Ståle Skrevet 10. februar 2008 Skrevet 10. februar 2008 Jeg har et problem med tasturoppsettet nar jeg kobler til med VNC. Alle bokstavene og tegnene blir forskjovet :s Hele layouten er feil. Feks i-tasten skriver l. Og jeg finner ingen sensorer som kan si meg hvor varm PCUen er stale@linuxserv:~$ sudo sensors-detect# sensors-detect revision 4171 (2006-09-24 03:37:01 -0700) This program will help you determine which kernel modules you need to load to use lm_sensors most effectively. It is generally safe and recommended to accept the default answers to all questions, unless you know what you're doing. We can start with probing for (PCI) I2C or SMBus adapters. Do you want to probe now? (YES/no): yes Probing for PCI bus adapters... Sorry, no known PCI bus adapters found. We will now try to load each adapter module in turn. If you have undetectable or unsupported adapters, you can have them scanned by manually loading the modules before running this script. We are now going to do the I2C/SMBus adapter probings. Some chips may be double detected; we choose the one with the highest confidence value in that case. If you found that the adapter hung after probing a certain address, you can specify that address to remain unprobed. Some chips are also accessible through the ISA I/O ports. We have to write to arbitrary I/O ports to probe them. This is usually safe though. Yes, you do have ISA I/O ports even if you do not have any ISA slots! Do you want to scan the ISA I/O ports? (YES/no): yes Probing for `National Semiconductor LM78' at 0x290... No Probing for `National Semiconductor LM78-J' at 0x290... No Probing for `National Semiconductor LM79' at 0x290... No Probing for `Winbond W83781D' at 0x290... No Probing for `Winbond W83782D' at 0x290... No Probing for `Winbond W83627HF' at 0x290... No Probing for `Silicon Integrated Systems SIS5595'... No Probing for `VIA VT82C686 Integrated Sensors'... No Probing for `VIA VT8231 Integrated Sensors'... No Probing for `AMD K8 thermal sensors'... No Probing for `IPMI BMC KCS' at 0xca0... No Probing for `IPMI BMC SMIC' at 0xca8... No Some Super I/O chips may also contain sensors. We have to write to standard I/O ports to probe them. This is usually safe. Do you want to scan for Super I/O sensors? (YES/no): yes Probing for Super-I/O at 0x2e/0x2f Trying family `ITE'... Yes Found unknown chip with ID 0x5d00 Trying family `National Semiconductor'... No Trying family `SMSC'... Yes Found unknown chip with ID 0x5d00 Trying family `VIA/Winbond/Fintek'... No Probing for Super-I/O at 0x4e/0x4f Trying family `ITE'... No Trying family `National Semiconductor'... No Trying family `SMSC'... No Trying family `VIA/Winbond/Fintek'... No Sorry, no sensors were detected. Either your sensors are not supported, or they are connected to an I2C or SMBus adapter that is not supported. See doc/FAQ, doc/lm_sensors-FAQ.html or http://www.lm-sensors.org/wiki/FAQ (FAQ #4.24.3) for further information. If you find out what chips are on your board, check http://www.lm-sensors.org/wiki/Devices for driver status.
Sokkalf™ Skrevet 12. februar 2008 Skrevet 12. februar 2008 Hva slags CPU er det snakk om? På nyere CPUer finner man ofte temperaturen i fila /proc/acpi/thermal_zone/THRM/temperature
Ståle Skrevet 12. februar 2008 Forfatter Skrevet 12. februar 2008 Det er en Celeron 2,8GHz Socket 478 Det er ingenting i /proc/acpi/thermal_zone/
Sokkalf™ Skrevet 20. februar 2008 Skrevet 20. februar 2008 Beste tipset jeg kan gi er å google på navnet på hovedkortet ditt + "sensors linux" eller noe i den dur.
Ståle Skrevet 20. februar 2008 Forfatter Skrevet 20. februar 2008 et que avec le problem de VNC? Det er litt vanskelig a gjore noe som helst pa serveren nar i = l æ = o - = enter shift = 1 enter = mellomrom (jeg kan ikke si osv, for det er ikke akuratt et monster )
Sokkalf™ Skrevet 20. februar 2008 Skrevet 20. februar 2008 VNC bruker jeg ikke, så kan ikke si så mye om det... regner med at du har prøvd å se om det kan ha noe med noen settings på klienten å gjøre? Regner med at ting er normalt når du logger inn med ssh? (Hvis du har prøvd det, da)
Ståle Skrevet 20. februar 2008 Forfatter Skrevet 20. februar 2008 (endret) Jupp, alt funker med ssh. Litt rart, iogmed at jeg fikk til VNC pa Debian. Har litt problem med a finne ut hva hovedkortet mitt heter. Endret 20. februar 2008 av Ståle
Sokkalf™ Skrevet 20. februar 2008 Skrevet 20. februar 2008 (endret) Pleier vel å stå navnet på hovedkortet i BIOS akkurat i oppstarten når den teller opp minne etc. Ellers kan du jo åpne PCen og se, pleier å være trykt på selve kortet. Edit: Ah.. du har en fujitsu-siemens-greie. Da er det sikkert noe egenproduserte saker.. Vet du om det er noe sensorer der i det hele tatt? Dvs, ser du temperaturer i BIOS, andre OS? Endret 20. februar 2008 av Sokkalf^
Ståle Skrevet 20. februar 2008 Forfatter Skrevet 20. februar 2008 Hmm det har jeg faktisk glemt a sjekke. Fant faktisk ingenting.. rart. http://www.ciao.co.uk/Fujitsu_Siemens_SCEN...n_X102__6274233 star det MainboardChipset Type: SiS661FX Data Bus Speed: 533 MHz Installerer Windowns XP pa en annen (lik) na, sa sjekker jeg der. Uansett virker det ikke pa min andre FSC PC, en Celsius H Mobile (laptop) som jeg kan lese av via en app i startmenyen. Men mbmon virker ikke.
Ståle Skrevet 21. februar 2008 Forfatter Skrevet 21. februar 2008 Na har jeg funnet ut at jeg kan se CPU temp med PCWizard i Windows.
