SHDSL hos Nextgentel....
har fulgt med uten å svare, men hva faen er det som er det for en krangling om noen så enkle utrykk.... :lol:
halv dupleks: innen data- og telekommunikasjon en toveis overføring som kan skje i begge retninger, men bare en vei om gangen.
full dupleks: innen data- og telekommunikasjon, overføring av data i begge retninger samtidig.
:woot:
half-duplex
<communications> (hdx, from telegraphy) 1. A type of communication channel using a single circuit which can carry data in either direction but not both directions at once.
full-duplex
<communications> (fdx, from telegraphy) 1. A type of communications channel which carries data in both directions at once.
On purely digital connections, full-duplex communication requires two pairs of wires. On analog networks or in digital networks using carriers, it is achieved by dividing the bandwidth of the line into two frequencies, one for sending, and the other for receiving.
Det trengs ikke å sies mere vel?
SR
janvidar@athlon:~$ dict duplex
From The Free On-line Dictionary of Computing (09 FEB 02) [foldoc]:
 duplex
    <communications> Used to describe a communications channel
    that can carry signals in both directions, in contrast to a
    {simplex} channel which only ever carries a signal in one
    direction.
    If signals can only flow in one direction at a time the
    communications is "{half-duplex}", like a single-lane road with
    traffic lights at each end.  Walkie-talkies with a
    "press-to-talk" button provide half-duplex communications.
    If signals can flow in both directions simultaneously the
    communications is "{full-duplex}", like a normal two-lane
    road.  Telephones provide full-duplex communications.
Jeg har skrevet dette i de trådene som var om dette temaet hver gang med kildereferanser, men det er tydeligvis noen som har trangt for å forstå dette...
Hvis du fremdeles er i tvil kan du lese litt om saken hos ITU - (International Telecommunication Union). Standarden for ADSL heter G.922.1
Det du har quotet her er er jo bare en forklaring på forskjellen mellom halv- og full duplex og således ikke interessant i denne sammenheng. Det som vi vel strides om er om ADSL er full duplex eller ikke.
"To create multiple channels, ADSL modems divide the available bandwidth of a telephone line in one of two ways -- Frequency Division Multiplexing (FDM) or Echo Cancellation. FDM assigns one band for upstream data and another band for downstream data."
"A DSL transmits duplex data, i.e., data in both directions simultaneously.."
www.dslforum.org
Altså dere har nok alle litt rett det avhenger av bare hvor man ser det ifra.
Definisjonen av Full Duplex er sånn ca at man kan sende tog motta trafikk samtidig på en "kanal".
ADSL bruker 2 kanaler til å kommunisere, en oppstrøms og en nedstrøms kanal.
Hver av kanalene kan bare sende trafikk i en retning, så hver "del" av ADSL er Half Dulpex. Dog ADSL må ha 2 kanaler, uten begge virker det ikke og man har da ikke ADSL om det ikke virker.
Så om man ser på ADSL fra et litt høyere punkt og glemmer de kanalene så er den Full Duplex, for ditt ADSL modem/router kan både sende og motta trafikk samtidig.
JPT
Med andre ord, ADSL er full duplex.
Om Hyperthreading er full duplex eller ikke skal jeg ikke være skråsikker på, men dette kan vel tyde på at det er det:
"Even more important is the fact that the Pentium 4's two ALUs can each execute 2 micro-ops per clock, meaning that two ADD instructions each one from two different threads could execute in a single clock on the Pentium 4/Xeon."
www.anandtech.com
Det blir vel omtrendt like "samtidig" som at man kan kjøre flere programmer "samtidig" (multitasking) på én prosessor.
Med det argumentet der så er ingen ting Full Duplex, siden CPU på CPE multitasker og tar seg av alt som CPE må gjøre, utover å kommunisere med adsl chipsetet..
Så hvis det argumentet er riktig, så blir vel konklusjonen at xDSL ikke full duplex?
JPT
halv dupleks(ADSL): innen data- og telekommunikasjon en toveis overføring som kan skje i begge retninger, men bare en vei om gangen.
full dupleks(SHDSL): innen data- og telekommunikasjon, overføring av data i begge retninger samtidig.
:woot:
