x000000CD edx = 0x00000000 eax = 0x00000800 MSR 0x0000003F edx = 0x00000000 eax = 0x00000000 MSR 0x000000CE edx = 0x001B0928 eax = 0x7F7F071A MSR 0x000001A0 edx = 0x00000040 eax = 0x62972489 MSR 0x000000EE edx = 0x00000000 eax = 0x837D4B00 MSR 0x0000011E edx = 0x00000000 eax = 0xBE702109 MSR 0x0000019C edx = 0x00000000 eax = 0x883C0000 MSR 0x00000198 edx = 0x09280928 eax = 0x06000928 MSR 0x00000199 edx = 0x00000000 eax = 0x00000928 CPU Thread 3 APIC ID 2 Topology Processor ID 0, Core ID 2, Thread ID 0 Type 01008005h Max CPUID level 0000000Ah Max CPUID ext. level 80000008h Function eax ebx ecx edx 0x00000000 0x0000000A 0x756E6547 0x6C65746E 0x49656E69 0x00000001 0x000006FB 0x02040800 0x0000E3BD 0xBFEBFBFF 0x00000002 0x05B0B101 0x005657F0 0x00000000 0x2CB43049 0x00000003 0x00000000 0x00000000 0x00000000 0x00000000 0x00000004 0x0C000121 0x01C0003F 0x0000003F 0x00000001 0x00000004 0x0C000122 0x01C0003F 0x0000003F 0x00000001 0x00000004 0x0C004143 0x03C0003F 0x00000FFF 0x00000001 0x00000005 0x00000040 0x00000040 0x00000003 0x00000020 0x00000006 0x00000001 0x00000002 0x00000001 0x00000000 0x00000007 0x00000000 0x00000000 0x00000000 0x00000000 0x00000008 0x00000400 0x00000000 0x00000000 0x00000000 0x00000009 0x00000000 0x00000000 0x00000000 0x00000000 0x0000000A 0x07280202 0x00000000 0x00000000 0x00000503 0x80000000 0x80000008 0x00000000 0x00000000 0x00000000 0x80000001 0x00000000 0x00000000 0x00000001 0x20100000 0x80000002 0x65746E49 0x2952286C 0x726F4320 0x4D542865 0x80000003 0x51203229 0x20646175 0x20555043 0x51202020 0x80000004 0x30303636 0x20402020 0x30342E32 0x007A4847 0x80000005 0x00000000 0x00000000 0x00000000 0x00000000 0x80000006 0x00000000 0x00000000 0x10008040 0x00000000 0x80000007 0x00000000 0x00000000 0x00000000 0x00000000 0x80000008 0x00003024 0x00000000 0x00000000 0x00000000 Cache descriptor Level 1 D 32 KB 1 threads Cache descriptor Level 1 I 32 KB 1 threads Cache descriptor Level 2 U 4 MB 2 threads MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00800 MSR 0x000000E8 edx = 0x0000001B eax = 0xA2A5349B MSR 0x00000017 edx = 0x00100000 eax = 0x88408928 MSR 0x000000CD edx = 0x00000000 eax = 0x00000800 MSR 0x0000003F edx = 0x00000000 eax = 0x00000000 MSR 0x000000CE edx = 0x001B0928 eax = 0x7F7F071A MSR 0x000001A0 edx = 0x00000040 eax = 0x62972489 MSR 0x000000EE edx = 0x00000000 eax = 0x837D4B00 MSR 0x0000011E edx = 0x00000000 eax = 0xBE702109 MSR 0x0000019C edx = 0x00000000 eax = 0x883F0000 MSR 0x00000198 edx = 0x09280928 eax = 0x06000928 MSR 0x00000199 edx = 0x00000000 eax = 0x00000928 Drive ----------------------------------------------------- Name WDC WD2500JD-55HBB0 Drive ----------------------------------------------------- Name WDC WD2500JD-55HBB0 Drive ----------------------------------------------------- Name WDC WD2500JD-55HBB0 Drive ----------------------------------------------------- Name WDC WD2500JD-55HBB0 Denne viser opp til 106 grader etter spilling på sensor 2. Hva er dette / Er dette noe å bry seg om? Hva kan eventuelt gjøres? Har god kjøling ellers, og det meste annet ligger under 50 grader. På forhånd takk. Gi gjerne tilbakemeldinger hvis dere legger merke til annet som kan gjøres for å optimalisere systemet (Og ja, det skal overklokkes, men vil ha alt på G med standard instillinger først. Lenke til kommentar
Syar-2003 Skrevet 19. februar 2008 Del Skrevet 19. februar 2008 Winbond= chip på hovedkortet med sensorer/data innhenting som oppgave. Dud avlesninger som 0/255 osv. betyr vanligvis at sensor nr/port ikke er wiret/tilkoplet. Den du sier blir 106°C må du evt sammenlikne med hovedkortets mon utility for å finne igjen for å bli sikker på hva den er eller om den er en dud avlesning. Sjekk også evt oppmot gfx kort . Siden Abit kaller denne winbond for qguru chip betyr det også at de har implementert denne på "sin" egen måte. Alle andre program enn Abits egne kan da gi feilaktige avlesninger av enkelte sensor id er. Lenke til kommentar
kaeksen Skrevet 19. februar 2008 Del Skrevet 19. februar 2008 Winbond,,er ikke det et chipset som heter det? Lenke til kommentar
Spirre Skrevet 19. februar 2008 Del Skrevet 19. februar 2008 det var også en chip på rambrikker for noen år sia. spesiellt twinmos winbond bh-5 brikkene var veldig populære pga gode overklokkingsegenskaper. Lenke til kommentar
Ploppelopp Skrevet 19. februar 2008 Forfatter Del Skrevet 19. februar 2008 (endret) Winbond= chip på hovedkortet med sensorer/data innhenting som oppgave.Dud avlesninger som 0/255 osv. betyr vanligvis at sensor nr/port ikke er wiret/tilkoplet. Den du sier blir 106°C må du evt sammenlikne med hovedkortets mon utility for å finne igjen for å bli sikker på hva den er eller om den er en dud avlesning. Sjekk også evt oppmot gfx kort . Siden Abit kaller denne winbond for qguru chip betyr det også at de har implementert denne på "sin" egen måte. Alle andre program enn Abits egne kan da gi feilaktige avlesninger av enkelte sensor id er. Supert, da fikk jeg svar på det jeg lurte på. GPU og CPU ligger på ca 40 grader idle, så da skal den være grei. Får legge inn uguru søppelet til Abit igjen og ta en titt der da. EDIT: Kom på en liten ting til: Temperature sensor 2 60°C (139°F) [0x3C] (PWM Phase 1) Temperature sensor 3 61°C (141°F) [0x3D] (PWM Phase 2) Temperature sensor 4 61°C (141°F) [0x3D] (PWM Phase 3) Temperature sensor 5 60°C (139°F) [0x3C] (PWM Phase 4) Temperature sensor 6 59°C (138°F) [0x3B] (PWM Phase 5) Disse målingene viser ca 20 grader mer en alt annet, er dette noe av det samme; Altså sensorer på HK som kun Abit holder track på? Endret 19. februar 2008 av Ploppelopp Lenke til kommentar
Syar-2003 Skrevet 19. februar 2008 Del Skrevet 19. februar 2008 PWM er hovedkortets power modul kretser så det er naturlig at disse blir "litt" varme . Lenke til kommentar
Ploppelopp Skrevet 19. februar 2008 Forfatter Del Skrevet 19. februar 2008 PWM er hovedkortets power modul kretser så det er naturlig at disse blir "litt" varme . Hmmm, ok? Gjør det noe at dette blir så varmt? Hva kan jeg eventuelt gjøre for å holde varmen nede (denne vlir jo 106 selv uten load)? Lenke til kommentar
