Installere nettverksprinter, PS eller PCL ?
Jeg skal installere en Xerox docucolor 2240 på jobben. Har fått med 2 forskjellige sett med drivere. En er Postscript og en er PCL...
Hvilken av disse skal jeg installere ? :shrug:
Hva er egentlig forskjellen på PS og PCL ?
Takknemlig for svar :)
Det spørs litt hva du skal skrive ut.
Skal du skrive ut vanlige tekstdokumenter med enkel grafikk så velger du PCL. Skal du skrive ut litt mer kompliserte tegninger (autocad, photoshop osv) så velger du Postscript.
PCL was created by HP to provide an efficient way to control printer features across many different printing devices. PCL was originally devised for the HP Dot Matrix and Inkjet series printers. The first printer HP LaserJet printer was released in 1984 with the PCL 3 language.
PCL commands are compact escape sequence codes that are embedded in the print job before being sent to the printer. HP PCL formatters and fonts are designed to quickly translate application output into high-quality, device-specific, raster print images.
The PCL printer language is common to all HP printers and provided the commands needed to support color printing. There are six versions (1 thru 6) of PCL. Each subsequent version of the language includes commands not found in older versions as well as the older PCL commands. As a result, printers with more recent versions of PCL are backwards compatible with software that supports older versions of the language.
There are currently two versions of PCL that are used:
PCL 6 driver - PCL 6 uses a new modular architecture that can be easily modified for future HP printers and exhibits the following characteristics:
Returns faster to the application after spooling data
Prints complex graphics faster
Data streams are more efficient for reduced network traffic
Better WYSIWYG printing
Improved print quality
Truer document fidelity
Complete backward compatibility
The PCL 6 language is very different from the earlier versions of PCL. One significant difference is the manner in which the commands are sent to the printer. Use the PCL 6 driver to take full advantage of the printer features. The PCL 6 driver is recommended unless backward compatibility with previous PCL drivers or older printers is necessary.
PCL 5 drivers - The PCL 5c driver provided the commands needed to support printing in color. Use the PCL 5e driver to preserve compatibility with documents created for older printers.
PS drivers - The PostScript (PS) was originally designed by Adobe® and is an interpretive programming language with powerful graphic capabilities. A program in this language communicates a description of a document to an output device (such as a printer). Generally, PostScript is recommended for use when the following are necessary:
Matching font styles with other users in an organization
When printing in a Macintosh environment
When rendering graphics in a specific manner
When printing with PostScript specific applications
NOTE: Available printing features vary between printer drivers. See the printer driver help files for instructions on using specific printing features.
