Hvordan øke volten på MSI P965 NEO-F?
Test og omtale av kortet.
The P965 Neo-F Cell Menu is quite bare compared to the nForce 570 SLI based K9N Platinum. For instance, on the Neo-F you don't have any options for boosting CPU or chipset voltage.
As I mentioned above, you don't have the ability to adjust CPU or chipset voltage, but you do have a wide range of voltage adjustment for your DDR2 memory.
