Hva skjuler det seg bak din Ctrl+v?
  • 3 uker senere...
  • 2 uker senere...
Matchpoint (Pairs) Strategy at Duplicate
Bridge
The Bidding :
Bid aggressively. Duplicate pairs tend to bid "close" games
and slams, so don't settle for a safe partscore if you think
there's a fair chance (60 percent or better) that you can
make game.
Choose the highest-scoring game. For game contracts,
you should be most anxious to play 4H or 4S, willing to play
3NT and reluctant to play 5C or 5D. If you have game
values and a club or diamond fit, consider playing 3NT
instead.
Choose the safest partscore. When you have minimum
high-card strength, choose the safety of a trump suit. A
major-suit is still best, but if you're deciding between a
notrump and a minor-suit partscore, play the suit
contract if you have a fit.
Overcall freely. At the one-level, don't be afraid to make
light, lead-directing overcalls (as few as 8 or 9 points if
you have a good suit), especially if you're not vulnerable
and your opponent opens a minor. If you have to go to the
two-level to bid your suit, though, be cautious. For a two-
level overcall, you should have good high-card strength
(11-12+ pts.) and a very good suit (a strong 5-carder or,
better, a 6+-card suit). A vulnerable two-level overcall
should be even stronger.
Raise partner's suit freely. Even if you're light in high-
card points, stretch to raise partner if you have a fit for
his suit, especially in competitive auctions.
Sacrifice more often. If you have a good fit, sacrifice
freely if your opponents are vulnerable and you are not.
But be very conservative about sacrificing when you're
vulnerable.
Don't "sell out" too low. If the opponents stop at a low
level, you don't have to have a strong hand to balance back
into the auction. The best situations for competing are
when:
(1) You're not vulnerable;
(2) The opponents have stopped in 1 or 2 of a suit
contract (not 1NT or 2NT); and
(3) You hold shortness in the opponents' trump suit.
Double more partscores. If you bid to a partscore you
think you could have made, but your opponents bid over it,
a double is sometimes necessary for you to get even an
average score. (Be very careful in choosing when to use
this tip!)
Use a simplified form of the "Law of Total Tricks (Trumps)"
for competitive decisions. In partscore situations --
those where you've found a fit but wanted to stop below
game -- don't let the opponents push you to the three-
level unless you have at least a 9-card trump fit.
The Play:
Make "normal" opening leads. Don't try for a "top" by
choosing an unusual lead. Against most contracts, choose
a safe, non-deceptive opening lead.
Look for overtricks. Unlike in rubber bridge, it's
sometimes right to make a fairly risky play trying for the
overtrick -- especially when you're in a "normal" contract
that you think will be bid by other pairs.
Play it safe if you're in an unusual contract. Go for the
sure plus score if you're playing or defending a contract
that you think probably won't be bid at most tables.
In General :
Play with the "field". When in doubt about what to bid or
play, try to guess what might be happening at other tables
and go for a similar result.
Consider using 15-17 points as the range for your opening
1NT bids. A 1NT opening often gives you a bidding
advantage because your responses are so well defined and
your opponents will find it more difficult to enter your
auction. Most duplicate players use the 15-17 range
(rather than 16-18) because it allows them to open more
hands with 1NT. If you use this range, responder will need
to adjust his point requirements up by 1 pointt. You should
also change your 2NT opening range to 20-21 or 20-22
points.
Consider adding popular conventions to your system.
Because many duplicate pairs play the conventions and
treatments listed below, you might want to try them, too.
Recommended (in a rough order of which are most
valuable):
