MindTooth Skrevet 15. februar 2008 Rapporter Del Skrevet 15. februar 2008 It's well known that the next Xbox 360 motherboard is going to be Jasper and it going to have both a 65 nm CPU and a 65 nm GPU. Jasper is going to be a major advancement in reliability since it is going to run much quieter than previous Xbox 360 systems. Jasper's reliability is in part to the fact that there is no place on the motherboard that is going to be running as hot or as much power as previous Xbox 360 systems, also it might run a lot quieter since it will not need as much power. The Opus project is a "Falcon" generation motherboard designed to fit in a Xenon case. You can expect an 90 nm GPU but a 65 nm CPU. Opus solves a major hardware recycling and inventory problem since Microsoft currently has millions of used Xenon cases from RRODed dead systems and this lets them use most of the good parts from the millions of dead Xenons but with a newer tested more reliable motherboard. At the heart of a Valhalla Xbox 360 is a combined 65nm CPU and 65nm GPU on a unified super chip. This also would only need one cooling system and be much quieter and hopefully more reliable than previous Xbox systems (if they include hardware JTAG testing reporting into the design). Kilde: 8bitJoystick.com Lenke til kommentar
iStephano Skrevet 15. februar 2008 Rapporter Del Skrevet 15. februar 2008 Godt og se MS jobber med saken for en gangs skyld. Lenke til kommentar
Gjest Slettet+981234789 Skrevet 15. februar 2008 Rapporter Del Skrevet 15. februar 2008 kjøpe ny når Valhalla kommer da, men den kommer vell sikkert kanskje nærme slutten på 360 livsyklus.. Lenke til kommentar
Laland Skrevet 15. februar 2008 Rapporter Del Skrevet 15. februar 2008 Kommer til å skaffe meg en Arcade når Jasper/Valhalla er i omløp! Lenke til kommentar
MindTooth Skrevet 15. februar 2008 Forfatter Rapporter Del Skrevet 15. februar 2008 Håper de lager en ny SDK med innebygd Wi-Fi, og som er musestille. Birger Lenke til kommentar
Walts Skrevet 15. februar 2008 Rapporter Del Skrevet 15. februar 2008 høres bra ut, går til innkjøp av ny xbox om de blir med stillegående =) Lenke til kommentar
Lakus Skrevet 16. februar 2008 Rapporter Del Skrevet 16. februar 2008 (endret) Passer meg ganske bra egentlig, da jeg i disse dager planlegger totalrenovering av både Flatskjerm og lydanlegg. Da kan jeg jo kjøpe meg en nyere versjon av 360 etter dette samtidig som jeg plukker opp en 120GB HDD. Endret 16. februar 2008 av Lakus Lenke til kommentar
TaWret Skrevet 16. februar 2008 Rapporter Del Skrevet 16. februar 2008 Nettopp kjøpt Falcon, så blir dyrt om jeg igjen skal selge/kjøpe ny versjon. Har en pc som bråker som et uvær, så litt støy fra 360`en gjør ingen ting. Lenke til kommentar
