Gears of War 2-Kafeèn!
A new stamina bar is introduced and will determine how far you can run and how long you can fight.
Det hadde da vært bedre hvis stamina bare gjaldt løping. Fighting også? Så de blir slitne av å skyte eller av mange Chainsaw-duels? Skeptisk....
En-garde høres gøy ut :)
Er dette old?
Klikk for å se/fjerne innholdet nedenfor
-New weapon Scorcher (Flamethrower) "most realistic fire in a game we've ever seen"
-5 vs 5
-Assasination gametype altered. everyone respawns until their leader is dead. when the leader is killed they stop rewpawing and the game ends when everyone is dead on one team.
-Assasination renamed 'Guardian'.
-New gametype 'Wingman' 10 players split into teams of two.each team is played as different character (eg marcus and marcus vs Dom and Dom etc)
-Features Matchmaking
-Exectucions now vary on the weapon you holding (eg sniper rifle will be used like a golf club)
-Curb stomp returns
-'Y' will cause your character to unleach several brutal punches to a downed enemy, killing him.
-'A' will cause you to pick up the enemy and use him as a shield. The player your using as a shield will go to the respawn line.
-New gametype 'meatflag' sort of like CTF but epic have done this in their own way. The flag will instead be character wandering around the centre of the map. He has his own weapons and even a place on the leaderboard.
To capture him you will need to down him and pick him up as a meatshield and take him back, slowly, to your base. If you shoot the meatflag enough times while he's being dragged back to base, his captor will loose him and he'll go crazy on everyone around him.
-Specific weapons will cycle round the maps.
-Stopping power - if your running towards an enemy but he is firing straight into your chest, you will slow down.
-The oppurtunity to spawn with either the lancer or hammerburst.
-Hammerburst gone through significant alterations. The faster you tap the the right trigger, the faster it fires. quicker shooting = more recoil however.
-New weapon Medusa. could be considered a power weapon. 6 shots per burst.
-Bullet shields. big metal shield that stops you from getting hit. can be planted into the ground to make a new cover. enemies can kick it down though if they get close enough.
-Grenades can be stuck anywhere. not just on enemies. they can be planted on the ground,walls,doors etc to produce a proximity mine.
-smoke grenades carry a stun effect that ragdolls anyone in range.
-new weapon poison gas grenade. produces a cloud of smoke that kills anything that lingers in it. they can be stuck onto enemies were the will slowly die. people stuck by the gas grenade can also injure team-mates if the get too close.
-On games with no respawn, when you are dead you can fly around the map as a "ghost cam". You can even take screenshots that will be uploaded to the community.
-Gridlock returns. However its more overgrown now, plants and grass growing.
(everything is still the same though- cars are where they where etc)
-New map - 'river' - symetrical map, each team has a thin strip of land with a house and sniping tower, and inbetween them a river.
-New map - 'Security' - long thin map. to the left and right are stairs leading to veranda's that run the entire length of the map. you are barred access however by red lasers, which will kill you if attempting to pass through. A power weapon is barred on the other side of the map while at the other it is defended by sentry guns. There is a button in the middle of the map that turns the lasers and sentry's off for 20 seconds.
-New locust 'hammerhead' (helmet makes him look sorta like a hammerhead shark)
-New locust 'Grenadier' (this is the guy we saw in the video were marcus punches him to death)
-Two people can chainsaw one guy at the same time.
-New cog 'Tai' has aboriginal tattoo's.
-New cog 'Dizzy' "looks like chuck Norris"
-Cole returns for multiplayer at least.
- A new stamina bar is introduced and will determine how far you can run and how long you can fight. In other words, if your stamina bar is low, your overall performance will be lowered as well.
WTF? NEEEEEEEEEEEEEEEI! EPIC IKKE GJØR DET MOT OSS!
Hvis det er sant med den stamina baren, gi oss ihvertfall ett "old school" valg i MP hvor ting blir identisk som Gears1. Ellers så ser det jo helt konge ut! Jeg pleier alltid å spamme granater, og både røyk og gift kan bli gøy(ere) da.. :wee:
Kanskje vi skal starte en underskriftskampanje mot stamina?
:p
I'm in! Makan til møkk!
MATCHMAKINGDRITT
HOREMØKK
Og Boff3n belyser oss igjen med sin allmektige kunnskap og saklighet.
Han er vel faktisk en av de få her inne som har spilt Gears aktivt, og jeg ser på meningene hans som verdifulle, uansett hvor dårlig formulerte de er.
Selv synes jeg at Matchmaking er en fin ting, men at det burde være valgfritt å bruke det, da det har sine (ganske store) nedsider.
Gjest Slettet+981234789
vent og se hvordan det Stamina greiene blir, før dere dømmer det, mulig det fungerer veldig bra.
og matchmaking er den største nye tingen i G2MP endelig kan man spille sammen med venner uten for mye mas.
Nettopp. Så STFU! Mye av grunnen til at Gears blei så populært var jo det enorme communitiet det la opp til. Matchmaking ødelegger sånnt. Eget servervalg funka dritbra i Gears, hvorfor i helsike skal de endre på det? Å si noe som dette, uten å virke skikkelig arrogant er vanskelig; men dersom du faktisk har spillt Gears ordentlig på et høyt nivå, og et matchmakingspill, så er det ganske innlysende hvor mye gøyere det er med custom rooms.
Håper bare resten av spillerne skjønner dette og ikke benytter seg av matchmakingmulighetene. Slik som Gears er nå er så godt som hver match en scrim, og dette er uten tvil at dette fortsatt er det største onlinespillet i Europa.
Jeg kan sikkert argumentere mer imot hvorfor MM er så møkk, men jeg tipper du leste nok i min forrige tråd?
Edit: Ikke rettet mot nirds innlegg.
@Nird: Når var Gears sitt system mas?
Endret av Boff3n
for å kunne spille sammen med en venn eller fler måtte man lete seg fram til serveren som han startet.
slik det er nå funker det bra hvis du spiller alene.
det kan man sikker velge i G2 også.
men for meg er MM mye bedre siden jeg vill spille f.eks med 5 venner mot 5 andre...
ja mulig det men tror jeg spilte der mest fordi der det va flest folk,
og selvfølgelig få achievements osv...
:p
MATCHMAKINGDRITT
HOREMØKK
Innlegg som ikke argumenterer for det han sier kan aldri være "verdifulle" etter min mening, greit kanskje han har rett, men det forandrer ikke på det faktum at han da kunne ha anstrengt seg bitte-litt for å faktisk forklare hva som er så dritt med ting, det virker jo på hele fremtoningen hans at han bare vil være arrogant med vilje, noe jeg ikke forstår hvorfor noen vil være, men det får så være.
Jeg vet selv at Boff3n er en dyktig spiller, mendet forandrer ikke det faktum at jeg synes at han er utrolig arrogant, og til tider barnslig i innleggene sine, noe som må sies å være ganske synd, men når noen konstant stryker på e-peen hans så kan man vel ikke forvente noe annet?
ydmykhet er en fin ting, ellers så får jeg vel bare vente til han blir moden nok til å skjønne at å være arrogant ikke blir sett på som en styrke.
Men nok negativt om Boff3n, var ikke meningen å lage dette en anti-boffen post, siden boffen faktisk HAR (etter sitt veldig...forumlerte innlegg) laget et velformulert inlegg, noe som øker sjansen for at han faktisk blir hørt.
Ja det er sant, folk burde høre på Boffen til tider, da han har erfaringen og faktisk skill, men hvem gidder vel å høre på en som på liv og død må bruke caps lock, arroganse og banning i nesten hvert innlegg for å få frem poenget sitt?
Uansett, beklager at dette virker som en heksejakt på deg Boffen fra min side, men jeg føler at jeg må få ytre meningen min, med alt dette sagt, du er en erfaren spiller, det hadde bare vært så utrolig mye bedre om du kan gå rett til formuleringen, istedet for å gå gjennom alt det jeg nevnte i sted.
Endret av NiXx
:p
MATCHMAKINGDRITT
HOREMØKK
WTF? Når ble Boffen en verdifull spiller?? Husker han mest som en dude som sto bakerst i rekka med saga på lur? he he
Men for all del! Han har jo rett.. eg skjønte godt ka han meinte eg.. trenger ikkje utdype det så fælt!
MATCHMAKINGDRITT HOREMØKK.. var vel langt på vei godt nok for de fleste som veit ka det går i...
Edit: litt mye quoteing... men det ordne seg!
Endret av RoninMasao
