Bilde av 9800GTX?
Dyver`n
Håper indelig ikke at 9800 GTX blir så gigantisk:
Må være en jævla dårlig Photoshop redigering detta! Tror bilde til høyre stemmer bedre kansje!
Info funnet på nett:
GeForce 9800 GTX will be over two times faster than a GeForce 8800 Ultra in real world games and applcations. Up to 40000 in 3DMark06
-price for the GeForce 9800 GTX will be 549-649 USD.
-price for the GeForce 9800 GTS will be 399-449 USD.
9800GTX (G100) Specs:
- Codenamed G100
- 1800 Millionen Transistors
- 65nm process
- 256 shader processors
- 780MHz core clock
- 3200MHz memory clock
- 512-bit memory width
- 2048MB (256X8) GDDR5 chips
- GDDR5 @ 0.25-0.5ns
- Dual DVI-out
- Supports DX 10.1, VP3
- 15-25% lower TDP than 8800GTS
godt poeng nizzen
kommentaren på XBITs forum er jo enda bedre..
ve just received word from the most reliable source in the world.....JESUS. He has told me the following about the 9800 JTX (Jesus X-Treme) !
-6500MM (mega metre) process technology, at MSMMMCFPPC
-Over 700 thousand transvestites
-Second Generation Unified Vader Architecture
-Triple precision magnitude flux capacitors
-GPGPUPGPU-PEE-YEW! native
-Over one TeraFARTS of shader processing ability like jedi's
-MAD+AD homosexual party
-Fully secular priesthood design (touch those kiddies with extra fps!)
-1280-bit memory interface (cos god doesn't hold back)
-4TB GDDR7 graphics memory
-DirectX 42.12c support
-OpenJL 500.326.8 compliant shader support
-eDRAM die for "FREE BJ from a priest"
-built in Cunt (for real men)
-built in boobs
-Improved AA and Ahh fuck off quality levels
"Produced by god, patented by jesus"
You made so many spelling mistakes in your version Erik. Im thinking a real Nvidia source would be less sloppy.
Endret av Spr0cket
Jeg tror at påstanden "GeForce 9800 GTX will be over two times faster than a GeForce 8800 Ultra" er ikke så galt og urimlig. Dette høres riktig ut.
Men jeg tror at bildet er fake, dette er altfor lang jo. :w00t:.
Selv om lang og stor kan ofte være bra, :p men det får være en grense. Jeg tror at dette kommer til å sprenge Starkas kabinneten min :D
Endret av Sam_Oslo
200% ytelse i forhold til ett 8800 Ultra var litt i meste laget. XD
Vi faar nok bare vente paa leakage fra litt mer troverdige kilder. ^^
Skulle ryktene stemme om at den vil bli opptil 2 ganger raskere enn 8800gtx ultra, så kommer jeg til å bli kvitt mitt 8800gts 512mb rimelig kjapt og kjøpe det nye kortet..
Men uansett, er ganske skeptisk til dette nå..
Får håpe Crysis blir noenlunde spillbart med alt maxa ut @ 1680*1050 oppløsning. Tenker da på SLI oppsett av det nye kortet.
-built in boobs
Haha, made me lol :p
Men, neh. Tviler diss ryktene ja.
tviler sterkt
bilde til høyre er 8800gtx/ultra av sparkles calibre version (http://www.calibrestyle.com.tw/news/P880U/news_p880u_en.html)(den "ekslusive i sånn fancy innpakking, mens kjøleren er faktisk en tec cooler fra macs, fabrikk-overklokka version/eller ikke etter hva du ser etter (P880+ for den klokka, og P880 for IKKE klokka)
og bilde til venstre
vel, det viker rett og slett ikke logiskt; bare se på utforminga av "gpuen", 5 sli broer og hvis du ser nøye ved der lyset skinner ved venstre hjøren på den øverste kjøleren, kan du tydelig se at "vifta" er FLAT, i likehet med etiketten/plasten (for såvit også kan du se på selve PCBen, så mitt svar er;
herregud, hva hadde du trodd? NEI
EDIT: 40k i 3dmark 06
neeee, trukke det du
