Ruter/Proxy
A proxy server acts as a go-between for a browser when it requests information over a network such as the Internet. Institutions use proxy servers because they offer security and performance benefits for groups of people who share the same connection to the Internet.
Normally when you request a document over the Web, your browser talks to the origin server --the computer that has the information--and requests it directly. The server then returns the data to your browser, and your browser displays the data for you. When you use a proxy server, you instruct your browser to contact the proxy instead. Then the proxy server retrieves the information from the origin server, and the proxy delivers the information to your browser.
One benefit that proxy servers offer is data caching. Often, a large group of people sharing the same connection to the Internet will look at many of the same documents. By keeping copies of the documents that it retrieves, the proxy can avoid always having to get the document from the origin server and instead get it from disk. This results not only in faster service for the person requesting the document, but in less traffic going over the group's internet connection.
Så kan noen andre ta routeren :smile:
Så enkelt som bare mor kan si det:
Proxyen øker ytelse (som nevn over av Xior), samt filtrerer forespørsler (altså hvilke websider du får tilgang til eller ei).
Routeren kobler sammen to eller flere nettverk og ruter trafikk mellom disse.
:smile:
Quote:
On 2002-01-10 22:09, Killer_DT skrev:
Men en proxy "binder jo også sammen 2 nettverk på samme måte som en ruter. Man kan jo erstatte en ruter med en proxy server.
Nei, du kan ikke erstatte en router med en proxyserver, men du kan bruke proxy istedenfor router til å dele internettforbindelsen.
