Hva skal jeg velge?
Phoenix)
Jeg har en Dell maskin:
CPU
CPU Properties
CPU Type Intel Pentium 4, 1600 MHz (4 x 400)
CPU Alias P68, Willamette, A80528
Original Clock 1600 MHz
L1 Trace Cache 12K Instructions
L1 Data Cache 8 KB
L2 Cache 256 KB (On-Die, ATC, Full-Speed)
CPU Physical Info
Package Type 478 Pin uPGA
Package Size 3.50 cm x 3.50 cm
Transistors 42 million
Process Technology 6M, 0.18 um, CMOS
Die Size 217 mm2
Core Voltage 1.75 V
I/O Voltage 1.75 V
Typical Power 55.3 - 75.3 W (depending on clock speed)
Maximum Power 72 - 100 W (depending on clock speed)
HK:
Front Side Bus Properties
Bus Type Intel NetBurst
Bus Width 64-bit
Real Clock 100 MHz (QDR)
Effective Clock 400 MHz
Bandwidth 3200 MB/s
Memory Bus Properties
Bus Type SDR SDRAM
Bus Width 64-bit
Real Clock 133 MHz
Effective Clock 133 MHz
Bandwidth 1067 MB/s
Chipset Bus Properties
Bus Type Intel Hub Interface
Bus Width 8-bit
Real Clock 67 MHz (QDR)
Effective Clock 267 MHz
Bandwidth 267 MB/s
RAM:
Memory Module Properties
Module Name Kingston 32MX64PC133CL3168
Serial Number 37032202
Module Size 256 MB (1 rows, 4 banks)
Module Type Unbuffered
Memory Type SDRAM
Memory Speed PC133 (133 MHz)
Module Width 64 bit
Module Voltage LVTTL
Error Detection Method None
Refresh Rate Reduced (7.8 us), Self-Refresh
Highest CAS Latency 3.0 (7.5 ns @ 133 MHz)
2nd Highest CAS Latency 2.0 (10.0 ns @ 100 MHz)
Jeg har to slike brikker. Systemet har tilsammen 512MB SDRAM
AGP:
AGP Properties
AGP Version 2.00
AGP Status Enabled
AGP Aperture Size 128 MB
Supported AGP Speeds 1x, 2x, 4x
Current AGP Speed 4x
Fast-Write Supported, Disabled
Side Band Addressing Supported, Disabled
Jeg er ikke fornøyd med mitt GF3 kort og skal kjøpe meg et nytt kort. Jeg skulle kjøpe et GF4 ti4600 kort, men det viser seg at det er umulig å få tak i et slikt kort i dag. Så jeg lurer på hva jeg skal velge... Hovedkortet mitt støtter max 4x AGP, men etter som jeg har forstått det så kan skjermkort med støtte for 8x AGP kjøre på et et hovedkort som støtter max 4x AGP uten noen store tap i ytelsen. Jeg har tenkt på hercules raedon 9700 pro, men jeg er usikker på hvor mye ytelsen i spill vil bli forbedret på dette systemet.
9700 er klokket 15% lavere enn 9700pro (325 vs. 275MHz på både minne og GPU). Forskjellen i pris er derimot hele 33% (ca 3000 vs. ca 2000 kr) 9700 kortet kan også enkelt overklokkes til pro-hastighet.
Ellers så har du plass til en raskere CPU i det hovedkortet. f.eks en P4 - 2,6GHz(med 100MHz "400" buss)
Men det er synd du valgte en maskin med så tregt minne...
Hvilke(t) spill er det du får lav ytelse i ?
Bestillte hercules 9700 pro for to dager siden, de jeg bestillte til skulle få inn kortet i dag :smile:
Jeg spiller bare to spill, diablo2 og warcraft3. I diablo2 spiller jeg som regel med 10 FPS +/- hvis jeg spiller sammen med andre, i warcraft3 begynner det å hakke når det kommer mange units inn på skjermen, noe som er veldig irriterende. :grumpy:
Så denne nå:
En slik mener du?
Jeg har dårlig erfaring med å sette i ny CPU. Jeg prøvde det på min gamle IBM maskin, men den kjører fortsatt på 300MHz :p
Uansett så er dette som sagt en Dell maskin, er det bare å pakke i CPU'n? Jeg tror jeg har lest at P4 hovedkort finner hastigheten til CPU'n av seg selv? Hvis ikke, hva skal jeg gjøre da? Btw, hvor ser du at hovedkortet mitt kan kjøre en CPU på den hastigheten?
hehe, de spillene krever ikke en dritt da! Må være noe galt i systemet ditt! Sjekk hva du får i 3Dmark score! Man kan se hvor mye HK ditt støtter ved å lese i brukermanualen, eller bare sjekke på produsentens hjemmeise.
Hvis du absolutt vil ha et nytt skjermkort, gå for 9700. Spar resten av pengene og helelr bruk de på pcen om en stund. NÅR DU VIRKELIG TRENGER DET!
:yes:
