Lost Odyssey trailer
mezzo
Dette spillet blir nok kjøp, men jeg har så mye jeg skal gjennom nå og i nærmeste fremtid så det blir nok utpå vårparten. Jeg har spilt og elsket FFVII og FFX, så dette bør falle i smak..
Jeg er over gjennomsnittet opptatt av achievements, er det noen som kan si noe om disse? Krever de flere gjennomspillinger, eller kan man ta det meste på èn runde? Er det mye å 'samle' i spillet?
Achievementliste:
1. Survived
Complete Disc 1. 125 points
2. Out to Sea
Complete Disc 2. 125 points
3. Surfacing
Complete Disc 3. 125 points
4. The End
Complete Disc 4. 125 points
5. Skill Linker
Make an immortal learn a skill from a mortal using Skill Link. 30 points
6. Skill Master Kaim
Master all of Kaim's skills. 20 points
7. The Dreamer Wakes
Unlock the first episode from A Thousand Years of Dreams. 20 points
8. Big Dreamer
View all the episodes from A Thousand Years of Dreams. 10 points
9. Treasure Trove
Obtain all Treasure Box items in the field. The items you missed may be available at auction houses. 20 points
10. Perfect Three
Achieve Perfect three consecutive times in battle. 30 points
11. No One's This Perfect
Achieve Perfect a total of 500 times in battle. 10 points
12. Thanks a Million
Inflict a total of more than 1,000,000 damage points. 10 points
13. True Warrior
Defeat 1000 enemies in battle. 10 points
14. Well Travelled
Visit all the fields in the world. 10 points
15. Light Class Master
Meet the secret requirement of the Backyard Light Class battle set and win. 10 points
16. Skill Master Seth
Seth mastered all skills. 20 points
17. Skill Master Ming
Ming mastered all skills. 20 points
18. Skill Master Sarah
Sarah mastered all skills. 20 points
19. Skill Master Jansen
Jansen mastered all available skills. 20 points
20. Skill Master Cooke
Cooke mastered all available skills. 20 points
21. Skill Master Mack
Mack mastered all available skills. 20 points
22. Skill Master Tolten
Tolten mastered all available skills. 20 points
23. Skill Master Sed
Sed mastered all available skills. 20 points
24. Spell Collector
All spells have been obtained. 20 points
25. Defeated Cave Worm
You defeated Cave Worm at the Forgotten Cave. 10 points
26. Defeated Persona
You defeated Persona at the Old Sorceress' Mansion. 10 points
27. Defeated Holy Beast
You defeated Holy Beast at Numara Atoll. 10 points
28. Defeated Blue Dragon
You defeated Blue Dragon at the Snowfields of the Northernmost Land. 10 points
29. Defeated King Kelolon
You defeated King Kelolon at Kelolon Village 10 points
30. Defeated Ghost of Eastern Ruins
You defeated the Ancient Spirit Magician Fu at the Temple of Enlightenment. 10 points
31. Defeated Golden Knight
Deactivated all Royal Seals and defeated Golden Knight. 10 points
32. Ring Assembler
Assembled a ring using Ring Assembly. 30 points
33. Middle Class Master
Met the secret requirement of the Backyard Middle Class battle set and won. 10 points
34. Heavy Class Master
Met the secret requirement of the Backyard Heavy Class battle set and won. 10 points
35. Super Heavy Class Master
Met the secret requirement of the Backyard Super Heavy Class battle set and won. 10 points
36. Champion
Met the secret requirement of the Backyard last challenger and won. 10 points
Må si jeg er veldig enig i Ign sin konklusjon.
Lost Odyssey proves that a turn-based RPG still has merit in modern gaming. While there is nothing in Lost Odyssey that will convert action-RPG fans, there is plenty to please those already singing in the choir. Lost Odyssey creates several memorable characters and a somber setting that should please those sick of JRPGs that seem made for 10-year-olds. There are quite a few things that go wrong -- from the bad stealth portion to performance issues -- but none of it kept me from enjoying the overall adventure. It may not be in the same class as Mass Effect, but for a system in desperate need for more quality RPGs, Lost Odyssey fits nicely into the 360 library.
Det hørtes skummelt lenge ut, men jeg er sikker på at det ikke føles så lenge når du sitter med kontrollen i hendene... jeg håper så i alle fall. =/
Det er ikke så ille.. battle themet er utrolig bra, det hjelper mye :)
Endret av tidus2k4
Tror ikke disse framerate problemene osv vil irritere meg mye.
Jeg spilte igjennom Mass Effect flere ganger uten å ense framerateproblemene der i det hele tatt nesten.
Håper spillet er langt nok til og føles som ett evighets-spill, da det er disse virkelig lange eventyrene som jeg blir sittende og digge i lang tid fremover.
etter og ha sett video anmeldelsen til gametrailers vill eg ha spillet nå!
3 uker igjenn :/
men hvordan er levlinga? når man kommer opp i level, hva sjer da? får man points man fordeler eller?
Og har dere tatt noen bosser? var dem fete? :)
Endret av Skogslik
Tror dette blir kjøp etter jeg så video-anmeldelsen fra gametrailers:
Review av Lost Odyssey fra Gametrailers.com
Lost Odyssey virker som et drømmespill fra min side. Har ventet lenge på et slikt spill!
Synes disse video-anmeldelsene fra gametrailers er veldig veldig bra, og de peker alltid på positive og negative sider. Synes at de er veldig rettferdige i sine anmeldelser og jeg stoler personlig mest på de!
EDIT: Lost Odyssey ble slaktet hos Gamespy, det fikk 2.5/5
Veldig som karakterene spriker... Skal vedde på at alle sammenligner det med Mass Effect o.l...
Endret av SirKenneth16
Spørs om NTSC utgaven vil støttes på pal, siden Asia versjonen allerede gjør det (på engelsk), men hvem vet.
Synes kanskje gametrailers overdriver litt i dette reviewet. Tipper jeg ville endt på ign score.. rundt 8-8,2.
Storyen er grei den.. men å gi spillet 9,6 i den kategorien .. no way, da skulle mass effect hatt 20 i story :)
Endret av tidus2k4
