wmpenc.exe starter ofte på tilfeldige tider
wmpenc.exe starter sykt ofte, de fleste ganger uten grund. Og vist den først starter en gang så starter den flere ganger uten og stoppe før jeg går i Task Manager og skrur den av, dette er iriterende da jeg ikke ønsker og bruke tid på sånt.
Noen ideer?
Kan være malware, kan være reell prosess:
http://www.file.net/process/wmpenc.exe.html
The process Windows Media Player Encoder Helper belongs to the software Microsoft® Windows Media Player by Microsoft Corporation (www.microsoft.com).
Description: File wmpenc.exe is located in a subfolder of "C:\Program Files". The file size on Windows XP is 28672 bytes.
The program has no visible window. wmpenc.exe is a Microsoft signed file. It is not a Windows core file. Therefore the technical security rating is 16% dangerous.
Important: Some malware camouflage themselves as wmpenc.exe, particularly if they are located in c:\windows or c:\windows\system32 folder. Thus check the wmpenc.exe process on your pc whether it is pest. We recommend Security Task Manager for verifying your computer's security. It is one of the Top Download Picks of 2005 of The Washington Post and PC World.
