Spill PC ca 10K for en venn
Hovedkort:
P5E WS Professional
The Extreme Workstation Engine with Multiple High Speed I/O
- Support Intel® next generation 45nm Multi-core CPU
- Intel Core™2 Extreme / Core™2 Ready
- Intel® Quad-core CPU Ready
- DDR2 1200(O.C.)/1066/800/667
- FSB 1600/1333/1066/800
- Dual PCIe 2.0 x 16 Graphics
- PCI-X Architecture
Minne
Mushkin DDR2 2048MB extreme Performance
XP2-8500 2x1024MB 1066MHz. (5.5.4.12)
Frequency: 1066Mhz
Latency: 5-5-4-12
Parity: Unbuffered
Voltage: 2.2V-2.35V
Pins: 240
Module: 128Mx64
Chip: 64x8
CPU
Intel Core 2 Duo E8400 3.0GHz Socket775
6MB, BOXED m/vifte 1333Mhz
Intel® Core™2 Duo processor is the new brand name for our next-generation energy-efficient performance desktop and mobile processors. Formerly known by their codenames Conroe and Merom, the Intel® Core™2 processors for desktop and mobile computers are based on the Intel® Core™ microarchitecture, Intel's new industry-leading foundation for all mobile, desktop and server platforms moving forward.
Processor Speed: E8400 / 3.00GHz
Processor Interface: Socket 775
Processor Class: Core 2 Duo
Processor Core: Wolfdale
Bus Speed: 1333MHz
Additional Technologies: Intel® EM64T
Enhanced Intel Speedstep
Dual-Core
Enhanced Halt State
Execute Disable Bit
Intel® Virtualization
Intel® Thermal Monitor 2
Architecture: 45 nm
Wattage: 65W
Core Stepping: C0
Fan: Included
Kabinett
Antec Performance One P180 Sort
ATX miditower u/PSU
Spesifikasjoner
Størrelse: Midi
Formfaktor: ATX
5.25 brønner: 4
3.5 brønner, eksterne: 1
3.5 brønner, interne: 6
Vifteplasser: 5
Konstruksjonsmateriale: Aluminium
Lyd I/O i front: Ja
USB-porter i front: Ja
Firewire-porter i front: Ja
Vekt: 14 Kg
http://www.hardware.no/artikkel/17831
PSU
MIST, 600W, avtagbare kabler, Rev.3
- Ny versjon, ATX 2.2, med kabel kit
GPU
Gainward GeForce 8800GTS 512MB PCIe 2.0
HDCP, 2x DVI, 650 MHz.
Gainward GeForce 8800GTS 512MB PCIe 2.0 skjermkort
Dette skjermkortet støtter f.eks. DirectX 10 og PCI-Express 2.0 som betyr en dobling i teoretisk båndbredde for den som har et kompatibelt hovedkort. Men standarden er også full bakoverkompatibel, da selvfølgelig med "vanlig" PCIe-fart. I tillegg har kortet 2. generasjon av nVidias PureVideo, altså bedre maskinvareakselerasjon for HD-dekoding (H.264/MPEG-4 komprimering). Støtter Shader Model 4.0, OpenGL 2.0, HDCP, NVIDIA Quantum (Advanced Shader Processors architected for physics computation).
Spesifikasjoner
Enhetstype Grafikkadapter
Utførelse Plugginnkort
Grensesnittype PCI Express 2.0 x16
Prosessor / Minne
Grafisk prosessor / leverandør NVIDIA GeForce 8800 GTS
Kjerneklokkehastighet 650 MHz
Installert videominne 512 MB
Teknologi GDDR3 SDRAM 256-bit
Memory Clock Speed 1.94 GHz
Egenskaper Nvidia SLI Multi-GPU Technology, Extreme HD ready (XHD), Nvidia Quantum Effects Technology
Videoutgang
Maks. oppløsning (ekstern) 2560 x 1600
Støttede API OpenGL 2.0, DirectX 9.0c, DirectX 10
TV-grensesnitt HDTV-utlinje
Digital videostandard Digital Visual Interface (DVI)
HDCP-kompatibel Ja
Ekspansjon / Tilkoplinger
Grensesnitt 2 x DVI-I (dobbeltlenke) - 29-pin kombinert DVI
1 x HDTV-utgang
Kompatible spor 1 x PCI Express 2.0 x16
Diverse
Kabler inkludert 1 x video adapter
DVI-VGA-adapter
Programvare / Systemkrav
Inkludert programvare Drivers & Utilities, Gainward EXPERTool
OS påkrevd Microsoft Windows Vista / 2000 / XP
Perifere / grensesnittenheter CD-ROM, ekstra strømkontakt, tilgrensende PCI-spor, 450 W-strømforsyning
Systemkravdetaljer Pentium 4 - RAM 512 MB
Windows Vista Windows Vista Ready
HDD
Western Digital 500GB S-ATA II 7200 RPM
Caviar Special Edition 16MB cache
Spesifikasjoner
Størrelse: 500 GB
Omdreiningshastighet: 7200 RPM
Grensesnitt: S-ATA
Gjennomsnittlig søketid: 8.9ms
Cache: 16 MB
NCQ-støtte: Ja
Lydnivå: 31db
Båndbredde: Serial ATA/300
Type: 3.5 tommer
Ny versjon med 2 plater
DREV
Samsung DVD brenner SH-S203D
Svart, SATA, bulk SH-S203D/BEBN
Hovedspesifikasjon
Produktbeskrivelse: Samsung Super-WriteMaster SH-S203D - DVD±RW (±R DL) / DVD-RAM-stasjon - Serial ATA
Enhetstype: DVD±RW (±R DL) / DVD-RAM-stasjon
Utførelse: Intern
Innbyggingsfarge: Svart
Grensesnitt: Serial ATA
Dimensjoner (BxDxH): 14.8 cm x 17 cm x 4.2 cm
Vekt: 0.8 kg
Optisk lagring: DVD±RW (±R DL) / DVD-RAM - 5.25" x 1/2H
Lesehastighet: 48x (CD) / 16x (DVD)
Skrivehastighet: 48x (CD) / 20x (DVD±R) / 12x (DVD-R DL) / 16x (DVD+R DL)
Overskrivingshastighet: 32x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 12x (DVD-RAM)
OS påkrevd: Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Vista
Noen formeninger/anbefalinger??? Noe som bør byttes ut? Trenger ev en grei LCD skjerm til spilling ca 20-22" widescreen.. Noen anbefalinger der? Ikke så altfor dyr..
Hovedkort:
P5E WS Professional
Minne
Frequency: 1066Mhz
Latency: 5-5-4-12
Parity: Unbuffered
Voltage: 2.2V-2.35V
Pins: 240
Module: 128Mx64
Chip: 64x8
CPU
Bus Speed: 1333MHz
Dual-Core
Enhanced Halt State
Execute Disable Bit
Architecture: 45 nm
Wattage: 65W
Core Stepping: C0
Fan: Included
Kabinett
ATX miditower u/PSU
Spesifikasjoner
Størrelse: Midi
Formfaktor: ATX
5.25 brønner: 4
Vifteplasser: 5
Lyd I/O i front: Ja
Vekt: 14 Kg
PSU
GPU
Spesifikasjoner
Prosessor / Minne
Videoutgang
HDCP-kompatibel Ja
1 x HDTV-utgang
Diverse
DVI-VGA-adapter
HDD
Spesifikasjoner
Størrelse: 500 GB
Grensesnitt: S-ATA
Cache: 16 MB
NCQ-støtte: Ja
Lydnivå: 31db
Type: 3.5 tommer
DREV
Hovedspesifikasjon
Utførelse: Intern
Vekt: 0.8 kg
Hadde eg kjøpt nå ville jeeg ha valgt 3870 X2, og i senere tid kjøpt et til så det blir crossfireX
Link: https://prisguiden.no/product.php?productId=89064
Edit:Til skjerm ville jeg ha valgt Samsung, denne for eksempel : https://prisguiden.no/product.php?productId=62686
Endret av robert166
